Clicking noise that goes away when I hit the brake - JeepForum.com
post #1 of 14 Old 04-19-2009, 12:37 PM Thread Starter
nathanielt
So, I've been trying to do my own work on my jeep since most of it's pretty simple. Just doing minor things like a tuneup. Actually, none of this is really relevant to my question, lol.
I've notice that when I start my jeep there's a weird clicking noise that seems to come from the front end. I've noticed this off and on, it doesn't always do it. When I hit the brake, the clicking stops.
I've tried searching the forum but haven't really found an answer. The noise doesn't speed up when I hit the gas. It stays constant. I can't really tell if it continues to make noise in higher gears since the engine noise is too loud to hear it. Has anyone else had this problem, or know what the cause could be?
Thanks in advance! I haven't posted here much, I think only when I first bought my jeep and was trying to find out if people here thought it was a good deal, but I lurk around a lot and the old threads are really helpful
nathanielt is offline
post #2 of 14 Old 04-20-2009, 07:04 PM Thread Starter
nathanielt
Does anyone have any thoughts on this clicking noise? I just realized the other day it only makes the noise if my jeep has been sitting for a couple days. It goes away after a bit of driving and doesn't start again unless it sits for a few days.
post #3 of 14 Old 04-20-2009, 08:24 PM
skip44
Check your brake calipers to see if they are loose. I chased a similar noise for a long time in my XJ and finally found the caliper mounting bolts had worn and caused a slight rattle, especially on a rough road surface and it would go away when you applied the brakes. NAPA has the replacement mounting kit if thats what it is. Good luck, hope you find it faster than I did.
skip44 is offline
post #4 of 14 Old 04-20-2009, 10:03 PM Thread Starter
nathanielt
Do you think that could be it even if it makes the noise while I'm not moving?
post #5 of 14 Old 04-20-2009, 10:42 PM
sporticon03
I'm not sure what exactly you mean, but, I had a clicking noise that I noticed w/ the windows/top down when I drove by a close building or by parked cars, braking also made the noise go away. It could be brakes but Im pretty sure it went away when I had my driver's side front U-joint replaced. I'd check those for play. My mechanic said the noise is sometimes a symptom. If it isnt the U-joints and your brakes are fine I'd say not to worry about it, unless its very loud.
sporticon03 is offline
post #6 of 14 Old 04-21-2009, 04:59 AM
Junky burp
I read a while back where there was some component in the vacuum sytem that would make this clicking noise, akin to the noise of a lifter, but at a slower frequency. It was described as a check ball thingamajigger deal, somewhere under the hood.
Junky burp is offline
post #7 of 14 Old 04-21-2009, 06:38 AM
NotURMailman
NotURMailman's Avatar
To clarify... it clicks whether you are moving or not and goes away when the engine warms up or when you hit the breaks?
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #8 of 14 Old 04-21-2009, 07:25 AM Thread Starter
nathanielt
Yeah, so I'd noticed it off and on. The last time I noticed it I hadn't driven my jeep for a couple days, and then I thought back and realized that that's been the case everytime I'd hear it. So, it starts when the jeep sits for a couple days, hitting the brakes stops it. There's no sound when the jeep's been running for about 15-20 minutes (although that's a guess since I was driving on the highway and couldn't hear it if I tried). But if I'm driving it everyday, the noise isn't there.
The noise isn't a big deal to me, since it's irregular and I usually don't let my jeep sit for long. I just want to make sure it's nothing that could cause long term damage.
post #9 of 14 Old 04-21-2009, 08:28 AM
NotURMailman
I was going to sugget a cracked exhaust manifold that leaked when cold and stopped when it got hot, but that would have nothing to do when hitting the brakes. Sorry, that's just weird... I have no idea!
post #10 of 14 Old 04-21-2009, 10:54 AM
shrubeck
Check your lug nuts. I had a clicking that I thought was brake calipers because it went away when I stepped on the brake pedal. It turned out to be loose lug nuts. Not something you want to ignore and hope it goes away.
That's what she said.
shrubeck is offline
post #11 of 14 Old 04-21-2009, 11:14 AM
hyperrust
I had this problem with my Hyundai Elantra. It was a little metal shim that was part of the front disc brakes that had broken. They took it off, and everything was back to normal.
Sorry for the nontechnical description.
hyperrust is offline
post #12 of 14 Old 04-22-2009, 09:59 AM Thread Starter
nathanielt
Thanks guys. I think I'm going to let it be for now. Just seems weird that it only happens when the engine hasn't been run for a couple days, lol. I'm hoping it's nothing serious, but I guess I'll find that out later if something happens!
post #13 of 14 Old 09-20-2011, 08:07 PM
gman-monona
the clicking noise in the front as you say, is that the front of the jeep like under the hood or is it under the dash like mine?
my 99 grand cherokee clicks after i release the brake pedal too. i tracked the noise down to at first under the dash and tonight i pinpointed it as coming from inside a rubber boot that gets depressed when i step on the brake. that is as far as i got, any ideas what it is?
gman-monona is offline
post #14 of 14 Old 09-20-2011, 08:32 PM
andy02
If I am reading this right, it does it sitting still as well as moving? It does it only after the Jeep has been sitting a couple of days, and it is independent of engine speed?
I think I know the noise you speak of, sounds basically like a relay clicking on and off at a constant speed? Mine seems to come from the passenger side rear but it doesn't matter if I touch the brakes or not. I haven't figured out what it is yet. Seems like everytime I go after it, the sound goes away.
Originally Posted by Hendrix
September 11 2001
Never Forget!
andy02 is offline
Another clicking noise ? Jcas TJ Wrangler Technical Forum 3 10-12-2009 10:38 AM
D30 clicking noise??? Skortch311 TJ Wrangler Technical Forum 8 10-10-2009 03:14 AM
Clicking noise?? Help please !!! 01blackws6 YJ Wrangler Technical Forum 8 01-24-2009 10:33 AM
Clicking noise Serafim TJ Wrangler Technical Forum 7 07-05-2005 06:09 PM
Clicking noise zex TJ Wrangler Technical Forum 5 09-12-2004 10:58 AM
