Cleaning IAC and Throttle body write up (for dummies) - Page 16 - JeepForum.com
 1Likes
post #226 of 272 Old 09-23-2013, 09:10 AM
Ajcobosco
Originally Posted by Knuckelhead
No, it's an air valve controlled by the PCM to maintain proper idle rpm...
Interesting and cleaning this will help smooth the idle? Mine sounds like it's got a jumpy idle but the tac doesn't move much. Also the 4.0s do not have a mass flow air sensor does it?
Ajcobosco is offline
post #227 of 272 Old 09-23-2013, 01:11 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
It might.
Nope, it has a MAP sensor: http://www.jeepforum.com/forum/f9/ma...ensor-1063614/
Knuckelhead is offline
post #228 of 272 Old 09-23-2013, 05:05 PM
Ajcobosco
Thanks ill be trying to do this tomorrow now.
post #229 of 272 Old 09-23-2013, 05:33 PM
Knuckelhead
AFSOC Retired
You're welcome and post back as to how it goes...
post #230 of 272 Old 09-23-2013, 05:45 PM
Ajcobosco
I'll take pictures as I go threw it as well.
post #231 of 272 Old 09-24-2013, 03:37 PM
Ajcobosco
I'm still waiting for the call that my gasket came in. They said it would only take a couple of hours to get.
post #232 of 272 Old 09-28-2013, 02:47 PM
Ajcobosco
Well I finally got the time. I didn't notice a huge difference in the idle but it wasn't to bad either.
Before
After
post #233 of 272 Old 10-02-2013, 11:41 AM
Ajcobosco
Well I did get 24.64 mpg when I drove in the mountains and back. 240 some miles that day
post #234 of 272 Old 10-14-2013, 11:35 AM
Ajcobosco
The next one I got 17.8 for city driving
post #235 of 272 Old 12-09-2013, 12:03 PM
djtjdxb1998
Good evening all. I've been having light throttle jerkiness on my 98 manual 4.0 TJ (170,000 km), no problem with full throttle.
This jerking was driving me nuts. Noticed slight crack in dizzy cap, so changed that + rotor arm, HT leads, plugs, coil.
Still the problem remained..
I went to the dealer (not to get my pockets picked LOL..) to see if they could check the diagnostics as had been having intermittent 'check engine' light. No codes. Mechanic says maybe the IACV needs replacing but no stock & not really sure without fault codes.., so start with changing that & if no better do the same with the TPS. (pocket emptying dealer mode..).
Didn't change anything, just parked it up as only use it in the desert once or twice a month. Next drive (a week later), no jerkiness, problem 'solved', but as I didn't know what had been wrong before.., was concerned if it happened again how to diagnose..
Now that moment has come again..., I've read all of this excellent thread & plan to attack the TB, TPS, IACV etc with TB cleaner as it seems the problem is rooted there..
I also wondered if a dirty injector or two had somehow 'coughed' & cleared their throats, but this thread seems to point to the TB & associated sensors..
I removed the TB the other day but hadn't read this thread at that point & the inside of the TB didn't seem dirty. However I did note the inside of the intake manifold below the TB was heavily carboned..., what is best to clean that & should it make much difference?
When cleaning the TB, does it help to use any metal polish on the TB throat after/before using TB cleaner?
Is everyone using WD40 or similar on the sensor electrical connections?
Any other advice appreciated as driving on soft sand with a needed light right foot at times is damn tricky with jerky power delivery!!
Thanks in advance! :-)
djtjdxb1998 is offline
post #236 of 272 Old 12-12-2013, 02:18 AM
djtjdxb1998
Update.
I have changed the TB with a used one & all now is good! Havn't found any TB cleaner so that seemed worth trying!
post #237 of 272 Old 04-01-2014, 02:35 PM
dmb2002man
hey everyone. Im trying to clean my tb and having issues getting the sensors to pull off. Is there a trick to do it. Im pushing the connector in with my finger and there not pulling off.
dmb2002man is offline
post #238 of 272 Old 04-01-2014, 02:38 PM
wwch99tj
Push the plug in slightly then pres the clip and pull...
Sent from my Samsung Galaxy S3 using JeepForum
wwch99tj is offline
post #239 of 272 Old 04-01-2014, 02:58 PM
dmb2002man
This is the one im talking about.
post #240 of 272 Old 04-02-2014, 02:21 PM
dmb2002man
On my 2006 tj 4.0, can I just unscrew the 1 screw on the map sensor and then remove the rubber hose? I also see throttle position sensor has 2 screws which is on the back side facing the firewall on the tb. Can i also just remove those screws and pop it off. thanks
4.0 , cleaning iac , i6 , throttle body
tnkayaker615
Throttle Body Cleaning? 3.8L '10 JK JeffinWesternWA JK Wrangler Technical Forum 18 02-03-2010 05:13 AM
throttle body cleaning greta TJ Wrangler Technical Forum 9 01-27-2010 01:00 PM
Cleaning Throttle Body LaJeepermln TJ Wrangler Technical Forum 13 04-21-2008 10:27 PM
Cleaning Throttle Body TEXASRAM YJ Wrangler Technical Forum 1 07-27-2004 12:50 PM
Throttle Body Cleaning? Mike611 YJ Wrangler Technical Forum 0 02-19-2002 09:16 AM
