Clifford Performance camshaft for my 2.5L or just a regular camshaft? - JeepForum.com
post #1 of 8 Old 04-15-2010, 10:29 AM Thread Starter
r_unda
I will be replacing the camshaft on my jeep and I am trying to decide what I should buy. Will I actually notice a difference in performance? I know it’s only a 4cyl but a little bit of gain would help.
If you actually have a 4 cylinder engine and installed a performance camshaft please let me know what your opinion/experience is/was.
Thank you,
Raul
My Jeep isn't getting older, it's getting newer part by part
2011 WK2 HEMI 4x4 Overland
2007 WK CRD 4x4 Limited GDE Tuned
1998 TJ SE
1973 CJ5 - YJ OME 2.5" lift, 33" tires
1951 Willys truck
r_unda is offline
post #2 of 8 Old 04-17-2010, 12:45 PM
VikesTJman
I know you only wanted to hear from someone that personally installed it, but i have a good friend that did and said "it didn't do much for the money i spent." Just tryin to help.
‎"The Democracy will cease to exist when we take from those who are willing to work and give to those who are not." -Thomas Jefferson
My Jeep Build:
VikesTJman is offline
post #3 of 8 Old 04-19-2010, 09:58 AM Thread Starter
r_unda
Thanks. I actually got more answer at the YJ tech forum.
Here is the link:
http://www.jeepforum.com/forum/f12/c...1/#post9310871
1998 TJ SE
1951 Willys truck
r_unda is offline
post #4 of 8 Old 04-19-2010, 10:04 AM
wtroger
Performance and 2.5L probably shouldn't be used in the same sentence. You have to be careful with how big a cam you put in so the Ecm doesn't throw a fit.
wtroger is offline
post #5 of 8 Old 04-19-2010, 10:11 AM Thread Starter
r_unda
I know. Here is what I said on the YJ tech forum:
Originally Posted by r_unda View Post
When I talked to Larry from Clifford he mentioned that they have two models for the camshafts. That if I ordered one I should make sure I mentioned that it is for an EFI 2.5L and that I could only run their 264 degree camshaft because that’s the only one my stock engine and ECU could handle.
1998 TJ SE
1951 Willys truck
r_unda is offline
post #6 of 8 Old 04-19-2010, 10:17 AM
STW
When I did the research for this possibility for my 2.5 I found that the performance cams (including the Clifford one I think) attempt to increase hp by increasing overlap (the amount of time both the intake and exhaust valves are open together) which raised hp at the higer rpm range. This usually decreases torque at the lower rpm range since adding overlap kills some backpressure. This is the typical performance cam approach because most performance auto applications are not concerned about torque but need more hp at the high end to increase top end speed and quarter mile times. But the 2.5L in the Jeep is right at the minimum usable torque that can even get the Jeep going, and in my experience you notice any loss of torque at the low end as less power, less drivability, right away. But you don't notice much advantage in a little extra hp at the high rpm range like you'd notice it in a V8 application where you have plenty of torque and need more top end.
What I learned is that a better performance cam upgrade for the 2.5L was what is called an RV cam--a cam with lobes engineered to increase backpressure and low end torque at the slight expense of high rpm hp. There were good reports from several 2.5L RV cam installs on JeepForum and the old Fourbangers united forum. I haven't gotten around to this install but it's one of the few things I'd consider for the 2.5L based on my research.
Edit: just read your YJ forum thread and it sound like the Clifford cam is a torque emphasizing RV cam design. Will have to look into the Clifford.
2000 2.5 TJ, 5spd, 33s, 8274
STW is offline
post #7 of 8 Old 04-19-2010, 12:38 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Buy a Comp Cams kit and put a 4.6L stroker around it.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #8 of 8 Old 04-19-2010, 12:59 PM
Robert J. yates
I responded over on the other thread.... there is a fair bit of mis information being shared over there.
Robert J. yates is offline
Bad camshaft in some 04 TJs PackMan TJ Wrangler Technical Forum 4 01-22-2012 12:34 PM
2.5L Camshaft? jaybird02 TJ Wrangler Technical Forum 1 03-19-2008 09:44 PM
Performance camshaft install jeepboy21 YJ Wrangler Technical Forum 12 06-11-2006 05:02 PM
Camshaft Joeys97TJ TJ Wrangler Technical Forum 8 05-31-2006 03:05 PM
4.2l performance camshaft options.... Radioflyer YJ Wrangler Technical Forum 2 09-02-2002 11:32 PM
