Clicking/snapping noise when braking at slow speeds or in park - JeepForum.com
post #1 of 8 Old 07-24-2013, 09:07 PM Thread Starter
odinseye84
My 05 jeep has developed a sort of clicking when depressing and releasing the brake pedal sometimes at low speeds or when parked. Its a manual so its not the PRNDL switch, I think I can hear it in the rear brakes (which were adjusted/cleaned 10k ago, 68k on the jeep now)
I can also sometimes feel it in the brake pedal. I was thinking obviously brake related, although sometimes I think it could be some sort of u-joint issue as well.
Im not too experienced with drum brake systems, so I would like to hear everyones opinion on where to start looking/what may be the cause.
odinseye84 is offline
post #2 of 8 Old 07-25-2013, 02:18 AM
oakmckinley
Climb under there and pull on the driveshafts, any movement and its a bad u joint.
If you can feel it in the pedal, chances are its not the rear drum cause the feeling wouldn't be transmitted via the brake lines. It wouldn't hurt to pull the rear drum off and investigate, the only thing that can be causing noise there would be if the springs got broken and you don't need to be a mechanic to see that. Is the parking brake operating normally?
It maybe a problem with the pedal. Look and see where it attaches to the master plunger and make sure you didn't have a pin fall out or anything. FYI the master plunger goes through the firewall to your brake pedal, so you'll be looking inside the jeep near you feet.
1999 TJ
2010 Mustang
1964 Ford Fairlane 500
oakmckinley is offline
post #3 of 8 Old 07-25-2013, 11:59 AM Thread Starter
odinseye84
Thanks for the advice, should I pull on them in and out or twist to check for movement?
post #4 of 8 Old 07-25-2013, 01:02 PM
oakmckinley
You should be able to feel a very small amount of turning which is normal. Although no up/down movement.
1999 TJ
2010 Mustang
post #5 of 8 Old 07-31-2013, 05:22 PM Thread Starter
odinseye84
Upon further investigation, it seems the sound is coming from the rear brakes perhaps, sound is consistent with speed. It only starts after driving awhile. Has anyone experienced this?
post #6 of 8 Old 08-01-2013, 10:49 AM
oakmckinley
Time to open them up. I have had broken springs in the past. Something may be broken and and moving around in there.
1999 TJ
2010 Mustang
post #7 of 8 Old 08-01-2013, 11:37 AM
j_bydesign
Wrench Wheel Repeat
j_bydesign's Avatar
check your control arms and other fixed negth susension arms... I had the sway bar end come loose on my front axle... and it made a clunking
'04 TJ(wheeler) '65 CJ5(sold :( )...'05 LJ(Scrambler conversion, SOLD!) 89' Int. Harvester Toter (get the TJ to and from)! '80 CJ7 Resto Mod(sold) 1985 CJ7 Renegade (in process/million pieces)
j_bydesign is offline
post #8 of 8 Old 07-18-2014, 07:49 AM
Tommy R
Tommy R's Avatar
Mine just started doing this. I can hear a slight click....click.....click with each tire revolution as I'm braking at slower speeds. Whether I'm applying the brakes via the pedal or e-brake makes no difference. I'm going to pull the drums today (everything new a few hundred miles ago) and see what I can find. Did you ever determine what the problem was?
2001 Wrangler homemade long arm, 99" WB, ARBs, alloys, 4.88s, 35" MTRs
Tommy R is offline
