12-13-2011, 09:25 PM
#151
  my type idles poorly when its cold a d cuts in and out do you think this would help
12-13-2011, 10:48 PM
#152
tj * my phone thinks it knows better than me lol sorry
12-13-2011, 10:53 PM
#153
brilliant. write up!
12-14-2011, 04:20 AM
#154
I did this procedure and my rough running problems went away, for awhile. I'm assuming it was the fact I had cleared the computer by removing battery during this procedure. A few weeks later my problems returned and I traced it down to a cam position sensor and either a short or loose connection int he wiring harness. I have been good for about 2 weeks now but I do know this procedure was long overdue and helped in my process of elimination in troubleshooting my issues.
12-19-2011, 09:17 AM
#155
Thank you for the helpful images my unit was way overdue at 144k, it took a toothbrush and a lot of cleaning fluid to remove all of the gummy oily residue it now looks like new and idles great your help is appreciated..
12-26-2011, 05:37 PM
#156
wouldn't hurt, you might have an O2 sensor problem though....
[CENTER]01 TJ. 35 inch KM2's. 4.5 RE. 2 inch body lift. dana 44. Detroit Locker. Olive Drab!! all set for trout and bambi![/CENTER]
01-26-2012, 06:49 PM
#157
Awesome thread! Thank you very much!
01-28-2012, 12:57 PM
#158
Just cleaned my AIC.Now I have a higher idle. Went from about 700 to about 1900.WTF???When I took off the sensor, the head of the push pin was not connected with the spring.Is that a problem??
As of yesterday only thowing 2 codes-P0301/missfire in cylinder 1, and code P0455-Large leak in EVAP(new gascap installed)
01-28-2012, 04:31 PM
#159
Jeep Forum is so good, I didnt even need a responce!!!!!
Like I said, the head to the "push pin" on the IAC fell off. I took off the throttle body and it was inside the IAC housing.Cleaned the balls out of the throttle body, screwed the little bad boy back in, slapped it on and WAHLAA!!! Smooth idle below 500rpms. Im hoping that will last after I take it for a test.
Thank you jeep forum. I love You.
01-29-2012, 10:31 PM
#160
***500 is wrong, must be dreaming. It was idling fine, just under 1K on the way to work but started acting up again on the way home.F*@%#! New IAC??Oh well, this thread IS for dummies.
02-03-2012, 05:41 AM
#161
Search button FTW!!!!
Thanks!
/l ,[___],
l--L --OlllllO-
()_) ()_)-o-)_)
05-04-2012, 09:44 AM
#162
subscribed - and great write-up.
Can anyone tell me how many and which gaskets are needed? Can they be found at any autoparts store?
TIA
05-15-2012, 10:22 AM
#163
thanks.
2001 TJ 4.0 auto
05-15-2012, 10:30 AM
#164
TIA
I just did mine yesterday. On my 05, the only gasket I needed to replace was the main base gasket. There were no other gaskets on my TB.
I have a spacer on my mine so I needed 2. I got them from Autozone for $1.99 a piece.
2005 Unlimited Rubicon, Sahara Edition #556, Colorado Jeep Club Member #556
Rusty, if you are reading this, I am still waiting for my $249 refund from 06/2010. Pm me for my address to send the check. Thanks!
05-15-2012, 11:56 AM
#165
Hey thanks for the info! I hadn't quite got to this yet but hoping to this weekend. Mine has a spacer as well, I am thinking about removing it.
