Chrysler is paying to install a new cam (2005/2006 owners should read this) - Page 53 - JeepForum.com
post #781 of 1825 Old 09-25-2010, 09:56 PM
Hella
Doesnt look normal to me neither, but I figured it was maybe just normal wear for the motor being seven years old. Plus I just had doubts because my motor is not in the build date for this specific problem, but should I call chrysler on monday? I have a feeling they are going to tell me its out of the build date.
04 TJ "Leyla" Rubi..
Hella is offline
post #782 of 1825 Old 09-26-2010, 10:01 AM
TheFog
This is a view from the bottom of the engine of the camshaft/CPS gear mesh up. You can use the thickness of the crankshaft gear for reference.
FOG
TheFog is offline
post #783 of 1825 Old 09-26-2010, 02:08 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Don't you mean "camshaft gear"?...
Knuckelhead is offline
post #784 of 1825 Old 09-26-2010, 04:25 PM
Hella
Hey knuckelhead, should I call regarding my cam sensor even though its not in the build date?? Or is chrysler just guessing as to what vehicles it affects and not totally sure about all the years?
Hella is offline
post #785 of 1825 Old 09-26-2010, 05:18 PM
JrJmisn
ok guys...i have had a loud ticking for a while now coming from the cam sensor/oil pump drive. I took off the plastic cap and can see the play in the shaft spinning that is causing the ticking. The round plate with holes in it at the top of the shaft seems to be hitting the housing causing the noise. I can move the mechanism both rotationally about 1/8 inch and also back and forth a little bit. Havent pulled it yet to see the gear.
I want to replace the whole mechanism. Had anyone found an aftermarket part by now? or anyone had good experience from the dealer selling the oil pump drive/cam sensor mechanism?
I am a november 04 build TJ within the problem time. I dont have the mechanical symptoms at all....just the ticking that I can see it causing. I hear a lot about the problem...but not a lot about the solution. I am not one of the guys on this thread with SUPER low miles on my 05 that want to try to get a free part, I just want a solution.
JrJmisn is offline
post #786 of 1825 Old 09-26-2010, 05:40 PM
Knuckelhead
AFSOC Retired
I think so.
Good luck...
post #787 of 1825 Old 09-26-2010, 07:07 PM
Jp90Talon
Little update on my situation. I was correct in assuming this part was my issue but as per my usual luck, my issue had a little "twist" than others that have had it happen to them. I did have the signs of wear as everyone else but my gear actually broke off. It appears it cracked at the section where the pin holds it on the rod. and just fell off. My mechanic couldnt tell what happen first be it the gear cracking or the pin falling out causing it to crack and fall off. She is now back on the road but I am still pretty dam unhappy with the situation esp since odds are it will happen again (well at least the wearing). unfortunately my gf has my camera but I will post up pics as soon as I get it back.
Jp90Talon is offline
post #788 of 1825 Old 09-26-2010, 08:10 PM
TheFog
Every bodies a critic
FOG
TheFog is offline
post #789 of 1825 Old 09-26-2010, 08:17 PM
bonza
that is the second OPDA gear that I am aware of that has failed in exactly the same way
makes me think that something is creating abnormal strain on the gear, possibly the bearings in the unit seizing or lacking lube
"I like a man who grins when he fights"
— Winston Churchill..
bonza is offline
post #790 of 1825 Old 09-26-2010, 09:08 PM
speed_phreak
I spent a bit of money bringing a brand new Rev E unit to a machinist for disassembly...
Bottom bushing requires oil to defy gravity and flow upward through 4 very small channels, which would work if it was set in some kind of pressurized cavity, however it isn't.
There is a seal in between bushings, so even if oil managed to get into the bottom bushing, it would never make it to the top.
Top bushing has zero chance of lubrication. There is a galley where lubrication is placed from the factory, but the Rev E unit doesn't have a pathway to the inside of the bushing. My machinist removed the top bushing drilled a hole in it that lined up with the galley, and installed a zerk.
Ultimately this is what I would like to see:
1.) A seal at the end of the bottom bushing where the gear attaches.
2.) A seal at the top of the top bushing where the pickup wheel is.
3.) Middle seal removed.
4.) Oil passages at around the bottom bushing sealed.
5.) Zerk with hole in top bushing as described above.
This would create a completely sealed system that is self lubricated. The next problem of course is making sure the cam/OPDA gears are properly lubricated themselves, enter Hesco's high volume oil pump with axillary lubrication tube.
speed_phreak is offline
post #791 of 1825 Old 09-27-2010, 03:09 PM
map93xj
My lj was built 5/06, engine 4/11/06, 42985 miles. This is what I found today. There is no noise, no side to side play, just able to turn about an 1/8 inch back and forth. I figure thats just slop between the gears. What do you think? My jeep is outside the time line of the service bulletin. I just put a new distrubor in my 93XJ with 190,000 mile and I don't remeber this much wear on it's gear. Not that I lloked that close at it. You think I could just put on a new gear and be alright? I looked at the cam gear and didn't an kind of wear to be alarmed about on it.
06 LJ rubi RE 4 1/2 sf, MT 35/12.50/15 on soft 8s, Kilby tummy tuck and engine skid, Wilderness frt and rear bumpers, Warn M8000, Cobra 75 cb, Genright sport cage, Poison Spyder Armor, Gen Right front fenders.
map93xj is offline
post #792 of 1825 Old 09-27-2010, 04:24 PM
willydigger
Do you have any pics of the guts? What about removing the OPDA shaft and cutting a groove like previous years?
willydigger is offline
post #793 of 1825 Old 09-27-2010, 05:57 PM
Zeep
FOG, are you installing a Hesco oil pump on yours?
JEEP THE AR-15 OF THE AUTOMOTIVE WORLD
Zeep is offline
post #794 of 1825 Old 09-27-2010, 07:12 PM
solarpower
Winner.
The total lack of lubrication on that top bushing wears it out fast. Once it's worn down that shaft is going to wobble (even more than the smaller style or even a distributer) and be amplified by having a large ring on top. That wobble in the top end of the shaft WILL translate to wobble at the other end of shaft.
This explains why the wear on the gears is so uneven not only from one vehicle to another but from tooth to tooth on same gear. It also explains why the flats on the very end of shaft (that drive oil pump) have wear spots on the corners.
I told my good friend to purchase another assembly brand new and if we put a zerk in the top (already a place for one anyway) and grease it it should last a real long time.
04 TJ "U" package
06 XK Commaddy 4.7
solarpower is offline
post #795 of 1825 Old 09-27-2010, 09:11 PM
speed_phreak
Winner.
That is good advice. I think the top bushing still needs to be removed by a machinist though, so that a hole can be drilled in the bushing. I suppose a hole could also be carefully drilled with the shaft removed and the bushing still in place.
We have all seen what doing nothing produces...
2006 , 4.0 , camshaft , replacement , tj , warranty , wrangler
All jeep owners please read for better mpg jeepfreak_5 TJ Wrangler Technical Forum 77 06-26-2012 04:20 PM
Have you really read your owners manual JohnRodriguez JK Wrangler Technical Forum 2 09-14-2008 07:25 PM
97 owners please read!!!!!! river rat TJ Wrangler Technical Forum 33 01-31-2007 05:38 PM
FL Jeep Owners, Please Read siennaspilt TJ Wrangler Technical Forum 11 01-24-2004 03:05 PM
soft top owners - must read DrEvil TJ Wrangler Technical Forum 12 10-20-2003 06:38 AM
