Cleaning IAC and Throttle body write up (for dummies) - Page 5 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Cleaning IAC and Throttle body write up (for dummies)
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 02-20-2011, 06:50 AM   #61
PlatinumNiner
Yes same as the 2.5 i just did it on my 5.9 while installing my 52MM throttle body. I gota say it does idle much smoother now.
PlatinumNiner is offline   Reply With Quote
Unread 03-04-2011, 06:11 PM   #62
fstws6
I have a 97 4.0 does this apply the same ?
fstws6 is offline   Reply With Quote
Unread 03-04-2011, 06:17 PM   #63
Winners97TJ
Go Big Or Go Home
Winners97TJ's Avatar
(double post, sorry!)
Gun Control Means Using Both Hands
1997 Jeep TJ - Truly BUILT not BOUGHT! Purchased from original owner stock... obviously THAT didn't last long!
| WJ Seat Swap into a TJ WITH FORWARD TILT!!
Winners97TJ is offline   Reply With Quote
Unread 03-04-2011, 06:18 PM   #64
Winners97TJ
Go Big Or Go Home
(wow! Make that triple post... Thank you iPhone! Sorry)
Unread 03-04-2011, 06:18 PM   #65
Winners97TJ
Go Big Or Go Home
Yes it does. Verbatim.
Sent from my iPhone using JeepForum - Gotta love it!
Unread 03-04-2011, 06:36 PM   #66
fstws6
Thanks ! x 3
Unread 03-06-2011, 10:15 AM   #67
fstws6
I bought a new gasket for the throttle body but what about the IAC does it take a gasket ? I have a tube of 100% pure silicon it is a multi purpose tube, is this ok to use if no gasket is required for the IAC.
Unread 03-06-2011, 11:55 AM   #68
Winners97TJ
Go Big Or Go Home
I don't believe it requires one. I don't think mine had one, nor did I put anything on it when I cleaned mine or when I replaced my TB. Anyone else shine some light on this that may be a little more "exact" than just an "I don't think so?"
Unread 03-06-2011, 12:05 PM   #69
fstws6
Well Im getting ready to tear into it so I will know soon enough.
Unread 03-06-2011, 01:18 PM   #70
fstws6
Ok I have all the connectors off the sensors and the bolts out of the throtttle body. How do the throttle cables come off, I dont want to damage them getting them off.
Unread 03-06-2011, 01:52 PM   #71
fstws6
got it
Unread 03-06-2011, 02:19 PM   #72
fstws6
Ok how does the IAC body come off the throttle body housing. Those screws are nothing like I have ever seen. I got the valve out and cleaned it already but the housing has some odd screws holding it on. If I cant get it off I will just spray it to death on the throttle body.
Unread 03-06-2011, 02:22 PM   #73
CTJeepWJ
2010 JK Wrangler
thanks for the write up and pics, I will have to do this on my TJ and WJ.
-Ed
BLACK JEEP SOCIETY
www.facebook.com/BlackJeepSociety
2010 JK & 2004 WJ
CTJeepWJ is offline   Reply With Quote
Unread 03-06-2011, 03:49 PM   #74
Winners97TJ
Go Big Or Go Home
If I'm not mistaken, they are a t-20 safety bit. You can buy a set if those at autozone for about $10.
Unread 03-07-2011, 10:43 PM   #75
fishinjeeper
There is supposed to be a gasket between the throttle body and the upper intake. Its nothing more then a seal so air does not escape/come in and through off your air fuel mix. You can use silicon which is what I did, but there should be some sort of seal there. good luck
[CENTER]01 TJ. 35 inch KM2's. 4.5 RE. 2 inch body lift. dana 44. Detroit Locker. Olive Drab!! all set for trout and bambi![/CENTER]
fishinjeeper is offline   Reply With Quote
4.0 , cleaning iac , i6 , throttle body
