clicking or crunching sound in the front end - JeepForum.com
post #1 of 19 Old 07-07-2008, 12:49 AM Thread Starter
rubicon1000
ok when i hit a bump just fight or i turn just right or the axle moves up and down i get a like a click or a crunching noise in the frontend.
just woundering could my tie rod or somthing up front wore out.
please help
rubicon1000 is offline
post #2 of 19 Old 07-07-2008, 01:03 AM Thread Starter
rubicon1000
or could it be the drag link
post #3 of 19 Old 07-07-2008, 07:30 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Is it more like a clunk?
Is your suspension stock?
Wheelin98TJ is offline
post #4 of 19 Old 07-07-2008, 11:39 AM Thread Starter
rubicon1000
no i haVE A 2 INCH BB
post #5 of 19 Old 07-07-2008, 11:47 AM
Wheelin98TJ
JEEP FREAK
What about the noise?
Is it more of a clunk? Like a pop?
Or is it a clicking/crunching noise as you described (repititive)?
If its a clunk/pop, look at the sway bar links. If they are stock, they are prone to breaking apart at the top of the link where it connects to the sway bar.
There is a ball joint fitting there that is under a rubber boot. Rock the Jeep back and forth while watching that joint. See if the sway bar link is separating and moving independently of the sway bar.
post #6 of 19 Old 07-07-2008, 08:03 PM
pyrow07
I have the same noise and i was painting my shocks today and saw that it had disconnected there. That is the noise you are propably hearing, do you hear it when you go over a curb turning.
Wheelin do i have to buy the whole end or can i just get the boot?
pyrow07 is offline
post #7 of 19 Old 07-07-2008, 08:07 PM
fire239
Get quick disconnects. The stock links are like 40.00 apiece and will break again.
fire239 is offline
post #8 of 19 Old 07-07-2008, 09:06 PM
pyrow07
well i need them fast unless i can drive at highway speeds like that, when i move the jeep the ball just comes out so is that ok
pyrow07 is offline
post #9 of 19 Old 07-07-2008, 11:19 PM
fire239
You can drive at highway speeds like that. I drove mine for a couple of months before I even found out what the hell the noise was. Highway every day. If they were both broken, it would affect the handling in a body roll type situation, but not to where the jeep would just flop over belly up.
fire239 is offline
post #10 of 19 Old 07-08-2008, 12:12 AM Thread Starter
rubicon1000
yeah first i was just hearing it on the pass side and now its on both it sure was a pita reconnecting the links after the lift maybe i should of gotten like 0-3 inch qds
post #11 of 19 Old 07-08-2008, 12:13 AM Thread Starter
rubicon1000
0-3 inch lift qds
post #12 of 19 Old 07-08-2008, 12:18 AM
kolten493
idk if im talkin about the same noise but sometimes whenever my front end gets flexed pretty good i hear a kinda of "pop" noise. any1 kno what it is?
kolten493 is offline
post #13 of 19 Old 07-08-2008, 07:14 AM
Wheelin98TJ
JEEP FREAK
You have to buy the entire link.
I recommend replacing them with something aftermarket like fire239 suggested.
post #14 of 19 Old 07-08-2008, 08:33 AM
SandboxTJ
If the sound the OP mentioned is actually a clicking/crunching sound as described in the title, couldn't it be the U-Joints in the front axle? I know that's how I would describe the sound of needle bearings self destructing.
Rubicon1000, does the sound get a lot worse when you're in 4WD?
SandboxTJ is offline
post #15 of 19 Old 07-08-2008, 09:36 AM
Wheelin98TJ
JEEP FREAK
Yep, it could be u-joints too.
I'm still trying to figure out what type of noise the OP is describing
I've asked twice now for clarification on the noise, but I'm not getting any help on this.
Clicking Sound in Front Left Hub?? mkuzmukerau TJ Wrangler Technical Forum 11 06-25-2015 09:19 PM
crunching/grinding on a front end of a 2003 tj 04tj918 TJ Wrangler Technical Forum 6 02-11-2010 10:07 PM
Pleas help with "crunching" sound coming from front wheel area Jeeeeeeeeeeeeep YJ Wrangler Technical Forum 9 02-28-2009 08:39 PM
Crunching Sound From Rear Driver's Side Wheel imbezol TJ Wrangler Technical Forum 3 07-30-2007 11:15 PM
Disturbing shutter/crunching type sound on turn from stop NJStriper TJ Wrangler Technical Forum 5 07-10-2007 04:45 PM
