Quantcast Climate Control? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Climate Control?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFREE shipping on Rugged Ridge Soft tops @thejeephut.comGR8TOPS Introduces the Exogate HD Tire Carrier
Old 03-03-2009, 03:11 PM   #1
Yelladog1
Yelladog1's Avatar
Climate Control knobs?
Can you interchange climate controls (The Whole Module That Goes Into The Dash) from 2001 TJ to 1998 TJ w/ac?
Yelladog1 is offline   Reply With Quote
Old 03-03-2009, 03:13 PM   #2
RnEmOvr
Never Forget
RnEmOvr's Avatar
so you want to go from sliders to knobs?
My Jeep 2.5-4.0 Motor Swap, Very detailed Military Jeepers
Guns have only two enemies; rust and politicians.
www.cityprofile.com
RnEmOvr is offline   Reply With Quote
Old 03-03-2009, 03:15 PM   #3
Yelladog1
Yelladog1's Avatar
Yes, I would like to
Old 03-03-2009, 03:43 PM   #4
Yelladog1
Yelladog1's Avatar
Anyone know?
Old 03-05-2009, 11:27 AM   #5
Yelladog1
Yelladog1's Avatar
Just wanted to run this one by you all again!
Old 03-05-2009, 11:39 AM   #6
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Its possible, but I would not recommend it.
The dial type controls are troublesome.
Someone here on the forum did this swap some time back. I'll see if I can dig up the thread.
You probably already know this, but its not just a simple swap of the controls. You need to swap out at least half of your heater box.
98 TJ
Wheelin98TJ is offline   Reply With Quote
Old 03-05-2009, 01:30 PM   #7
Yelladog1
Yelladog1's Avatar
Ok Thanks WHEELIN
Old 03-05-2009, 01:38 PM   #8
Wheelin98TJ
JEEP FREAK
Here is some info on the swap:
http://www.jeepforum.com/forum/f9/hvac-update-296359/#post2414910
98 TJ
Glock Forum
