Chrysler is paying to install a new cam (2005/2006 owners should read this) - Page 46 - JeepForum.com
post #676 of 1825 Old 09-01-2010, 12:45 AM
Terrible2
so aside from the oils, what has anyone done with aftermarket parts?
Terrible2 is offline
post #677 of 1825 Old 09-01-2010, 03:30 AM
bonza
in my area of the world Castrol wont publish zddp levels in their TDS anymore.
I queried the Castrol rep who supplies oil to my business and he was coy about it and said they arent aloud to disclose it
however he gave me a lab report for RX super 10w-40 diesel oil and it has a zddp of about 1200. and is suitable for mixed fleet being SL rated as well as diesel rated. thats what I will be using in the future. had been using a Havoline 10w-30 SL and havent any wear problems on the gear, but apparently that oil will be SM in the near future here
"I like a man who grins when he fights"
— Winston Churchill..
bonza is offline
post #678 of 1825 Old 09-01-2010, 08:01 AM
Sweeney
The comment by Hesco about Mobil 1 being "too slippery" makes zero sense. The problem with frictional wear is a lack of 'slipperyness'...
I made an observation. They guy I sold my '98 TJ too allowed me to pull the distributor to examine the gear. Though it obviously looks used it has very little wear. It also has 185K miles on it and it has gotten Mobil 1 10w30 at 10K mile intervals with filter changes every 5K miles the entire time.
I currently run Mobil 1 10w30 HM in my LJ Rubicon.
Sweeney is offline
post #679 of 1825 Old 09-01-2010, 08:38 AM
Peterpsc
I added the Hesco pump and ZDDP additive to Royal Purple 10-40.
Hesco Inc. - High Performance Engine Service
Peterpsc is offline
post #680 of 1825 Old 09-01-2010, 09:10 AM
DstroyrOfWrldz
I examined AutoZone's entire oil shelf yesterday looking for ACEA A3 certifications.
I found no conventional oils meeting ACEA A3.
Valvoline DuraBlend and Valvoline MaxLife Synthetic Blend were the only blends that met it.
Maxlife specs appear to have in the range of 800ppm Zinc/phosphorous.
http://www.valvoline.com/pdf/Maxlife.pdf
Here's a nifty link with what appears to be Mobil1's entire product line listing their certifications for each along with nominal zinc and phosphorous levels!
http://www.mobiloil.com/USA-English/...duct_Guide.pdf
Note that even the ACEA A3 oils still have zinc and phosphorous 1100ppm and below, while the motorcycle and racing oils have the highest (racing 0W30 and 0W50 say not recommended for street use)
15W50 looks interesting, as it has a high zinc/phosphorous concentration and it's recommended for high temp/high shear and specifically mentions flat tappets.
Joe
1999 Wrangler Sahara
2005 Wrangler Unlimited (Sold 9/2012)
DstroyrOfWrldz is online now
post #681 of 1825 Old 09-01-2010, 09:39 AM
Peterpsc
http://hesco.us/shop.asp?action=showpic&id=226889&header=false
Here's a picture of the Hesco pump showing the oiling tube spray device.
Peterpsc is offline
post #682 of 1825 Old 09-01-2010, 10:02 AM
DstroyrOfWrldz
that's pretty cool...I may need to look into the install complexity of the oil pump...can you do that without pulling the motor? most vehicles I've had put a crossmember too close to the pan to get it off without lifting the motor out.
Joe
post #683 of 1825 Old 09-01-2010, 10:30 AM
RubiOR
I would like to know this also. I need to pull the pan & replace the rear main seal one of these days. Might as well do the pump while I'm up to my elbows...
'06 Solar Yellow Rubicon Unlimited --
Their huge yellow spaceships hung in the air in exactly the same way that bricks don't. -- Douglas Adams, Hitch Hiker's Guide to the Galaxy
RubiOR is offline
post #684 of 1825 Old 09-01-2010, 10:33 AM
rmeredit
Well, I went out and checked my '06 LJ (1/8/06 Build Date). It has 37k currently. I am the second owner - the dealer did the work on it up until 34k. They changed the oil with Mopar 5w-30!?! every 3k for those 34k. I'm now running Mobil 1 High Mileage 10w-30 (ACEA A3 rating). The pattern is even on all teeth. There appears to be very little wear on the cam gear although I can't seem to get a decent pic of it. Thoughts?
rmeredit is offline
post #685 of 1825 Old 09-01-2010, 10:53 AM
Peterpsc
No need to pull the motor just the oil pan.
Peterpsc is offline
post #686 of 1825 Old 09-01-2010, 11:52 AM
DstroyrOfWrldz
yours looks very similar to mine - we appear to have caught it early enough that damage to the cam gear is likely very minimal. The marks on the cam gear are present, but they don't appear to have any significant "depth", meaning there hasn't been a lot of metal removed from the tooth face.
My plan of action is:
1. replace my gear with the one from pre-04 models (just arrived from Crown Auto)
2. use a good quality oil. I've currently got Castrol GTX 10W30 in it but will likely be switching. Haven't chosen which one just yet since I'm just now beginning to do that research. Maybe Valvoline MaxLife synth blend or Mobil1 High Mileage, 10W40 for either one, or something like Delo with a ZDDP level closer to 1200 depending on what I learn.
3. Monitor wear on new gear. If wear begins to show on the replacement gear I might start looking at this replacement oil pump.
Joe
post #687 of 1825 Old 09-01-2010, 12:11 PM
gunner87
Dstroyr,
Are you not going to add a zerk for the upper bushing? The folks over on the Rubicon forum swear that the upper bushing is seizing up and causing the gear wear. Just wondering.....I got my new OPDA from the stealership, and will pull my old one and take it to the machine shop. I will let those guys advise me on what they think are the best options.
2006 Wrangler Unlimited
42rle tranny
gunner87 is offline
post #688 of 1825 Old 09-01-2010, 02:12 PM
tkki1230
Originally Posted by gunner87 View Post
Dstroyr,
I don't think the problem is with the upper bushing. If you really look at the unit, all of the load is on the bottom bushing. That is where all the force is generated. I think that once that bushing wears, then tolerences get sloppy, and the gears get a little misaligned. There is a major difference between the 05-06 units and the earlier models. The older units have a groove in the shaft that forces oil upwards into the lower bushing. I purchased 3 different older units from ebay, all of them with fairly high mileage counts. They all have zero wear on the gear, and more importantly, zero wear on the shaft.
My 06 shaft is wasted in the area where it contacts the lower bushing, and it only has 60k miles. I'm pretty sure that the lower bushing area was putting significant resistance against the camshaft gear/oil pump because the lubrication was insufficient. The upper bushing area was dirty with caked up grease, but it did not add any significant resistance to the shaft. All it did was make a lot of noise (screaming monkeys). See post #650 for pics.
tkki1230 is offline
post #689 of 1825 Old 09-01-2010, 02:35 PM
TheFog
The problem is your gear and OPDA unit are NOT THE ORIGNAL units that were on the Jeep when it was built. None of 05 or 06 units had anything later than a REV-D unit when built. My 06 with a later build date than yours came with a REV-D unit.
In the last picture you show the label on your OPDA which states it as a REV-E with means its been replaced because the previous one failed.
Also Tikki don't think the top bushing isn't a problem. There area good amount of documented cases where the upper bushing starts making the howler monkey sound and then locks up to the point where it causes the OPDA assembly to spin around and rip the wires loose.
FOG
TheFog is offline
post #690 of 1825 Old 09-01-2010, 03:14 PM
DstroyrOfWrldz
Dstroyr,
Not immediately, but I'll be monitoring how well the shaft rotates every time I pull it out to check the gear. Right now it turns so freely it feels like it's on fresh roller bearings and there's no side play in it so there's no signs of a problem with the bushings so far. It's a Rev C.
Next time I have it out I may re-evaluated, I'm also a little thrown by the conflicting reports about how some seem to have an open passage to the bushing while others have nowhere for the grease to go.
Joe
2006 , 4.0 , camshaft , replacement , tj , warranty , wrangler
All jeep owners please read for better mpg jeepfreak_5 TJ Wrangler Technical Forum 77 06-26-2012 04:20 PM
Have you really read your owners manual JohnRodriguez JK Wrangler Technical Forum 2 09-14-2008 07:25 PM
97 owners please read!!!!!! river rat TJ Wrangler Technical Forum 33 01-31-2007 05:38 PM
FL Jeep Owners, Please Read siennaspilt TJ Wrangler Technical Forum 11 01-24-2004 03:05 PM
soft top owners - must read DrEvil TJ Wrangler Technical Forum 12 10-20-2003 06:38 AM
