Quantcast clanking sound under the jeep - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > clanking sound under the jeep
Old 03-16-2004, 11:07 AM   #1
rajincajingt
any help would be appreciated,
shifting in and outa gear is fine but engaging the clutch is hairy. if i feather it gently nothing happens. but if i pop the clutch, or engage it harder than normal, there is a single clanking sound. not really a bang or a grind, just a bump, i just put a lift on like 2000 miles ago, and i have not touched it...
thanks for the help,
matthew
83 cj new 350 465 205 clocked flat with 32 spline outputs... d44-5.13s BTF cover USA Alloys, Yukon superjoints, aussie locker. d70-5.13s BTF cover lincoln locked. 38.5" super swamper sx in front and boggers rear h1 double beadlocks with copperhead fab rock rings and Stawzworks HDPE inserts. custom roll cage with bottle openers/warn hs9500i/custom bumpers, skid, crossmembers. 103" wb and plenty of dents
[url]http://www.smjc.net/[/url]
rajincajingt is offline   Reply With Quote
Old 03-16-2004, 11:38 AM   #2
Upstate Chili
matthew
I had a similar noise, it was the tailpipe hitting the gas tank skid. If so just bend the hanger.
Upstate Chili is offline   Reply With Quote
Old 03-16-2004, 02:58 PM   #3
doorocks
I agree with Chili, the lift did draw your exhaust closer to the tank......the engine torquing is causing the exhaust to hit the frame or tank...........bend the hanger just to be sure.
Steve
[B][COLOR=Black]LIFE IS TOUGH ENOUGH ALREADY, IT'S EVEN TOUGHER WHEN YOU'RE STUPID.[/COLOR][/B]
RE 3.5 and all kinds of other relevant goodies, you know winch and stuff.
[COLOR=Red][B]Life is like walking into the No Chance Bar full of Future Darwin Stories........[/B][/COLOR]
More mods than a hillbilly's set of teeth..
doorocks is offline   Reply With Quote
Old 03-16-2004, 03:10 PM   #4
macb
I had a similar noise, it was the tailpipe. the shock mounts can also cause this type of noise, as can the tranny mount. Also double check all your bolts etc...retighten everything. buddy had a similar sound only when braking hard...found 2 loose control arm bolts. there are a lot of bolts under the jeep - make it a habit to check them every oil change and you will be able to find small problems and fix them before they become big problems. I usually do an 'under the frame' inspection after each offroading trip.
3.5" Terraflex, 1" BL, Flat Belly Pan, Currie Steering, 35s, Cowl Intake, blah blah blah: [URL]http://www.sajeeps.com[/URL]
[url=http://www.cafepress.com/H2RT]No Bling - H2 Recovery Gear[/url]
Bob Supplee:supplee@ionet.net or (405) 799-8977
Stu Olson's great jeep resource site: [url=http://www.stu-offroad.com]www.stu-offroad.com[/url]
macb is offline   Reply With Quote
Glock Forum
