Chrysler is paying to install a new cam (2005/2006 owners should read this) - Page 68 - JeepForum.com
post #1006 of 1825 Old 11-16-2010, 05:55 PM
JeepScrap
Thanks for the info Willy. Just outta curiosity, what part do you ask for when you order one of these assemblies? CPS? Oil pump drive assembly?
Jeez, if someone here is mechanically inclined, making a sturdy aftermarket assembly could prove to be financially rewarding! Anyone? Anyone?
JeepScrap is offline
post #1007 of 1825 Old 11-16-2010, 06:05 PM
TJJP77
TJJP77's Avatar
Originally Posted by rubicon1000 View Post
this was the one i replaced, only number on the saft is the part number 53010614aa and a number under the manufacture standard 1063
'03's use a different assembly that doesn't seem to be suffering as high a failure rate as the '05/'06 models. If I were you I would just use a high quality oil with adequate ZDDP content and not worry about it. This is exactly what I'm doing with my '02 - I've never removed it and have no plans to since I run Valvoline VR1 in it.
My '06 is another matter...the original gear showed striation wear with 9,300 miles on it, and the replacement gear I got (the same part the dealers installed as part of the recall) is already showing signs of wear with just 4,000 miles on it. It's just as well that I've parked the Jeep for the winter - I'll figure out what to do about it next spring.
Chris
'02 Sahara
'06 Rubicon Unlimited
Sienna Jeep Club: Member #15
TJJP77 is offline
post #1008 of 1825 Old 11-16-2010, 06:25 PM
willydigger
Below is a pic of the difference in the 02-04 shaft Top and the 05-06 shaft Bottom. I would love to get my hands on one of each to see everything that's different.
Originally Posted by tkki1230 View Post
The newer shaft (bottom one) is the one that is scored. The bushing is scored too.
willydigger is offline
post #1009 of 1825 Old 11-16-2010, 06:29 PM
willydigger
I asked for the Oil Pump Drive Assembly. The PN should help narrow it down also. The CPS, I suppose, is technically the electronic sensor.
post #1010 of 1825 Old 11-17-2010, 09:21 AM
JeepScrap
Are you guys that are pulling the OPDA periodically to check it needing to replace the gasket when reinstalling it? Or is the gasket just needed for installing a new assembly?
post #1011 of 1825 Old 11-17-2010, 11:05 AM
willydigger
When I pulled my original (65K miles) there was no damage. I pulled it twice with no problems.
When the new OPDA was installed it didn't have the gasket. It leaked a tiny bit. I drove with it off for a few days while waiting for the replacement to come in. I would think you only need to purchase one new gasket for the new OPDA. It can be reused if you are reasonably careful when removing and installing.
post #1012 of 1825 Old 11-17-2010, 11:32 AM
dtc503
Just an FYI
Just to chime in on where to buy the OPDA and gasket.
I purchased OPDA part number: 53010624AC $97.85
Gasket part number: J3181288 $1.87
Total including freight was $112.67
They are Jerry Ulm Dodge, Chrysler, Jeep
2968 N. Dale Mabry, Tampa, FL 33607
(813) 872-6645
Rick
dtc503 is offline
post #1013 of 1825 Old 11-17-2010, 01:34 PM
fdoepel
i have an 06 lj with 65k miles the mfg date on the door frame is 11/05 , however don't know when engine was mfg. how do i determine if the tj falls in this problem?
thank
fdoepel is offline
post #1014 of 1825 Old 11-17-2010, 07:11 PM
SkylinesSuck
Read the last couple of pages. This is a problem across all years,
'98 Sahara w/AX15 & 4.6L stroker, 2.5" OME lift, 32" BFG M/T's, 8.8 w/Detroit Trutracs & 4.10's F&R
SkylinesSuck is offline
post #1015 of 1825 Old 11-18-2010, 08:46 AM
JeepScrap
Posted this in the registry post as well...
Has anyone been able to figure out what the difference is, if any, between Rev E and Rev B in the serial number of the OPDA? Also, did D/C update the assembly in late 2006 and is there actually anyone who is NOT having issues with their OPDA?
post #1016 of 1825 Old 11-18-2010, 09:01 AM
willydigger
If I were to guess I would say manufacture date. I originally had a REV-B that failed. Now I'm working with a REV-E. They look identical. There are several high mileage 05-06 TJ's out there. I would be reluctant to say every one is bad. They are more prone to failure though.
Also, just to put it out there, the I6 calls for 6 qts of oil. A lot of places sell 5 qt deals and I don't know for certain what shops add.
post #1017 of 1825 Old 11-18-2010, 09:13 AM
biffgnar
biffgnar's Avatar
If you do a search there was a thread a few weeks ago with many people without issue. Many had reasonably high mileage (80-100K) for a 05-06.
biffgnar is online now
post #1018 of 1825 Old 11-18-2010, 09:57 AM
bacon225
I purchased OPDA part number: 53010624 $97.85
(813) 872-6645
Rick
That is a great price I paid $ 167 for mine with no gasket.
bacon225 is offline
post #1019 of 1825 Old 11-18-2010, 11:33 PM
wl07
i found out mine was changed at 8k by previous owner i havent checked to see if they just put in the same or a different one yet but now it has 103k and no problems so at least it is fixed i think.
wl07 is offline
post #1020 of 1825 Old 11-18-2010, 11:34 PM
wl07
was on another jeep forum and ask about this issue and not many on that site seemed to have this problem so not sure how big of issue it is.
wl07 is offline
2006 , 4.0 , camshaft , replacement , tj , warranty , wrangler
All jeep owners please read for better mpg jeepfreak_5 TJ Wrangler Technical Forum 77 06-26-2012 04:20 PM
Have you really read your owners manual JohnRodriguez JK Wrangler Technical Forum 2 09-14-2008 07:25 PM
97 owners please read!!!!!! river rat TJ Wrangler Technical Forum 33 01-31-2007 05:38 PM
FL Jeep Owners, Please Read siennaspilt TJ Wrangler Technical Forum 11 01-24-2004 03:05 PM
soft top owners - must read DrEvil TJ Wrangler Technical Forum 12 10-20-2003 06:38 AM
