Clicking/grinding in front in 2wd, less in 4wd - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Clicking/grinding in front in 2wd, less in 4wd
Only 2 Days left to win $3,800 Jeep Parts!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAttention seahawks fans!!! Want to save some $$$ ??!!
Unread 01-22-2015, 08:08 PM   #1
blysccr
03 automatic rubicon. Noticed after I did the break bed in I had a clicking on acceleration up to like 30 mph. Also does it around turns. When put into 4wd it's much less noticeable, but still there. I really have no idea where to start as the front driveshaft spins regardless...right?
Link to my build if this helps.
http://www.jeepforum.com/forum/f22/35s-no-lift-2920609/
Cv head on front shaft had no play 2k miles ago. Ujoint on the diff was replaced 2k ago.
I'm going to pull it into the shop this weekend and can check stuff out but like I said have no idea where to start.
Any ideas?
blysccr is offline   Reply With Quote Quick reply to this message
Unread 01-22-2015, 08:10 PM   #2
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
Start checking hub assy and front u-joints. I know you said they are new but what brand?
RnEmOvr is offline   Reply With Quote Quick reply to this message
Unread 01-22-2015, 08:13 PM   #3
blysccr
Last time when the jeep was in the air (two weeks ago)the hubs felt decent- but will certainly look again. Napa gold- local spicer guy said "I don't do part numbers, bring it in" so I did and he gave me the wrong size...go figure.
Unread 01-22-2015, 08:19 PM   #4
RnEmOvr
RnEmOvr's Avatar
All 5 joints in the front? 2 in axle and 3 in shaft?
Unread 01-22-2015, 08:22 PM   #5
blysccr
Front shaft ujoints are oem. No moticable play two weeks ago when I did the brakes. Will check those as well. I have a set of shafts with 6k on them I may throw in the front??
The cv head -2 joints was tight. Differential side ujoint was new.
Unread 01-22-2015, 08:23 PM   #6
RnEmOvr
RnEmOvr's Avatar
Don't go by miles or two weeks ago. Stuff can go bad over night.
Unread 01-22-2015, 08:42 PM   #7
Andy5150
I had noises I thought was bad spider gears in the rear axle, and it turned out to be bad front driveshaft u-joints. The popping sound only happened when turning. I pulled the front driveshaft, and no noise.
Andy5150 is offline   Reply With Quote Quick reply to this message
Unread 01-23-2015, 01:47 AM   #8
jaspepp
Another vote for ujoints and/or hubs
"Idaho sucks!!!! Tell California"
jaspepp is offline   Reply With Quote Quick reply to this message
Unread 01-23-2015, 11:23 AM   #9
blysccr
Was going to grab unit bearings and just throw them in- 138k. But never wheeled.
Rock auto 75 plus 10$ shipping.
Napa gold 120 plus tax.
Even though I wanted to get them done this weekend, I can justify the extra $. Guy at Napa said sorry, can't do anything about the price. So I'll still check out the ujoints but have a laundry list of other stuff to do.
Will update when I take a look
Unread 01-23-2015, 01:32 PM   #10
RnEmOvr
RnEmOvr's Avatar
RAs are probably timken? So better brand anyway.
Unread 01-24-2015, 08:54 PM   #11
blysccr
surprisingly the unit bearings showed up today! they were in new york and got them installed along with oem shafts from my old rubi with 6K on the clock. I'm 99% sure the clicking is 100% better. Maybe a faint bit? Not sure too many other sounds going on in there.
However, the u joints and bearings seemed to be in fine shape? Everything was tight and rotated smoothly. When I grabbed the wheels there was no play when grabbing at 12 and 6 or 3 and 9. Not sure why?
Needless to say, it's gone and I thank you guys.
