CJ tailgate swap, Anyone have a writeup????? - JeepForum.com
post #1 of 12 Old 03-16-2006, 07:19 PM Thread Starter
Nickb1907
Nickb1907's Avatar
Looking for a write-up for this...the CJ tailgate
Nickb1907 is offline
post #2 of 12 Old 03-16-2006, 07:44 PM
UCTJ
UCTJ's Avatar
There is one at www.texasjeepcorps.org one of the guys in the club did this swap on his YJ.
UCTJ is offline
post #3 of 12 Old 03-16-2006, 07:52 PM Thread Starter
Nickb1907
Nickb1907's Avatar
if you could give me a direct link that would help, tried searching came up with nothin.
post #4 of 12 Old 03-16-2006, 08:02 PM
UCTJ
UCTJ's Avatar
YJ to CJ tail gate install
First of all I have a '93 YJ and I was rear ended in a parking lot at Home Depot and that is where the idea first came about. I got the
idea from always wishing my stock tailgate was like a truck. And my buddy offered me a CJ7 tailgate to replace the one that was damaged.
When you get your new tailgate there are several things you will want to try to make sure that you have (will make life easier later on).
1. the turn latches
2. cables and bolts along with spring washers (trust me when you see them you will know what I am talking about)
3. hinges, (make note of which way is top and bottom, will help with lining them up in the future)
First thing to do is to remove the stock tailgate. There are the 4 bolts that mount to the Passenger side of the tub. If you have
problems with the bolts not turning or the torx heads being damaged, take a 3/8th drill bit and drill of the head of the bolt and once
the hinges are removed you can then take the entire tailgate assembly off. Now to the bracketry for the tailgate.( since this is actually
in the tub you can leave this if you wish. There are a few bolts inside the Bed area of the Jeep and there is the bracket on top of the
fender. Of course now there is also the latching mechanism on the driver side now to deal with, it is pretty self explanatory. There are
several small torx screws to be removed and then there you go. One tailgate less YJ. Now to line up the new tailgate, you do have one right.
Once you have it set into place mark where to drill for your hinge bolts
Now as you can tell in when I did the install I had a 3in body lift and I still had to remove the last 2 sets of body mounting bolts and
lift up on the rear of the Jeep to reach in and get the new bolts through.
I considered putting the bolts in the same directions as the OEM bolts but it was hard enough getting the bolts and washer through the hole
and get the washers lock washers and nuts on the bolts. I use the largest washers I could get at Lowe's (don't like Home Depot any more)
In order to insure that there will not be any pull through. Also, make sure you put the rounded side of the washer against the tub or the
sharp edge will cut a hole in the tub in later on in the future.
Now to discuss mounting of the cables, here is what I did. I picked this location because it allows for the cable to have plenty of sag
room and put the tailgate level when let down all the way.
For latching, I was not able to find any stock CJ latching locations so I improvised. I took a small L bracket and then bent the end over to
allow secure latching
It was in the mod section on the second page towards the bottom....were you not able to get the actual www.texasjeepcorps.org page to open? Make sure you type .org not .com HTH.
UCTJ is offline
post #5 of 12 Old 03-17-2006, 12:35 AM
orangetj05
orangetj05's Avatar
heres the link to it with pictures http://www.texasjeepcorps.org/module...rder=0&thold=0
2005 TJ 5.7 HEMI, Caged, Locked, Long armed, Stretched, Air shocked, Cromoed, Running 37 Irocks
orangetj05 is offline
post #6 of 12 Old 03-17-2006, 12:41 AM Thread Starter
Nickb1907
Nickb1907's Avatar
wasnt familiar with the website so didnt really know where to look. found it thanks
if there are anymore write ups that anyone know of please post links. A TJ writeup maybe
post #7 of 12 Old 03-17-2006, 12:45 AM Thread Starter
Nickb1907
Nickb1907's Avatar
i have also never owned a CJ, so how do they open up that tailgate? is there a handle somewhere? This mod might just only work with a softop.
post #8 of 12 Old 03-17-2006, 08:51 PM
iismet
I am just completing this mod. Quadratec will get you a long way there.
22504 91 TAILGATE PIVOT LATCH ASSY 76-86 CJ 30666 69.99
Chrysler could come up with little.
You still need hinges, gasket, (Quadratec or Chrysler) and some fabrication. I built nut plates larger than the hinge flange for attaching the hinges to the lower panel on the tub. I dropped the gas tank and used a hole saw just bigger than the nut plate height and chopped an access hole in the inside lower cavity wall. This allowed us to slide the nut plates into the cavity to attach the hinges.
I looked at alot of pictures of CJ's for the attachment of the cables to the tub. The rear wells have morphed over the years. I tried to go to the fender well but the angle of the cables was not steep enough to adeqately put the hinge tub bolts in shear when a load was put on the gate. The tub took too much load and flexed inward.
To correct this we modified the stock TJ gate closure bracket bolted to the drivers side fender well. I removed the closure pin and had a nut welded on the back of the bracket then reinstalled the bracket in the factory location. I purchased another bracket from Chrysler and hacked it up to match the location of the driver side relative to the taligate. We built nut plates for that bracket and installed them thru the tail light hole in the tub.
In the pictures below notice the small steel blocks attached to the tub walls above the brackets. This is what the latch, latches against and do not come from Q. These would be best if done in stainless.
Paint, decals, and stainless latch blocks left to go.
iismet is offline
post #9 of 12 Old 03-17-2006, 09:23 PM
NakedJeeper
NakedJeeper's Avatar
More:
http://www.jeepshots.com/tech/tailgate.html
http://www.inajeep.com/cjbuildup/mybuildup8.php
NakedJeeper is offline
post #10 of 12 Old 03-18-2006, 12:37 AM Thread Starter
Nickb1907
Nickb1907's Avatar
wow these help alot, thanks
post #11 of 12 Old 03-11-2007, 06:48 PM
Erik T.
Erik T.'s Avatar
Pity a hardtop doesn't work, and a soft top is such a pain in the arse.
Maybe one day someone will start fabbing a drop down tailgate that will work with TJ tops. I'd buy one.
-Erik.
Hack work? :rofl: You just described half the modified jeeps on this board.
Erik T. is offline
post #12 of 12 Old 03-11-2007, 06:49 PM
Erik T.
Erik T.'s Avatar
Aw ****.
Had to threads open on this and posted in the wrong one.
Enjoy the bump.
-Erik.
Erik T. is offline
4.2L to 4.6L Golen Stroker Swap Writeup GroundClearance YJ Wrangler Technical Forum 7 05-23-2011 11:32 AM
Seat Swap!!!...Writeup w/ pics!! mxracer513 YJ Wrangler Technical Forum 39 06-19-2010 09:11 PM
TBI injected 318 swap prepration and future writeup 73Dart YJ Wrangler Technical Forum 14 01-23-2010 08:42 PM
TJ Bumper Swap Writeup Ares YJ Wrangler Technical Forum 5 07-13-2007 07:57 PM
Need a D44 Front Axle Swap Writeup sevise TJ Wrangler Technical Forum 14 11-13-2006 10:21 PM
