Chrysler is paying to install a new cam (2005/2006 owners should read this) - Page 91 - JeepForum.com
post #1351 of 1825 Old 12-22-2010, 07:37 AM
OldenEagle
Originally Posted by willydigger View Post
Only go to the dealer if there will completely cover (no cost) the replacement OPDA, installation, and replacement of the camshaft. Otherwise you will spend $100 on the copay, not get the old OPDA back, and will still be left with the old camshaft. I assume you are the first owner and potentially are still under warranty.
dodge-wholesale.com has the part you need. Pages 60-current will have all the information regarding ZDDP, modification, installation, grease, pics, part numbers, tools, etc.
Welcome to the club. It's not as bad as you probably think, but get it fixed ASAP. Replacing the OPDA with a new one is something you can do yourself in 20-30 minutes.
Thanks for the info. I was on dodge wholesale and found the new OPDA using the part # off my original one for $50 less than dealer price + shipping. I did not find the info on the ZDDP, mods, install etc. I'll keep looking.
Any tips on checking the cam for possible damage from the worn pump drive gear before putting in the new pump drive? After I inspected my pump drive and reassembled it until I can get parts, I thought of holding my digital camera down there and trying to snap a shot of the cam thru the opening for the pump drive.
OldenEagle is offline
post #1352 of 1825 Old 12-22-2010, 08:15 AM
JBWood05TJ
Cut to Fit-Paint to Match
JBWood05TJ's Avatar
Shine a light down the the hole that the OPDA mounts in, sort of angled down in the direction of the front of the vehicle and you will be able to see the gear on the cam. Some of the guys have been able to get good pics of it but I didn't even try, as I could see that it was in good shape.
We save dogs:
JBWood05TJ is offline
post #1353 of 1825 Old 12-22-2010, 09:11 AM
kgginslc
So, I've got my new OPDA. I will do the mods described in this thread.
My question - you need to pull the shaft to do all the drilling (right?) - I believe this requires removing the gear.
When you put the gear back on, is there some particular method to install the new roll pin that secures the gear? Can I reuse the old pin?
kgginslc is offline
post #1354 of 1825 Old 12-22-2010, 09:31 AM
OldenEagle
I'm hopeful the cam is fine because the OPDA gear isn't pretty, but far from destroyed yet. I've got the new parts ordered and will give the cam a much closer look when I pull the old drive. A big THANKS to all the people sharing this info, most likely saved my 4.0 from self destructing.
Now while I'm waiting on those parts I'll get my 3.5" lift done and some tires on.
"Be sure to leave this world as you entered it, screaming your head off and covered in someone else's blood"
post #1355 of 1825 Old 12-22-2010, 01:00 PM
willydigger
http://www.jeepforum.com/forum/f9/20...ilure-1144202/
I've started a new thread dedicated to consolidating all the information from this thread. It has a brazillion pics and posts reserved as we find new information. It is not meant to replace this thread, but act as a one stop thread to answer all the reoccurring questions generated. I hope to have all the pics up before the new year.
willydigger is offline
post #1356 of 1825 Old 12-22-2010, 04:04 PM
JBWood05TJ
JBWood05TJ's Avatar
Use a roll pin punch to remove the pin and pull the gear. The roll pin can be reused.
We save dogs:
post #1357 of 1825 Old 12-22-2010, 04:55 PM
OldenEagle
You need to be very careful if driving out the old roll pin, it is possible the shaft could be bent if not supported correctly. The most recommended way is to drill out the roll pin and replace it upon reassembly.
post #1358 of 1825 Old 12-22-2010, 05:07 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
I've never heard of anyone recommending to drill out a roll pin?...
Knuckelhead is offline
post #1359 of 1825 Old 12-22-2010, 05:56 PM
keithert
keithert's Avatar
You have done a great job with the new thread. Very informative.
keithert is offline
post #1360 of 1825 Old 12-22-2010, 06:25 PM
OldenEagle
This is the way the "E 05 oil pump drive gear replacement" instructs all service techs to perform the gear replacement. I spoke with a mechanic today who worked for a Jeep dealer for 7 years.
post #1361 of 1825 Old 12-22-2010, 06:27 PM
TheFog
Drilling the roll pin out is asking for trouble. I don't care how careful you are your going to rock the drill bit side to side a bit and wallow out the hole.
Support the shaft and use a appropriate ized punch and you will have no problems knocking the pin out.
FOG
In memory of Samantha Sue 1998 to Dec-16-10 at 2:15PM. She may have had 4 legs and a tail but she was the best friend I ever had and helped me through some really tough times. I hope to see her again one day.
TheFog is offline
post #1362 of 1825 Old 12-22-2010, 06:36 PM
Knuckelhead
AFSOC Retired
Post a DC document pertaining to this procedure. I'd really like to see this...
post #1363 of 1825 Old 12-22-2010, 06:39 PM
OldenEagle
I agree knocking out the roll pin with the right punch is the way to go, I was just sharing what the mechanic read to me right off the procedure's instructions used by dealership service depts. Truth be known, they probably drive em out to.
Anyone have the part # for the Eschlin gear from NAPA?
post #1364 of 1825 Old 12-22-2010, 06:43 PM
TheFog
Napa is no longer making the gear. The one made by Crown is the only option.
FOG
TheFog is offline
post #1365 of 1825 Old 12-22-2010, 06:50 PM
OldenEagle
FOG
Just my luck...
Way back in the thread I saw it stated that some of the best performance was with this Napa gear.
What is the most recommended grease for the upper end when installing a zerk? I've seen many types tried but haven't caught where anyone has nailed it down.
2006 , 4.0 , camshaft , replacement , tj , warranty , wrangler
All jeep owners please read for better mpg jeepfreak_5 TJ Wrangler Technical Forum 77 06-26-2012 04:20 PM
Have you really read your owners manual JohnRodriguez JK Wrangler Technical Forum 2 09-14-2008 07:25 PM
97 owners please read!!!!!! river rat TJ Wrangler Technical Forum 33 01-31-2007 05:38 PM
FL Jeep Owners, Please Read siennaspilt TJ Wrangler Technical Forum 11 01-24-2004 03:05 PM
soft top owners - must read DrEvil TJ Wrangler Technical Forum 12 10-20-2003 06:38 AM
