Cleaning IAC and Throttle body write up (for dummies) - Page 7 - JeepForum.com
 1Likes
post #91 of 271 Old 03-22-2011, 02:10 PM
MidTnSahara
thank you for this great write up
MidTnSahara is offline
post #92 of 271 Old 03-23-2011, 07:02 PM
trailinAZ2MI
just got done cleaning! it was a breeze, also found out the PO had put a throttle body spacer thing in... I know they don't help you significantly, but would I be better off leaving it on or taking off?
trailinAZ2MI is offline
post #93 of 271 Old 03-23-2011, 07:36 PM
jpsjp
x2 on the spacer, I have one too and wonder if its better left off?
2004 TJ, 4" lift (Daystar upper and lower; Rubicon express springs and track bars), 35" Goodyear Wrangler Kevlar, 4.88 gears and rear Tracloc locker, 4.0 with intake and throttle body, Transgo shift kit, Front axle is high pinion Dana 30, Rear is Dana 44 w/ Disc brakes, Currie Front Anti-rock sway-bar.
jpsjp is offline
post #94 of 271 Old 03-23-2011, 07:45 PM Thread Starter
fishinjeeper
doesn't really matter whether its left on or not. Does not make any noticeable difference.
01 TJ. 35 inch KM2's. 4.5 RE. 2 inch body lift. dana 44. Detroit Locker. Olive Drab!! all set for trout and bambi!
fishinjeeper is offline
post #95 of 271 Old 03-23-2011, 07:49 PM
justa5o
Great post....looks like may have a sunday project.
justa5o is offline
post #96 of 271 Old 03-29-2011, 01:25 PM
fullbore
Originally Posted by ncunlimited View Post
can anyone tell me how to remove the iac on an 05 lj? I checked my tb and it is shiny and clean don't need to clean that, but want to chcek the iac now. Thanks
fullbore is offline
post #97 of 271 Old 03-29-2011, 08:43 PM
mhcurlee
one torx screw on the 05 and 06 models..... instead of a gasket the new one uses a rubber o-ring. After you remove the torx screw twist the IAC back and forth while gently pulling it out.
mhcurlee is offline
post #98 of 271 Old 04-04-2011, 10:51 AM
pricejt
I just did this clean out this weekend. Seemed to work perfectly. However when i jumped on the highway (i had a 2 hour drive) My jeep was vibrating a lot. It was vibrating the front end not the steering. After an hour into the drive my engine light came on. Went to Auto Zone found out it was my TPS. Would that cause this??
pricejt is offline
post #99 of 271 Old 04-04-2011, 11:01 AM
mhcurlee
I doubt it's coincidence. did you remove the TPS or soak it with cleaner? When I cleaned mine I really only cleaned the throttle body, the butterfly valve, and the air mass sensor. I didn't "clean" the TPS since it is probably just a simple sensor that works off the butterfly valve axis position.
mhcurlee is offline
post #100 of 271 Old 04-04-2011, 04:30 PM
pricejt
I thought i followed the directions and just cleaned what was said to clean. The IAC, throttle body, butterfly valve, and the MAP hose. Don't think i really touched the TPS. I am going to try to take the connector off and reconnect when i get off work. I imagine the check engine light wont go off though i will need to get it cleared.
Buddy of my here at work also suggested i put my jeep in neutral and get my engine up to speed to rule out any possibilities with my wheels.
pricejt is offline
post #101 of 271 Old 04-04-2011, 09:41 PM
PlatinumNiner
Disconnect the battery for 15-20 mins and see what happens. That will reset any codes. Make sure the TPS plug is in all the way and make sure the contacts are clean. Also make sure the 2 screws holding it in are tight. Same for the IAC
PlatinumNiner is offline
post #102 of 271 Old 04-08-2011, 09:57 PM
chrisjsmith4
Originally Posted by WeezyBlue View Post
My 2.4 started stalling occasionally when coming to a stop a few months ago, and this past week has started stumbling when I take off from a stop... I'm going to be optimistic and hope this is all it needs...
Weezy did this help you? Mine started doing this.
chrisjsmith4 is offline
post #103 of 271 Old 04-11-2011, 03:27 PM
MeanMachine
Thanks for the write-up!
Did this yesterday, man it was nasty in there. Definitely idles smoother now...
Question though: I didn't have a paper gasket or any remnants of anything between the throttle body and the manifold. I hadn't had any problems before and haven't noticed any since, should I just leave it? (If it isn't broken, don't fix it).. Or should I track one down? (It is indeed 'broken' without a gasket)
MeanMachine is offline
post #104 of 271 Old 04-13-2011, 08:14 PM
QuickSack
Thank you for the write up, my TB was NASTY, She has 204k miles on her & never been cleaned.
Forgot to clean out the IAC Housing :S I'll do that another day.
idle & acceleration seems to be better
QuickSack is offline
post #105 of 271 Old 04-23-2011, 08:18 AM
Austinb86
If we use a paper TB gasket, does the gasket require any type of gasket sealer?
Austinb86 is offline
4.0 , cleaning iac , i6 , throttle body
Throttle Body Cleaning? 3.8L '10 JK JeffinWesternWA JK Wrangler Technical Forum 18 02-03-2010 06:13 AM
throttle body cleaning greta TJ Wrangler Technical Forum 9 01-27-2010 02:00 PM
Cleaning Throttle Body LaJeepermln TJ Wrangler Technical Forum 13 04-21-2008 11:27 PM
Cleaning Throttle Body TEXASRAM YJ Wrangler Technical Forum 1 07-27-2004 01:50 PM
Throttle Body Cleaning? Mike611 YJ Wrangler Technical Forum 0 02-19-2002 10:16 AM
