> Models
> Jeep Wrangler Forums
> TJ Wrangler Technical Forum
Cleaning IAC and Throttle body write up (for dummies)
12-01-2010, 03:46 PM
#46
Question:
I was just cleaning this on my 2000XJ and broke the gasket on the IAC body. I made a new one from gasket material, but where can I buy an actual one??
Thanks
1999 TJ
2010 Mustang
1964 Ford Fairlane 500
12-01-2010, 07:46 PM
#47
Go Big Or Go Home
Originally Posted by oakmckinley
Question:
Thanks
I would assume the dealer would be able to at least order one for you. It shouldn't be but about a few bucks... theoretically.
12-09-2010, 11:42 AM
#48
napa should sell them. I just made mine out of silicon.
[CENTER]01 TJ. 35 inch KM2's. 4.5 RE. 2 inch body lift. dana 44. Detroit Locker. Olive Drab!! all set for trout and bambi![/CENTER]
12-09-2010, 02:36 PM
#49
Is this the same on the 2.5?
12-11-2010, 07:52 PM
#50
bump to the front page
12-27-2010, 05:50 PM
#51
how does the throttle cable come off...should it just pop off or what?
12-28-2010, 11:49 AM
#52
Rough Idle
Thanks for the great detail. I have an 88 XJ with rough idle in gear and it likes to stall at stop lights, going to do a good cleaning this weekend.
12-28-2010, 10:29 PM
#53
Is it carb or FI? My old carbed YJ had the same stop light problem, google search found a good write up on how to do a quick clean by pulling the venturi cluster and that solved the problem.
12-29-2010, 04:11 PM
#54
88 XJ has a 4.0 and is fuel injected. 1987+ was injected.
12-29-2010, 05:43 PM
#55
Thanks for clearing that up for me. I guess my YJ was just a little behind the curve w/ the old carbed 4.2.
12-29-2010, 07:09 PM
#56
I know you can use rtv for the IAC housing, but do you need to use rtv when you re-mount the TB?
ps. great write up thanx
People sleep peacably in bed at night only because rough men stand ready to do violence on thier behalf. ΜΟΛΩΝ ΛΑΒΕ
12-29-2010, 07:22 PM
#57
Yea the YJ was a little behind but the 4.2 was a great motor either way. You dont use RTV between the TB and manifold. Get the TB gasket from your local parts store. Costs only 3-4 bucks.
12-30-2010, 06:34 AM
#58
My 2.4 started stalling occasionally when coming to a stop a few months ago, and this past week has started stumbling when I take off from a stop... I'm going to be optimistic and hope this is all it needs...
CURRENT: '05 Rubicon, 2-3" Skyjacker lift, 32x10.5 BFG A/Ts.
SOLD! '06 TJ, 2.4L + NSG370, 3.25" RC, 1" Currie BL, 1" JKS MML, 33x12.5" Federal Couragia M/T on 15x8 Soft 8s
12-30-2010, 07:03 PM
#59
When did it get its last tune up? This is not a fix for everything but doesnt hurt to do.
02-19-2011, 08:06 PM
#60
Same thing for 2.5L correct? If so I'll be doing this same day as the spark plugs, wires, dist. cap, Gum out, etc...
