Clicking Noise from Driver Side - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Clicking Noise from Driver Side
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder from CCOR!Oconee Offroad Sales Tech are Available To Help!
Unread 06-15-2012, 09:36 AM   #1
Anatase
Yay first post after 4 years
Anyhow - I have a 2000 Jeep Sahara and a new noise had cropped up. Hard to tell exactly what it is at this point - I only hear it when passing by barriers or buildings to reflect the noise.
I Recently had my rear breaks upgraded (again) and my bearings fixed (again) - so I know it doesn't sound like a failing brake pad or a missing brake slider thing. Nor does it sound like a bearings that went south in less than 2 days from install (oops).
What it does sound like is small metal to big metal and it does speed up/ slow down as the jeep does.
I don't think the control arms would be constant with rotation speeds of the tire and that noise would be more a clicking when going over stuff right?
Perhaps the brakes need to be tightened down?
Anatase is offline   Reply With Quote
Unread 06-22-2012, 03:18 PM   #2
Anatase
I think I have 3 distinct noises.
1. my normal timing noise getting a little worse
2. the noise I describe above - sounds like it's from the rear
3. then a noise that sounds like a gross vibration in the tail pipe rattle when I accelerate (perhaps a vacuum related sound) - very obvious when I do short quick accelerations.
