Chrysler is paying to install a new cam (2005/2006 owners should read this) - Page 51 - JeepForum.com
post #751 of 1825 Old 09-15-2010, 08:15 PM
sumday
how much did it cost for the dealer to resynch the cam?
sumday is offline
post #752 of 1825 Old 09-15-2010, 08:46 PM
Knight-Rider
It cost me an hour of shop time. I actually swapped the part in the parking lot while waiting for my appointment. I tried to get as close as I could.
It fired up right away, but the check engine light was on. No biggie, as I was already in the stealership's parking lot.
The best part was that the noise from the bushing was gone
Knight-Rider is offline
post #753 of 1825 Old 09-15-2010, 08:54 PM
speed_phreak
$50 for me...
speed_phreak is offline
post #754 of 1825 Old 09-15-2010, 11:37 PM
TheFog
There is a way to re-sync the CPS unit WITHOUT a DRB-III tool.
I spoke with fellow ham radio operator that is an engineer with a company that makes engine control computers. He had a pretty good working knowledge of the JTEC system and how it deals with the cam and crank sync issues.
The JTEC is designed to be able to realize when the CPS is off by up to 15 +/- and compensate. This was designed into the system to deal with gear wear and other system variables that can cause the CPS timing to shift. Because of this if the CPS timing is dead on or 14degrees off the ECU/JTEC compensations and the engine will run the same.
The way to take advantage of this to reset the sync with involving the dealer is as follows.
First you have set the engine at top dead center and install the CPS with the locking pin in place. This will get the CPS with-in about 20 degrees +/- of where it should be. Now snug down the bolt that holds the CPS in place just enough to where it can't turn.
If there is already a error code clear it out and then start the engine. Let the engine idle for about a minute and then if the check engine light doesn't come on rev it up to about 2200 and hold it there for 15-20 seconds. If the check engine light comes only on when you rev it then you close.
Stop the engine and turn it back a touch and try again. Its a trial and error but it only took me about 10 minutes to get it right.
Just realize that if the check engine light comes on idling its grossly off and its probably going to be on the "other side" of where the TDC mark is you found earlier. But if it throws a code at high revs then its pretty close.
So if you don't want to spend the time and money and have a basic el-cheap scan tool that can clear codes, you can re-sync without a DRB-III
FOG
TheFog is offline
post #755 of 1825 Old 09-16-2010, 05:35 AM
TJJP77
TJJP77's Avatar
FOG,
Not sure if this affects the theories of your engineer friend, but the '05/'06 Wranglers use the newer NGC control module, which is what necessitated the change to the new, failure prone OPDA. The '04 and older Wranglers were the models with JTEC controllers.
Chris
'02 Sahara
'06 Rubicon Unlimited
Sienna Jeep Club: Member #15
TJJP77 is offline
post #756 of 1825 Old 09-16-2010, 08:38 AM
TheFog
Originally Posted by TJJP77 View Post
FOG,
Its my mix up, he used both terms as talking about the revisions and changes. He was specifically talking about the newer computer that Jeep started using in 05 models.
FOG
TheFog is offline
post #757 of 1825 Old 09-17-2010, 03:46 AM
SkylinesSuck
The distributor gears on the older models fail just like the newer models. Go look on jeepstrokers.com and you'll find TONS of examples, and almost everybody there is running older style distributors, not the new module thingy.
'98 Sahara w/AX15 & 4.6L stroker, 2.5" OME lift, 32" BFG M/T's, 8.8 w/Detroit Trutracs & 4.10's F&R
SkylinesSuck is offline
post #758 of 1825 Old 09-18-2010, 02:15 AM
trw
2011 JK Wrangler
Wow, I was seriously looking at an 05 Rubicon to replace my tired YJ, but not now, I guess I'll have to up my payments for a JK since they're showing more promise without such hellish failures.
Seriously, Daimler should burn for this, and Chrysler .....uhg no comment.
Jeep garage:
2011 Jeep Wrangler JK - 33" BFG KM2s, 2.5" RC BB, ARB bumper, IPF 900XS, Superwinch EPI 9.0, AEV Snorkel
1995 Jeep Wrangler - 4 cyl, 2.5" lift, BFG AT 30s, Ford 8.8, SYE+CV, AX15 swap, ARB snorkel, Aussie locker + loads more - sold
1978 Jeep CJ-7 - 304 V8, TH400 auto and quadratrac
2007 Jeep Liberty - Mother's Jeep, BFG ATs and....mud?
trw is offline
post #759 of 1825 Old 09-21-2010, 04:15 PM
willydigger
My dealer had the part in stock and installed it in a day. They only replaced the OPDA and it cost $100 covered with the 7yr/70,000 mile warranty.
willydigger is offline
post #760 of 1825 Old 09-21-2010, 04:16 PM
2006_Sport
That's good you got it covered under warranty. Those of us out of warranty are pretty much screwed though.
2006_Sport is offline
post #761 of 1825 Old 09-21-2010, 06:06 PM
willydigger
If not under warranty I planned to get a new one and install myself. It isn't that hard assuming of course there is no damage to the camshaft. I contacted DaveysJeep for a used one for $62 shipped. Moparparts supposedly has them new for just over $100.
All the dealer did was replace my VER-D with a VER-E that everyone is having trouble with. It cost $100 to buy some time.
post #762 of 1825 Old 09-21-2010, 06:14 PM
willydigger
Quick summary request.
Is it the general feeling that the lack of lubrication to the OPDA shaft is causing the wear on the gear?
Would removing the cover and lubing the upper chamber (like the WD-40 scenario with a more appropriate lube) prevent this problem?
Or, is the gear wearing due to inferior components? And oiling the OPDA upper will only cover the "laughing monkey"?
Shouldn't the OPDA shaft gear be softer so it is the expendable component instead of the camshaft?
post #763 of 1825 Old 09-22-2010, 01:36 AM
Terrible2
How are you out of warranty? youre 2006 should have 7 year 70,000 mile powertrain. Unless youre the third owner?
Terrible2 is offline
post #764 of 1825 Old 09-22-2010, 02:21 AM
2006_Sport
Nope, only had the 3 yr/36000 mile. Its over both of those, I'm the second owner. Ive talked to jeep about this a few times.
post #765 of 1825 Old 09-22-2010, 07:52 AM
srfnfly227
srfnfly227's Avatar
06 came with a 3 year 36k warranty. Mine was up 10 months ago and I only hit 30k last week. Sucks, but it is what it is.
srfnfly227 is offline
2006 , 4.0 , camshaft , replacement , tj , warranty , wrangler
All jeep owners please read for better mpg jeepfreak_5 TJ Wrangler Technical Forum 77 06-26-2012 05:20 PM
Have you really read your owners manual JohnRodriguez JK Wrangler Technical Forum 2 09-14-2008 08:25 PM
97 owners please read!!!!!! river rat TJ Wrangler Technical Forum 33 01-31-2007 06:38 PM
FL Jeep Owners, Please Read siennaspilt TJ Wrangler Technical Forum 11 01-24-2004 04:05 PM
soft top owners - must read DrEvil TJ Wrangler Technical Forum 12 10-20-2003 07:38 AM
