Chrysler is paying to install a new cam (2005/2006 owners should read this) - Page 52 - JeepForum.com
post #766 of 1825 Old 09-22-2010, 05:44 PM
willydigger
From the Registry Thread.
1. Year, model, mileage, and build date of your Jeep
2005, Wrangler X TJ, 64,400 miles, 2/05
2. Brief description of the problem and any collateral damage. Please include pictures if available.
The laughing monkey noise tipped me off. I pulled the OPDA after two weeks of troubleshooting.
3. Actions taken to fix the problem.
I took it to the dealership. I took it the evening before so they had it cold the following morning. I explained to the dealer the noise and the problem. I let them know about the TSB and the duration of the noise.
Later that morning the dealer called and said the part was not covered under the 7yr/70,000 mile drive train warranty. I asked how a part that was directly related to the drive train was not covered considering the TSB. He said he would double check. He mentioned that since it wasn't a "recall" and was only a "TSB" it was not covered under warranty. A few minutes later he admitted he was mistaken and said it was covered under the warranty. He mentioned the $100 deductible would still have to be covered. I believe if I hadn't of pressed the subject the dealership would not have covered it.
4. Approximate cost of repair?
They originally tried to charge me the price of the OPDA and installation (~$490). After admitting to warranty coverage I had to pay a $100 deductible for the replacement ODPA. I asked to see the part they removed to confirm it was the worn part. It was. The part also has a 12mo/12,000 mile warranty.
5. Did Chrysler pay for or reimburse any of the repairs?
The dealer said there was no damage to the camshaft gear. There was no other indication of failure other than the noise (no drop in oil pressure, no codes, no engine trouble, etc.). The service rep did mention that the old part would likely be rebuilt. I expect my replacement to be the same PN or a rebuilt part. I will have to keep an eye out. The only repair cost was a "new" OPDA and installation.
6. If Chrysler did pay, what steps were taken to make them pay?
As mentioned above, I had to press the subject. If I had of accepted the dealer's initial response I would not have been covered. Only after asking for an explanation and asking to check why the part was not covered, did they admit to coverage. I dealt directly with the dealer.
7. Has the problem returned?
When I left the dealership the noise was gone. Since that was my only symptom, I will have to wait a little while to inspect. I believe it will return.
UPDATE YES.
I removed the OPDA today. It had 20 miles on it since the dealer installation.
Here are some shots of the camshaft gear the dealer claims was okay.
*Also FYI, the dealer had the OPDA in stock (9/21/10, Baltimore MD). I dropped the Jeep off the previous evening and picked it up the next afternoon.
Also One other helpful note with removing the OPDA. After you mark the engine, OPDA housing, and OPDA sensor wheel, you'll pull the OPDA out. The shaft will turn as stated previously. During reinstallation take care not to turn the oil pump so that it doesn't match during reinstallation. If you move it, take a flathead screw driver and return it so the OPDA shaft will mate correctly. Your match marks have to meet for the Jeep to run properly.
willydigger is offline
post #767 of 1825 Old 09-23-2010, 01:53 AM
Terrible2
Well,
My dealership wants a $450 diagnostic fee to take a look at the clutch even though I tell them I have 2 TSB, one for reverse popping out of gear and one for this OPDA. I kept insisting they simply look at the camshaft but they wont. So I called up chrysler, and now theres a case manager assigned to my case. Im just wondering if anyone else had to front a "diagnostic fee" especially for something you dont want them to look at? If so how they dealt with it.
Terrible2 is offline
post #768 of 1825 Old 09-23-2010, 07:24 AM
willydigger
Originally Posted by Terrible2 View Post
Well,
My dealer mentioned a $99 Diagnostic fee but only if they didn't find anything.
post #769 of 1825 Old 09-23-2010, 07:58 AM
willydigger
Originally Posted by tkki1230 View Post
Here's a pic of a side by side comparison. You can see the oil groove on the older style shaft (upper one). Even with the crappy phone pic, if you look at my 06 shaft (lower one), you can see the major scoring right above the teeth.
Why is the newer shaft not scored? Is the bushing scored instead? Does any one have an old one that I can dissect?
post #770 of 1825 Old 09-23-2010, 10:45 PM
Terrible2
were they going to be giving a diagnostic on the transmission or clutch? the thing they suspected.
post #771 of 1825 Old 09-24-2010, 07:25 PM
willydigger
I prepped them by telling them the symptoms of the OPDA. I think the protocol is there must be something wrong and they are responsible. I felt like I had to take them by the hand and show them.
Afterward I told them the gasket wasn't installed on the part they replaced. I told them I would be down to get a gasket and that I would install it myself. I have no confidence in the dealer or the techs.
Regarding the OPDA, I believe the camshaft gear is okay. While there is some shine on the edge, I don't believe it will have a substantial impact on the new OPDA gear. My plan going forward is to monitor the new OPDA at each oil change. I subscribe to the thought that poor bushing or shaft design is the issue. I have started using Mobil 1 High Mileage also.
post #772 of 1825 Old 09-24-2010, 08:37 PM
Terrible2
hmm, no matter what I seem to say they want to check out the clutch and charge me $450 for diagnostic. Im waiting back on Chrysler
post #773 of 1825 Old 09-24-2010, 11:05 PM
tkki1230
The newer shaft (bottom one) is the one that is scored. The bushing is scored too.
tkki1230 is offline
post #774 of 1825 Old 09-25-2010, 01:40 PM
jeffjeep1
jeffjeep1's Avatar
I have been following this thread for quite a while. Probably posted once or twice. Just pulled the OPDA today (Rev B). 30,200 miles. No camera at the moment. There is a little shine on each of the ODPA gear and cam teeth and the two spots where the shaft drives the oil pump, shaft turns very freely. Does not look anywhere near worn like that of prior posted pictures.
Bought it used from a Chev dealer with dealer fresh oil change at 22,800. No records by prior owner, no idea what Chev dealer put in for oil. I put in Mobil1 10-30 at 26,500. Found this thread after that oil change. Changed that out at 27,600 and put in Mobil1 15W-50 due to "flat tappet" statement in M1 data.
Sent sample of 1100 mi M1 10-30 to Blackstone advising them to look for any unusual "debris" in the oil that could be symptoms of this problem. Sample came back with a statement that engine oil looks good, but only 1100 miles.
I plan an oil sample every other oil change for a while, along with a OPDA gear visual inspection each change. Got to admit, oil change maintenance effort on this Jeep is starting to approach that of my 87 911.
Jean - Wonderful wife
2003 Toyota Sequoia
2005 FA64 (aka LJ) Khaki
Heidi - Golden Retriever/Jeep Dog
jeffjeep1 is offline
post #775 of 1825 Old 09-25-2010, 03:23 PM
solarpower
Noticed this thread long ago..but only starting looking into issue recently.
My friend has a Jeep built 10-2004 with 42,000 miles on it and mine was built 4-2004 with 43,000 miles. He has the large cap OPDA and I have the smaller old style.
We decided to check them out few days ago since his seemed to be getting poor gas mileage. Since I don't have a top notch scanner to synch the timing correctly I told him I would pull mine first.
My OPDA gear looked great as did my cam gear.
His looked like crap. Scored along the entire length of the tooth and very similar to the ones many have posted pics of.
His cam gear did not look so bad that I think it will not be an issue if we can get this thing fixed soon
So what has been the best solution to this?? If the OPDA gear is crap..what is different about the gear they would sell me at the dealership?? I could go to a junkyard and pull an older OPDA but the sensors are different.
04 TJ "U" package
06 XK Commaddy 4.7
solarpower is offline
post #776 of 1825 Old 09-25-2010, 05:52 PM
Hella
What do you guys think about this one. Mine is an 04 Jeep with a build date motor of Nov of 03. Has random misfiring, camsensor ticks, sluggish. Has 93,000 Miles so I dunno if its normal wear?!?!
04 TJ "Leyla" Rubi..
Hella is offline
post #777 of 1825 Old 09-25-2010, 06:24 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
That does not look good...
Knuckelhead is offline
post #778 of 1825 Old 09-25-2010, 07:49 PM
speed_phreak
Today me and a buddy tore apart my jeep to install the Hesco high volume oil pump with auxiliary lube shaft pointed at the gear. We had to drop the skid plates in order to remove the exhaust, so that we had enough clearance to drop the pan. Took the better part of 6hrs, but it is done...
The new OPDA has only been in there a couple weeks, so hopefully it wears no more than it has in that time.
Got a better look at the cam gear, there was wear, but i don't think it was bad...
Made what I believe to be a permanent switch to M1 HM 10W-40.
fingers crossed, or to hell with the heep....
speed_phreak is offline
post #779 of 1825 Old 09-25-2010, 08:15 PM
Hella
So do you think its a faulty crank and gear or just normal wear. it has 93000 on it
Hella is offline
post #780 of 1825 Old 09-25-2010, 08:30 PM
Knuckelhead
AFSOC Retired
That does not look normal to me?...
2006 , 4.0 , camshaft , replacement , tj , warranty , wrangler
All jeep owners please read for better mpg jeepfreak_5 TJ Wrangler Technical Forum 77 06-26-2012 04:20 PM
Have you really read your owners manual JohnRodriguez JK Wrangler Technical Forum 2 09-14-2008 07:25 PM
97 owners please read!!!!!! river rat TJ Wrangler Technical Forum 33 01-31-2007 05:38 PM
FL Jeep Owners, Please Read siennaspilt TJ Wrangler Technical Forum 11 01-24-2004 03:05 PM
soft top owners - must read DrEvil TJ Wrangler Technical Forum 12 10-20-2003 06:38 AM
