Chrysler is paying to install a new cam (2005/2006 owners should read this) - Page 50 - JeepForum.com
post #736 of 1825 Old 09-12-2010, 10:06 PM
Mattyvac
2012 KK Liberty
Was a copy of the tech bulletin posted anywhere in this thread? or a reference number? I am the second owner of an LJ and want to know if I need this done under my warranty, I have a full stealership warranty until 80k miles and it only has 47k right now.
Mattyvac is offline
post #737 of 1825 Old 09-12-2010, 10:30 PM
TheFog
The problem is you can't get anything "done under warranty" until there is a problem. 99% of the dealerships are not going to touch a engine under warranty unless there is a provable problem like a check engine light or abnormal sound.
This is the reason most of us have decided to just buy a new CPS unit and swap it out. If you want till it causes noise or the engine stops running then it has done serious engine damage.
Sure the engine is under warranty but everyone knows the dealer isn't going to go out of his way to fix it properly. The dealer is just going to replace the torn up parts and leave the marginal effected ones in the engine and send you on your way.
FOG
TheFog is offline
post #738 of 1825 Old 09-13-2010, 07:34 PM
Slugger
Originally Posted by bonza View Post
what grade of oil WAS you using?
Yes on a 50 page thread that could be the biggest variable or constant for those who have or not had problems.
2005, Havoline 10-30 non-synthetic, no problems ,yet.
Slugger is offline
post #739 of 1825 Old 09-13-2010, 08:30 PM
bonza
exactly same oil that I always use. and checked pinion gear at 80,000 kilometers and it was fine
noticed that Havoline is SL rated, or at least it was last time I bought it
"I like a man who grins when he fights"
— Winston Churchill..
bonza is offline
post #740 of 1825 Old 09-14-2010, 08:24 AM
wildride89
2014 JK Wrangler
what are the affected build dates for the cam issues?
wildride89 is offline
post #741 of 1825 Old 09-14-2010, 09:39 AM
rmeredit
All 2005 and 2006 TJs? Possibly more.
rmeredit is offline
post #742 of 1825 Old 09-14-2010, 09:56 AM
wildride89
2014 JK Wrangler
who can I call and give the vin number to so I can find out?
post #743 of 1825 Old 09-14-2010, 10:11 AM
bertaman80
06 Rubicon
I noticed a ticking noise while driving about 2 years ago. My Rubicon only had 30,000 miles. Chrysler agreed to replace the cam for $100. I just figured I had a bad cam from the factory and they didn't say anything about a recall. But i am glad they fixed the problem.
bertaman80 is offline
post #744 of 1825 Old 09-14-2010, 05:43 PM
jkp
Owners manuals, recalls, service history, etc:
https://www.jeep.com/hostb/crossbrand/owners/en/
'92 Islander
'06 Rubicon
jkp is offline
post #745 of 1825 Old 09-14-2010, 09:23 PM
Knight-Rider
My 06LJ has 63 000 miles. Yesterday I put in a new OPDA because of a noisy upper bushing. There wasn't any wear on my gear, but the contact patch was a little irregular. I figured that to be the result of driving it with a pooched bushing, although the unit seemed to spin freely.
I use castrol syntec 5w50
Knight-Rider is offline
post #746 of 1825 Old 09-14-2010, 09:36 PM
TJJP77
TJJP77's Avatar
I'd strongly recommend salvaging that gear from the old OPDA...I'm not convinced that new OPDAs necessarily have a good gear with the right metallurgy/hardness.
Chris
'02 Sahara
'06 Rubicon Unlimited
Sienna Jeep Club: Member #15
TJJP77 is offline
post #747 of 1825 Old 09-14-2010, 10:56 PM
speed_phreak
Here is an update on what I have done...
1.) Purchased new OPDA.
2.) Brought new OPDA to machine shop where it was dissembled and analyzed. As others have discovered, at the factory lube hole for the upper bushing there was lube. However, in my case and in others, there was no way for that lube to EVER enter the busing. Machinist removed the upper bushing and drilled a hole in it that lines up with the reservoir cavity that surrounds the bushing. He reinstalled the busing so that the new bushing hole was on the opposite side of the new zerk, so that the reservoir would fill up with grease.
3.) Machinist compared the stock rev E gear to a Napa Eschlin gear and said they were the same, same hardness, same weight. So he just reinstalled the stock gear.
4.) On the new OPDA, there was quite a bit of play 1/8 or so between the gear and the assembly. I didn't even take the plastic key out before I gave it to the machinist. It was almost as if there was the same amount of play as those who have posted pictures with a replaced gear. However, this was with the stock gear. Rev B OPDA does not have this much play at the gear.
5.) Installed new re-engineered OPDA and took it to the stealership for syncing. I just wanted to make sure...
6.) Purchased Hesco high volume pump with auxiliary oiling tube pointing directly at the gear. Plan to install this next weekend.
7.) The only real concern that remains is the oiling of the bottom bushing. Engine oil is supposed to get sucked up through 4 little passage ways up, around, and over the top of the lower bushing. The machinist thought that the lower busing must sit in a pressurized oil cavity to force oil up through those passages, but that isn't the case. Perhaps the Hesco pump's active oiling of the gear will cover this thing in oil enough that oil will get sucked in for the lower bushing...
If this doesn't fix it, F the heep... I will take pictures of it on the bottom of a lake and post!!!!
speed_phreak is offline
post #748 of 1825 Old 09-14-2010, 11:13 PM
Knight-Rider
It is the same part .......rev E
I am keeping the old assembly, so I can tinker with it at a later time. I am thinking about a grease fitting and a brass gear. Then I will have a spare when my new one packs it in.
post #749 of 1825 Old 09-15-2010, 11:07 AM
Orange_Buddha
Has anyone been able to locate/purchase a new (05-06) CPS unit from Chrysler?
What dealer & how much?
Orange_Buddha is offline
post #750 of 1825 Old 09-15-2010, 08:09 PM
TJJP77
TJJP77's Avatar
Teh whole "Rev" thing doesn't matter - they could have had batches of bad gears without the proper metallurgical properties. Without the right metallurgy, it's impossible to properly harden the gear, thus resulting in the striated wear patterns we're all seeing.
On another note, I replaced the gear only on mine (shaft and bushings seemed to be OK) with the little kit mentioned in the bulletin sent to dealers. I just pulled the assembly again last week to see if the new gear was wearing after the 3,000 miles or so it had on it....yup...starting to wear again....sigh.
Chris
'02 Sahara
TJJP77 is offline
2006 , 4.0 , camshaft , replacement , tj , warranty , wrangler
All jeep owners please read for better mpg jeepfreak_5 TJ Wrangler Technical Forum 77 06-26-2012 05:20 PM
Have you really read your owners manual JohnRodriguez JK Wrangler Technical Forum 2 09-14-2008 08:25 PM
97 owners please read!!!!!! river rat TJ Wrangler Technical Forum 33 01-31-2007 06:38 PM
FL Jeep Owners, Please Read siennaspilt TJ Wrangler Technical Forum 11 01-24-2004 04:05 PM
soft top owners - must read DrEvil TJ Wrangler Technical Forum 12 10-20-2003 07:38 AM
