Cleaning IAC and Throttle body write up (for dummies) - Page 9 - JeepForum.com
 1Likes
post #121 of 271 Old 08-16-2011, 06:37 AM
mightydog78
1999 wranglers dont have a throttle body gasket correct?
When I took mine apart I didn't see one....just wondering if I should put one on anyways.
2013 JKU Sahara
Charlotte, NC / Southport, NC
Mechanical Engineer
mightydog78 is offline
post #122 of 271 Old 08-22-2011, 07:03 AM
andyaux
The one I took off had one and so did the new one.
andyaux is offline
post #123 of 271 Old 08-24-2011, 06:31 PM
KevKaos
Bookmarked.
KevKaos
Honey Badger Wheelin'
RED JEEP CLUB # 621
It's not much, but check out my build thread;
Originally Posted by krashnpa View Post
I know kev was riding his tank skid and belly pretty good on some of the blacks up at RC, but he doesn't back down from the line either.
so I use my original nuts?
You should, in no way, take any of this personally. It's just business. So to recap, I come in peace, I mean you no harm, and you all will die. Gallaxhar out.
KevKaos is offline
post #124 of 271 Old 08-29-2011, 06:20 PM
teneightbrah
Did this except for fully removing the IAC housing (no security torx bits). Scrubbed the throttle body and used several qtips on the IAC housing. Jeep idles steady and found some get up too. Thanks fishinjeep for the great write up.
teneightbrah is offline
post #125 of 271 Old 09-01-2011, 10:14 AM
talon282
im doing this my next day off mind is giving me fits
http://groups.jeepforum.com/Blue_Jeep_Club member #318 gunmetal pearl
talon282 is offline
post #126 of 271 Old 09-01-2011, 06:45 PM
QCDoc
At some point earlier it was asked how to remove throttle cables with no solution, ima be doin this tomorrow and lOoked at this the other day and thats the only thing i couldnt figure out. Help please
QCDoc is offline
post #127 of 271 Old 09-01-2011, 09:18 PM
talon282
good question i didnt ven think of that guess i need to look at and do some research
talon282 is offline
post #128 of 271 Old 09-01-2011, 09:22 PM
QCDoc
Yeh im off tomorrow and wanna knock it out but thats the only thing i dunno what to do with. Looks like itd just pop off but i dont wanna try and break it haha
QCDoc is offline
post #129 of 271 Old 09-01-2011, 11:12 PM
lope
lope's Avatar
I have an '05 so I'm not sure if yours is different but I just popped the cables off mine.
lope is offline
post #130 of 271 Old 09-04-2011, 04:56 PM
26679cj5
I used this walkthrough today when I cleaned my throttle body. I could t get mine as clean as the pictures, even using a tooth brush and going over everything a few times. I think a polishing bit on a dremmel wouldve been good to use.
26679cj5 is offline
post #131 of 271 Old 09-06-2011, 12:19 AM
Sula
I have 97 TJ 4ltr with about 113k kms, which is about 72k miles. It runs fine but sometimes takes several cranks to start. It seldom starts on the first key and almost always on the second key. New HT coil, distributer cap and rotor and leads fitted about a year ago, and fuel pump and some lines, also about a year ago. This was for severe misfiring and farting and the pump cleared it up. Any advice regarding the starting?
I will take a look at the throttle body and appreciate any other direction that might lead to a cure.
Thanks,
Sula is offline
post #132 of 271 Old 09-06-2011, 12:22 AM
Fusco
2016 JK Wrangler
Thanks,
Starter?
2016 Jeep JK 2D Sport S
2006 Jeep TJ Rubicon Impact Orange - SOLD :-)
Fusco is offline
post #133 of 271 Old 09-06-2011, 12:34 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Thanks,
Slow starts are normally caused by a leaky check valve inside the fuel pump assembly. That problem is so commonly caused by a leaky check valve inside the fuel pump that I wouldn't look beyond that possibility.
Getting
Jerry Bransford is online now
post #134 of 271 Old 09-06-2011, 01:18 PM
Sula
Thanks Jerry, I will take a look. Are these components at the pump/tank end of the lines?
Sula is offline
post #135 of 271 Old 10-02-2011, 09:10 PM
markx64
IAC still acting up
I took my carb off a few months ago and cleaned the IAC valve and it seemed to work better. But then a couple of days later it started acting up again. I have a manual transmissin and when I shift from 2nd to 3rd it seems like it wants to die. It bogs down real bad. It idles fine, I changed the idle control a few months ago. Any way....I replaced the IAC and it still seems to have the same problem. When I am driving, it seems like it is starving for fuel. I know it isnt the fuel filter because I replaced that a few months ago when this first started. Could someone please help?
markx64 is offline
4.0 , cleaning iac , i6 , throttle body
Throttle Body Cleaning? 3.8L '10 JK JeffinWesternWA JK Wrangler Technical Forum 18 02-03-2010 06:13 AM
throttle body cleaning greta TJ Wrangler Technical Forum 9 01-27-2010 02:00 PM
Cleaning Throttle Body LaJeepermln TJ Wrangler Technical Forum 13 04-21-2008 11:27 PM
Cleaning Throttle Body TEXASRAM YJ Wrangler Technical Forum 1 07-27-2004 01:50 PM
Throttle Body Cleaning? Mike611 YJ Wrangler Technical Forum 0 02-19-2002 10:16 AM
