Cleaning IAC and Throttle body write up (for dummies) - Page 15 - JeepForum.com
 1Likes
post #211 of 272 Old 04-25-2013, 12:45 AM
SKINUM
Originally Posted by atty
Skinum,
Sounds exactly like my original problem. I cleaned the throttle body along with the pintel on the IAC, which temporarily cured the problem, but returned within a 100 miles. A new IAC did the trick.
I'm sorry, that today, a large part of troubleshooting is tossing logic out of the window, and start grabbing for new parts. For the record, I also tried a new TPS with no change, so I knew it had to be the IAC. Even though, I had cleaned the old one and got an immediate correction, "logic" told me the original one was bad. So far, I was right, and that was about 10K miles ago.
Cleaned the IAC & changed the o2 sensors to NGK's. Reset the PCM but it still seems to idle a little odd when in park or sitting still. The rpms only vary slightly but I can hear the engine idle change more then the rpm needle moves. The engine will miss once on occasion & then everything seems good again. On initial crank the rpm's are jumping to about 1250 now & settles as soon as I go into gear.
I'm hoping that the computer just needs to adjust to the o2 sensors & a clean IAC.
SKINUM is offline
post #212 of 272 Old 04-25-2013, 11:17 AM
Aristotle113
I hate to be the bearer of bad news, but that's similar to what mine was doing and my computer had to be replaced.
Aristotle113 is offline
post #213 of 272 Old 04-25-2013, 11:42 AM
SKINUM
I hope not but it seems like every other day I am replacing a sensor.
SKINUM is offline
post #214 of 272 Old 04-27-2013, 10:25 AM
esad_b
Just removed the air box stuff in order to check my CPS sensor. After removing that i thought of the throttle body and whether I should clean it or not.
What's your guy's thoughts on this? Seems like people are having issues after cleaning them? Can it be cleaned with it still being bolted to the jeep?
Here is some pictures of the throttle body, 97TJ with 215,000 KM's on it.
esad_b is offline
post #215 of 272 Old 04-27-2013, 11:16 AM
JBTJ
Holy cow, is there even a air filter installed? THat needs to be removed and cleaned for sure.
JBTJ is offline
post #216 of 272 Old 04-27-2013, 11:17 AM
esad_b
Lmao! On the way to the parts store to get throttle cleaner as we speak
Sent from the I-device using an APP
esad_b is offline
post #217 of 272 Old 04-27-2013, 11:23 AM
JBTJ
I would take it off to clean it. I would not want to wash all that crap down inside the intake.
JBTJ is offline
post #218 of 272 Old 04-27-2013, 02:20 PM
esad_b
Yea good call man! Deff going to tomorrow.
esad_b is offline
post #219 of 272 Old 04-27-2013, 07:08 PM
FarmerinVA
Geez, was a pigeon nesting in your air box?
I'm only half joking. I had similar results and I found a chipmunk nest in mine.
Needless to say, I responded with my least expensive and most effective mod ever.
My do-it-yourself install thread for a TrueTrac in the rear, upgraded shafts, and a PowerTrax No-Slip in the front:
FarmerinVA is offline
post #220 of 272 Old 04-28-2013, 02:16 PM
esad_b
LOL! Well took cleaned the throttle body today, along with the IAC. The IAC was really dirty looking forward to see how the Jeep runs now just have to wait until the CKP sensor shows up..
esad_b is offline
post #221 of 272 Old 06-17-2013, 03:59 PM Thread Starter
fishinjeeper
did you have a squirrel living under your hood?
01 TJ. 35 inch KM2's. 4.5 RE. 2 inch body lift. dana 44. Detroit Locker. Olive Drab!! all set for trout and bambi!
fishinjeeper is offline
post #222 of 272 Old 06-17-2013, 04:01 PM
esad_b
Nah it was a moose, since I'm in Canada.
But the Jeep purs now, this made a huge difference.
esad_b is offline
post #223 of 272 Old 09-12-2013, 03:12 AM
vrsoft
I did this on my '93 YJ this evening. Took me a couple of hours to finish (5min to pull the throttle off and 1hr 55m to clean).
I didn't snap a before picture, but I recently discovered that my rear valve cover CCV hose was 100% clogged... which is why I was getting oil in my air filter, and which is also why my throttle was ENTIRELY coated in a thick, baked, black film. Every crevice and surface... it was all coated.
About 30 q-tips, 2 large rags, half a can of Seafoam Deep Creep, a couple of very sore fingers, and everything cleaned up nicely.
I have one piece of advice. Since I had never done this before, I wasn't sure what to look for. I noticed that the pintle area of the IAC (even after I thought I had cleaned it well enough) felt bumpy as I ran my finger around it. Since it's a hard smooth material, I thought it was kind of odd. When I was nearly done with the entire cleanup on the throttle, I checked the IAC again... and I'm glad I did, because it had a layer of caked black crap on it that I couldn't see very well. Most of it came off with my initial clean, but not all. I got a paper towel and used my finger nail to scrape the grud off, and now the pintle area is perfectly smooth.
I'm super happy with the result. Thank you for this great thread, and everyone who has offered follow-up advice along the way.
1993 YJ 4.0L
1999 XJ 4.0L (Going up for sale very soon)
2007 XK 5.7L
vrsoft is offline
post #224 of 272 Old 09-22-2013, 10:28 PM
Ajcobosco
IAC- is this like the mass air flow sensor?
Ajcobosco is offline
post #225 of 272 Old 09-22-2013, 10:33 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
No, it's an air valve controlled by the PCM to maintain proper idle rpm...
Knuckelhead is offline
4.0 , cleaning iac , i6 , throttle body
Throttle Body Cleaning? 3.8L '10 JK JeffinWesternWA JK Wrangler Technical Forum 18 02-03-2010 05:13 AM
throttle body cleaning greta TJ Wrangler Technical Forum 9 01-27-2010 01:00 PM
Cleaning Throttle Body LaJeepermln TJ Wrangler Technical Forum 13 04-21-2008 10:27 PM
Cleaning Throttle Body TEXASRAM YJ Wrangler Technical Forum 1 07-27-2004 12:50 PM
Throttle Body Cleaning? Mike611 YJ Wrangler Technical Forum 0 02-19-2002 09:16 AM
