clicking noise when decelerating - JeepForum.com
post #1 of 4 Old 03-04-2014, 09:16 AM Thread Starter
huntin20
I have a clicking noise coming from my rear end during deceleration. It is a Dana 44 with 3:73 gears. I replaced the clutches, spider gears, and carrier bearings. The drive shaft doesn't have excessive play and it still makes a clicking noise. What else could it be?
huntin20 is offline
post #2 of 4 Old 03-04-2014, 09:39 AM
Vinman
Sounds like a dry U-joint
Vinman is offline
post #3 of 4 Old 03-04-2014, 09:44 AM
JStMarie
JStMarie's Avatar
Pull the rear drive shaft, then check for play. While in place you'd be surprised how little play they will have even when the U-joints are completely toast. I know I was.
JSt.Marie
'06 Jeep Wrangler, 65th Edition, stock.
'98 Jeep Wrangler, stock.
JStMarie is offline
post #4 of 4 Old 03-04-2014, 09:25 PM
vic_sinclair
Did you ever drop the driveshaft to physically check the U-joints before replacing all those other parts? I just had a U-joint go south and there was no play. I did have what I would describe as pinging or clicking. Turns out a needle bearing had snapped in half. Always start with the components that are designed to wear out.
vic_sinclair is offline
