Chrysler is paying to install a new cam (2005/2006 owners should read this) - Page 47 - JeepForum.com
post #691 of 1825 Old 09-01-2010, 03:14 PM
rmeredit
FOG - That is interesting information. I didn't realize the unit had been replaced already. What is your recommendation for me @ this point? I've changed to a decent oil, am thinking about installing a new (Rev-E) OPDA and installing one of Hesco's high volume oil pumps w/ the sprayer tube that lubricates this gear. Any other advice?
Does anyone know if the Jeep engineers are actually aware of this problem & are they going to get us another part made OR are we SOL as they know these models/engines will soon be dropping out of warranty so it won't be their problem any longer?
rmeredit is offline
post #692 of 1825 Old 09-01-2010, 03:29 PM
dtc503
Rev e
I have a 2006 and I'm the original and only owner. My OPDG assembly has the REV E. I doubt that it was repalced back in September of 2006 when I bought it.
dtc503 is offline
post #693 of 1825 Old 09-01-2010, 03:56 PM
FarFire70
Originally Posted by Peterpsc View Post
I added the Hesco pump and ZDDP additive to Royal Purple 10-40.
Hesco Inc. - High Performance Engine Service
How long ago did you install this? Did your gear fail before you did this?
Have you checked your wear since you installed it?
I'd be interested to know ho much of a permanent solution this is or if it's another band-aide.
Villanova Wildcat!
2005 Wrangler Sport, 4.0L, 6spd
2" BB, JKS 1.25" BL & MML, M/T MTZ 33x12.50R15
HP D30: Aussie Locker, D44: Eaton Elocker
FarFire70 is offline
post #694 of 1825 Old 09-01-2010, 05:22 PM
tkki1230
I would love to see the condition of the not only the gears but the shafts too.
tkki1230 is offline
post #695 of 1825 Old 09-01-2010, 05:36 PM
gunner87
I pulled my OPDA this afternoon. My vehicle build date is 5/06 and the engine build date is 1/06. I am very fortunate in that my gear showed very little wear.....it is really just a bright spot around 1/3 inch long on each tooth. No wear on cam gear. I now have a check engine light on, so I guess the timing is off a little. Before pulling the assembly, I marked the tone ring in 2 places and also pegged the tone ring against the housing with an allen wrench. I also marked the housing as relative to the mounting strap and block. I guess I am off to the stealership tomorrow to have the cam timing reset.
I am one of those that just got lucky (so far)....but I still don't trust the jeep for long trips. By the way, I always use Pennzoil Platium 10-30 and Wix filters.
2006 Wrangler Unlimited
42rle tranny
gunner87 is offline
post #696 of 1825 Old 09-01-2010, 05:38 PM
biffgnar
biffgnar's Avatar
Another 06 here with original owner and REV E.
Romney in 2020!
biffgnar is offline
post #697 of 1825 Old 09-01-2010, 06:17 PM
rmeredit
After seeing your posts, I checked the maintenance records I got w/ my '06 LJ, checked the Jeep website, and then called the service dept. My '06 DID come with a REV-E part, from the factory. It has never been changed, positive.
rmeredit is offline
post #698 of 1825 Old 09-01-2010, 07:54 PM
TheFog
Well then I'm wrong about the REV-E units. Its just I've seen a bunch of 06 TJs with REV-D units including mine. Supposedly the REV-E units where made after the end of the TJ production line when the E-05 TSB came out.
FOG
TheFog is offline
post #699 of 1825 Old 09-01-2010, 08:08 PM
dtc503
Another 2006
FOG
My dad just had his OPDA replaced on his 2006 Jeep Original date code for the defective unit was: 106017 REV E...the NEW OPGA date code is: 106132 REV E
So can someone explain how to read the date code?
Thanks
dtc503 is offline
post #700 of 1825 Old 09-01-2010, 08:12 PM
Tryer
Likewise, I have rev E. Checked the assembly today. Date was 2/06 on the OPGA. I had "even" wear all the way around the gear. Some wear at 20.5k miles. Doesn't look like anything to be too concerned about at this time. I will keep an eye on it. I am running mobil 1 HM 10W-30.
Tryer is offline
post #701 of 1825 Old 09-01-2010, 08:32 PM
Sleeperman
Great discussion!
I hope Chrysler engineers are allowed to talk as openly as in this thread. But I doubt their management cares, since warranties are expiring.
My 2001 TJ's upper end was rebuilt this year (cam, lifters, etc.) b/o damage related to oil sludge/inadequate lubrication. Although it runs great now, no way I would take it on a long trip, if you know what I mean.
Recently, I almost bought a 2005 Rubicon LJ. Now, I'm wondering if a JK might be a better idea for the next 5-10 years; low interest rates are very tempting...
Sleeperman is offline
post #702 of 1825 Old 09-01-2010, 09:54 PM
Bishop Creek
Thanks
Hmmm..., mine is 105132 REV-B
“This isn’t the Old West, because the New West has never arrived. It’s just the West, like Wyatt Earp died yesterday.”
─ Michael Martin Murphey talking about the Eastern Sierra during an interview in 1996.
Bishop Creek is offline
post #703 of 1825 Old 09-01-2010, 09:57 PM
Tryer
I just bought a 2006 Rubi two months ago. I have read this whole thread, and have worried it to death. If I had it to do over, I would still buy a low mileage 2005 or 2006. The last of the great ones.
Tryer is offline
post #704 of 1825 Old 09-02-2010, 09:12 AM
Peterpsc
No the gear did not fail in fact it's in excellent shape but I only have 10,300 miles.
IMHO, I believe it's the lack of lubrication and oil with insufficient amounts of zddp that's causing our problems but obviously the jury is still out.
Installed Hesco pump as a precautionary measure. FWIW, I've always used oil in the jeep with higher than average zddp ratings because of experience with "older" engines in muscle cars.
Along with the Hesco pump, I'm also adding a zddp additive. I'm not worried about catalytic failure...besides my engine isn't buring oil in significant amounts to cause catalytic failure from "too much" zddp. Purchased the zddp additive here: ZDDPlus™ - ZDDP Additive for Classic Cars - Agricultural Equipment & More
Installation of Hesco pump was on Monday of this week so no opportunity as yet to check for wear.
I don't know if this a permanent solution or a bandaid but I'm betting it'll help.
Peterpsc is offline
post #705 of 1825 Old 09-02-2010, 01:01 PM
rmeredit
Peterpsc - Can you tell us anything about the Hesco pump, and the installation of it? How is the quality compared to OEM? On your '06 LJ - did you have to modify the pan to install it? Wondering specifically about pan baffles as I haven't pulled one myself.
rmeredit is offline
2006 , 4.0 , camshaft , replacement , tj , warranty , wrangler
All jeep owners please read for better mpg jeepfreak_5 TJ Wrangler Technical Forum 77 06-26-2012 04:20 PM
Have you really read your owners manual JohnRodriguez JK Wrangler Technical Forum 2 09-14-2008 07:25 PM
97 owners please read!!!!!! river rat TJ Wrangler Technical Forum 33 01-31-2007 05:38 PM
FL Jeep Owners, Please Read siennaspilt TJ Wrangler Technical Forum 11 01-24-2004 03:05 PM
soft top owners - must read DrEvil TJ Wrangler Technical Forum 12 10-20-2003 06:38 AM
