Chrysler is paying to install a new cam (2005/2006 owners should read this) - Page 8 - JeepForum.com
post #106 of 1825 Old 03-31-2010, 10:45 PM
iowaneedshills
I literally just broke down in the middle of a 14 hour drive this weekend while I was trying to move. A mechanic and I tried replacing the crankshaft and camshaft position sensors (it had been throwing that code for a while) and nothing worked. We found that my timing was 30 degrees off. yep, 30. even after resetting the timing, it jumps around and still doesn't run. Pulled the oil pump drive and the teeth look horrible. My build date is february 2005, so right at the end of the problem dates.
What I don't get is why wasn't the gear on the oil pump drive made of brass so it didn't tear up the camshaft
Who did everyone call to get Chrysler to pay for it? I called them today and they said it wouldn't be covered under a warranty or anything like that...
As it is now, i'm out $800 for the Uhaul i needed to get the thing the rest of the way. I hope I'm not out more!
iowaneedshills is offline
post #107 of 1825 Old 03-31-2010, 10:59 PM
AZJeepNewbie
What do you mean "a warranty or anything like that"? Your standard warranty has expired. If you have the extended power train warranty, it certainly is covered. If not, you're out of luck.
2005 Rubicon, Currie JJ SA lift with AEV 3" springs.
"Confidence is that feeling you have before you fully understand the situation."
AZJeepNewbie is offline
post #108 of 1825 Old 04-01-2010, 06:49 AM Thread Starter
ElJaynocibuR
There is no warranty, there is no "recall", there IS a Technical Service Bulletin (TSB) for this problem. You need to call Chrysler back, they know about this poblem, and you need to insist that they cover you under the E05 (I believe that's the number they use) TSB. They probably won't cover the $800 uhaul, but theyll cover almost $1000 to fix the problem
2006 LJ Rubicon=4" lift, 305/70/16 Mickey T.'s MTZs, etc...
ElJaynocibuR is offline
post #109 of 1825 Old 04-01-2010, 08:15 AM
iowaneedshills
The lady's comment was that because it wasn't a recall, it wouldn't be paid for, period. She said it didn't matter if it was a TSB when I brought it up. Guess I'll try again and see if I get someone that is a little more agreeable...
post #110 of 1825 Old 04-01-2010, 08:25 AM
tshively
[QUOTE][
/QUOTE]
This is a bunch of B.S. ^^^! I am now in my fourth day waiting to hear back from the dealer. The dealer is telling me they have a call in to Chrysler and that they are waiting to hear back from their rep.??
tshively is offline
post #111 of 1825 Old 04-01-2010, 08:36 AM Thread Starter
ElJaynocibuR
Here is how my conversation with Chrysler went down (in a nutshell):
Me: I'm calling because I'm having a problem with my oil pump drive gear and its giving me check engine lights and my jeep won't run. Chrysler has a TSB for it and I want to see about getting the repairs covered
Chrysler Rep.:What is the last 8 of the vin and what's the mileage?
Me: ******** and 65k miles
CR: Well I have a TSB for an oil pump drive gear but yours does not qualify.
Me: I know it doesn't, that's why I'm having to call you. It has the problem but was built a few months outside of the TSB range. Yall should cover this just like yall did for the 2005's because obviously the problem is bigger than you're leading owners to believe. What do I need to do to get it covered?
CR: You will need to have it diagnosed by a certified Chrysler/Jeep dealership.
Me: Do I have to pay for the diagnosis?
CR: Yes
Me:Are you going to guarantee that yall will cover it if they agree that it is teh oil pump drive gear
CR: No
Me: So i may be out $100 for the diagnostics?
(Fast Forward, my dealership didn't charge me)
CR: You will be contacted in the next 1 or 2 business days by a Chrysler Rep. and he will handle your case.
I took it to the dealership, they diagnosed it that same day. In the next few days I heard back from the Chrysler Rep and he told me they would cover all but $100.
It's now fixed, no more check engine lights or bucking, spitting, and sputtering. All of that only cost me some time on the phone, 2 trips to the dealership, and $100.
post #112 of 1825 Old 04-01-2010, 08:39 AM Thread Starter
ElJaynocibuR
Ask them why they covered mine and won't cover yours. Ask them if it's because you're (insert color/ethnicity here)
post #113 of 1825 Old 04-01-2010, 11:37 AM
iceman8
ElJay,
Glad you got it worked out. Any leaks after re-assy. of the engine?
iceman8 is offline
post #114 of 1825 Old 04-01-2010, 11:59 AM Thread Starter
ElJaynocibuR
Originally Posted by iceman8 View Post
ElJay,
It's funny that you ask that. It's been back twice because I have an oil leak from the front of the oil pan. It's right where the timing cover meets the oil pan.
I've read of some people having leaks because the tech forgets to install the gasket on the camshaft synchronizer. That makes a huge mess. Mine is more like oil seepage.
post #115 of 1825 Old 04-01-2010, 09:40 PM
iowaneedshills
I called them back (this time the "vehicle complaint" option, not the "warranty information" line). They offered to fix it right away without any hesitation, under the powertrain warranty. She also said she'd move it to their "upper level" customer service department to see if they could cover whatever the warranty did not.
I took pictures today, too. Here's the wear on my oil pump drive and the camshaft. Doesn't look like much, but it's enough to make the teeth on the gears jump and throw my timing way off....
post #116 of 1825 Old 04-02-2010, 07:50 AM Thread Starter
ElJaynocibuR
You got a great pic of the camshaft^. I was never able to get my camera to focus in on it.
I'm glad Chrysler is taking care of it.
post #117 of 1825 Old 04-02-2010, 08:09 AM
Nick B
ElJay:With 65,000 miles I'm surprised they covered you instead of saying: "sorry" .
Nick B is offline
post #118 of 1825 Old 04-02-2010, 08:13 AM
Nick B
WOW ! That's some serious wear . What's your mileage again ?
Nick B is offline
post #119 of 1825 Old 04-02-2010, 08:34 AM
Woodenya
Man, that's exactly what mine looks like with only 7k on it. My cam shaft gear has the same rough/chipped looking end edge to it too.
Monday can't get hear fast enough for me. I need to get this thing in and taken care of. She's getting hauled in on the trailer too. Hope that makes an impression on them about how serious this problem is!
Two trips back and you still have an oil leak?! That's the kind of stuff that I'm worried about!
'06 TJ Rubi (Light Metalic Khaki) 6sp, Bought 3-10 w/6500 miles. 31 MTR's, UCF alum UHC T-case & engine skid w/ LoPro, Rokmen gas tank & steer gear skid, Ridler dif covers F/R, Warn 8274-50, Optima Yellow top, Pro Comp front 3/4" spacers, Currie 1" BL, Bomb Proof MML, Novak cable shifter, AGR Super Box 2, Warn rear bumper/tire carrier, Rubi locker mod/pumps moved to engine bay, OBA. Build to come...
Woodenya is offline
post #120 of 1825 Old 04-02-2010, 09:16 AM Thread Starter
ElJaynocibuR
I was anticipating them saying that, but I wasn't ready to take "sorry" or "no" for an answer. I've found if you don't get the answer you want, you just "climb the ladder". By that I mean you asked to speak to their supervisor, or their supervisor's supervisor, etc...
2006 , 4.0 , camshaft , replacement , tj , warranty , wrangler
All jeep owners please read for better mpg jeepfreak_5 TJ Wrangler Technical Forum 77 06-26-2012 04:20 PM
Have you really read your owners manual JohnRodriguez JK Wrangler Technical Forum 2 09-14-2008 07:25 PM
97 owners please read!!!!!! river rat TJ Wrangler Technical Forum 33 01-31-2007 05:38 PM
FL Jeep Owners, Please Read siennaspilt TJ Wrangler Technical Forum 11 01-24-2004 03:05 PM
soft top owners - must read DrEvil TJ Wrangler Technical Forum 12 10-20-2003 06:38 AM
