Click when trying to start - JeepForum.com
post #1 of 20 Old 12-18-2011, 09:48 AM Thread Starter
NickM2828
This morning I went out to start the jeep and all it gave me was a single click. All the lights turned on and the radio. I did have to clean and re-tighten my positive battery cable because of a similar issue I was having. My ground and positive wires are both looking pretty rugged so I am thinking that the wires are just not supporting the voltage needed to start the starter. Any other possibilities?
Thanks
Nick
****IF YOU CANT RAM IT, DODGE IT, IF YOU CANT DODGE IT.....GET A JEEP AND RUN OVER IT!!****
NickM2828 is offline
post #2 of 20 Old 12-18-2011, 10:13 AM
alex211
1995 XJ Cherokee
Mine did this once, I crawled under it and tapped the starter with a screwdriver. After that it's been starting fine but I need to get a new starter soon.
95 xj bone stock for now
alex211 is offline
post #3 of 20 Old 12-18-2011, 11:04 AM Thread Starter
NickM2828
I tried to hit it with a canoe paddle Didnt do any difference so im pretty sure the brushes arent sticking...
post #4 of 20 Old 12-18-2011, 11:14 AM
teknics
unless youve got nasty canoe paddle skills, that wouldnt be anywhere as effective as a hammer on the starter.
check battery voltage, ground from batt to block, etc etc.
teknics is offline
post #5 of 20 Old 12-18-2011, 11:44 AM
flying_bosun
Thanks
Nick
I see you have an AX15 trans. It could be the clutch safety, too...
And I agree that a canoe paddle won't have the punch required to free sticky starter brushes.
Originally Posted by Ron Paul
“Liberty is lost through complacency and a subservient mindset. When we accept or even welcome automobile checkpoints, random searches, mandatory identification cards, and paramilitary police in our streets, we have lost a vital part of our American heritage. America was born of protest, revolution, and mistrust of government. Subservient societies neither maintain nor deserve freedom for long.”
― Ron Paul
"Did you exchange your walk-on part in the war for a lead role in a cage?"
flying_bosun is offline
post #6 of 20 Old 12-18-2011, 11:55 AM
getoffmyland
take it apart, quiet easy to do, clean it
the brushes in mine were stuck
getoffmyland is offline
post #7 of 20 Old 12-18-2011, 12:15 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Remove both (!) battery connections and wire brush the battery posts and the inside of the connections until they are bright and shiny. This is one of those things where you can't look at them and pronounce either as 'ok' since the connectors/connections might look ok but not be good enough to allow enough current (amperes) to pass through them to let the starter fully engage.
If that doesn't fix it, charge the battery overnight. If that doesn't do it, have the battery load tested which is the only way to know its true health. Odds are very good the problem is either battery connector or battery related and not a bad starter.
Jerry Bransford is offline
post #8 of 20 Old 12-18-2011, 12:16 PM
biffgnar
biffgnar's Avatar
x2 on cleaning those battery connections till they shine!
biffgnar is offline
post #9 of 20 Old 12-18-2011, 12:19 PM
FL 4.0L
Get a cheap voltmeter and test the battery (after cleaning and tightening all connections). Just changed my battery yesterday with same symptoms.
'97 TJ Sport, 4.0L, AX-15, D30/35, BFG TA KO 183K
'12 F30, '03 E46, '06 Rabbit, '13 Jetta
FL 4.0L is offline
post #10 of 20 Old 12-18-2011, 12:58 PM Thread Starter
NickM2828
I will admit, my canoe paddle beatin skills are probably no match for a hammer! but tomorrow i am going to try to clean off the cables real good and get new terminals cause mine look like hell!
post #11 of 20 Old 12-19-2011, 05:45 AM
Tdog02
Great advice, focus on the simplest fix first. Battery and cables.
it is what it is except when its something else
Tdog02 is offline
post #12 of 20 Old 12-19-2011, 08:07 AM Thread Starter
NickM2828
Hmm, well, I tried replacing the terminals and cleaned the wiring around the terminals until it shined. Still a click. Then I noticed that if I turn the key only half way (one turn before start) and left it there a few seconds, then turned all the way, she'd start right up. Any ideas guys? I only did this 3-4 times so maybe a coincidence but I don't know?
post #13 of 20 Old 12-19-2011, 08:44 AM
teknics
It's definitely just clicking and not cranking, right? If its cranking and not starting unless you leave the key on its prob fuel related. Clicking is usually electrical.
Turn your headlights on before trying to start it and then crank it, see if your headlights dim really low when it clicks.
When I had a bad main ground (from battery to engine block) mine clicked unless I left the key in the on position a few seconds before cranking.
teknics is offline
post #14 of 20 Old 12-19-2011, 09:07 AM
merkchop
Sounds like a bad connection somewhere, dirty or loose ground since you say you cleaned and replaced your battery terminals.
I have come to find out that the 4.0 (at least) engines in the Jeep requires full power to crank. It seems that if the terminals are just the littlest bit corroded they will not crank and just give you a "click". They are much more sensitive than any other vehicle I have ever owned, if you can see any corrosion then it probably won't start.
merkchop is offline
post #15 of 20 Old 12-20-2011, 09:52 AM Thread Starter
NickM2828
OK so now that I have cleaned the battery terminals and given her a bath, I'm getting a single click and then about half a second later she'll start?? Any ideas guys?
Click.... click.... No start WalrusPaul YJ Wrangler Technical Forum 4 11-27-2010 12:21 PM
Engine Click Click Click when trying to start nonnaca TJ Wrangler Technical Forum 3 07-24-2009 01:35 PM
Jeep won't start click, click,found loose wire scojean YJ Wrangler Technical Forum 8 07-06-2009 08:02 PM
Click, Click, no start diehnjeep YJ Wrangler Technical Forum 7 04-19-2007 10:48 AM
Click,Click...won't start. Joe jeep YJ Wrangler Technical Forum 6 01-26-2003 04:28 PM
