-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   Cleaning IAC and Throttle body write up (for dummies) (http://www.jeepforum.com/forum/f9/cleaning-iac-throttle-body-write-up-dummies-1114849/)
fishinjeeper 10-13-2010 03:32 PM
Here was my problem. My jeep would occasionally cut out while driving. At times it would not start for about ten minutes. So looking things up I figured I would replace my IAC, TPS, and MAP sensors. Turns out my IAC just needed to be cleaned. so there it goes.
This is your Throttle body. First you will need to disconnect your Air Intake Hose which is held together by a hose clamp (straight head screw driver).
[Edit by Jerry Bransford: It is not required to remove the throttle body in order to remove and clean the IAC (Idle Air Controller).]
http://i198.photobucket.com/albums/a...c/IMG_2395.jpg
Then there are four bolts, which are 10 MM, you will need to remove those.
http://i198.photobucket.com/albums/a..._2396-Copy.jpg
After you remove those four bolts, disconnect your TPS, MAP, IAC, and throttle cables.
http://i198.photobucket.com/albums/a...c/IMG_2396.jpg
After you disconnect those, your throttle body will come off. Take your throttle body cleaner and clean as much of the gunk off as possible. Use a cloth rag and tooth brush. sorry, could not get a in action picture. I also used zip ties to hold open the throttle body.
http://i198.photobucket.com/albums/a..._2399-Copy.jpg
http://i198.photobucket.com/albums/a...c/IMG_2401.jpg
Then take off your IAC Sensor, not housing. Clean it with your throttle body cleaner, this is what it will look like after. Before and after pictures
http://i198.photobucket.com/albums/a...c/IMG_2404.jpg
http://i198.photobucket.com/albums/a...c/IMG_2409.jpg
Then take off the IAC housing and both sides (house and throttle body). clean that too. before and after...
http://i198.photobucket.com/albums/a...c/IMG_2413.jpg
http://i198.photobucket.com/albums/a...c/IMG_2421.jpg
http://i198.photobucket.com/albums/a...c/IMG_2416.jpg
After that, take off your MAP, the only thing to clean is the beather hose.
http://i198.photobucket.com/albums/a...c/IMG_2424.jpg
with new gaskets, or silicon, reverse the above and put back together
SpaceWrangler 10-13-2010 03:57 PM
Bookmarked for future reference. Well done, sir.
fishinjeeper 10-13-2010 04:09 PM
thanks
fishinjeeper 10-13-2010 04:22 PM
o, and this only took about an hour and a half to do for someone that didnt know what they were doing
del_TJ 10-13-2010 04:23 PM
nice write-up!
Ryman12 10-13-2010 07:41 PM
Very good job. When first starting out I think the hardest things to do were the simple jobs, just because everyone assumed that you knew how to do them already!
fishinjeeper 10-13-2010 09:37 PM
exactly
billabong266 10-15-2010 11:42 AM
This write up is great. How often should i clean my throttle body and IAC? I have 33,000 miles on my jeep now and it has never been done. Do you think it would be dirty enough to clean at 33,000 or should i wait longer?
keithert 10-15-2010 12:38 PM
I sometimes get a stumble at idle. Does cleaning this sound like it would help? How did yours run differently after you were done?
Hendrix 10-15-2010 08:32 PM
I have been putting this off for weeks. Who knew it was just that easy.
Voltekker 10-17-2010 04:33 PM
I need to do this
keithert 10-19-2010 07:30 AM
I wiped down the mouth of the throttle opening. There was a light greasy buildup there. I then used Seafoam's intake cleaner that you spray into the intake while the engine is running for 3 minutes. My gas mileage does seem to be up by 1 or 2 mpg. I religiously track my gas mileage so I would know if it was getting better. My question is why does having a little buildup of gunk in the intake affect the gas mileage?
SilverBullit22 10-19-2010 07:35 AM
Great write-up! I was having some idle issues earlier this spring and after cleaning out the throttle body and sensor I was good to go. I remember the throttle body being a huge PITA to keep open during cleaning, so I'll for sure have to use the zip tie method next time! Thanks again for the write-up!
jforse 10-19-2010 09:41 AM
Great post!
scottbr 10-19-2010 09:51 AM
Good post. I'd add to be careful with the IAC housing gasket unless you are making one or have a spare (they are a pain to fabricate from gasket stock). It cracks easily.
Also to have a VERY clean surface on which to work.
Lastly, USE EYE PROTECTION. Throttle body cleaner is some nasty crap to get in your eyes.
The time now is 03:21 AM.
