-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   clicking noise when decelerating (http://www.jeepforum.com/forum/f9/clicking-noise-when-decelerating-2178105/)
huntin20 03-04-2014 09:16 AM
I have a clicking noise coming from my rear end during deceleration. It is a Dana 44 with 3:73 gears. I replaced the clutches, spider gears, and carrier bearings. The drive shaft doesn't have excessive play and it still makes a clicking noise. What else could it be?:mad:
Vinman 03-04-2014 09:39 AM
Sounds like a dry U-joint
JStMarie 03-04-2014 09:44 AM
Pull the rear drive shaft, then check for play. While in place you'd be surprised how little play they will have even when the U-joints are completely toast. I know I was.
vic_sinclair 03-04-2014 09:25 PM
Did you ever drop the driveshaft to physically check the U-joints before replacing all those other parts? I just had a U-joint go south and there was no play. I did have what I would describe as pinging or clicking. Turns out a needle bearing had snapped in half. Always start with the components that are designed to wear out.
The time now is 06:56 PM.
