Chrysler is paying to install a new cam (2005/2006 owners should read this) - Page 40 - JeepForum.com
post #586 of 1825 Old 08-17-2010, 03:35 PM
bonza
Originally Posted by anymanusa View Post
This was the gap before i relocated the gear, if id used the stock hole provided. Yes i said 'hole'.
how did you go with the Crown gear anymanusa?. did you drill a new hole in it to align up with the OPDA shaft?
I received one in the mail yesterday, just keeping it as a spare for the moment
"I like a man who grins when he fights"
— Winston Churchill..
bonza is offline
post #587 of 1825 Old 08-17-2010, 04:03 PM
Zetto
Zetto's Avatar
^^ I think you guys are making too big an issue of the 'uneven' wear. From my recollection of this thread, there weren't but one or two people who'd claimed uneven wear, and one was destoryerofworlds, and he recanted.
I gotta think gear profile is the culprit on this one.
This thread has now grown to 40 pages. After reading through all of it I still can not tell if I should be concerned...
I have an 06 LJ with an 02/06 build date. Is the general consensus that their is still no fix and all TJ are affected?
Should we be checking regularly for wear on the oil pump drive gear/camshaft synchronizer as part of routine maintenance?
ElJaynocibuR said he was receiving crank position sensor CEL codes and hearing noises. Is it to late at that point?
Zetto is offline
post #588 of 1825 Old 08-17-2010, 05:52 PM
DstroyrOfWrldz
I would recommend anyone with an 05-06 TJ w/ 4.0 pull their OPDA for inspection at every oil change.
If it's bad enough to be throwing codes and making noises, it will without a doubt need a new camshaft as well as the OPDA gear.
For those that have only "slight" wear, like mine, where the wear can be seen but the overall shape of the tooth is still mostly unaltered - just changing the OPDA gear should be sufficient. Only time will tell.
Joe
2005 Wrangler Unlimited (Sold)
DstroyrOfWrldz is offline
post #589 of 1825 Old 08-17-2010, 05:54 PM
anymanusa
it was the 4wd gear, and I made the tolerance what i wanted (shot for 0.015" ended up with 0.017") and drilled the first hole very carefully, then used the shaft with the gear hole lined up as a jig to drill through the second hole. I don't think you could ever get the holes lined up in your 'garage' without doing this, and I didn't feel like wasting a day at the machine shop after travel etc.
anymanusa is offline
post #590 of 1825 Old 08-18-2010, 06:19 AM
Sweeney
There is a possibility that, though not a new revision, the gear and/or other components may just be within spec.
My guess is that most of the individual components are from different manufacturers. It only takes one to produce an out of spec part that renders the assembly faulty.
Sweeney is offline
post #591 of 1825 Old 08-18-2010, 01:25 PM
TheFog
Just another option on getting a gear.
I was having a discussion with a neighbor that's a retired mechanic and spends his time building and selling hot rod engines.
He said there has been a HUGE problem with gears from China and other questionable sources causing allot of problems for aftermarket distributor manufactures. I showed him the gears and some pictures of camshaft damage that some of you have posted.
He took a quick look and went into his garage and pulled out several camshafts and aftermarket distributors for a Ford and two Chevys. The damage looked identical to what we are having.
His answer to the problem was ordering gears form NAPA made by their "Echlin Ignition" division. I went down and ordered one part number DG 402 at a whooping $50! But he swears by them and claims they are well worth the money.
As we have seen in the past with all kinds of stuff on our Jeeps that Chrysler will cut any corners and source cheap low quality parts to save a nickle. I think that is whats going on with the distributor gears. They got them from the cheapest supplier probably overseas and they are not cut to spec/out of tolerance.
FOG
TheFog is offline
post #592 of 1825 Old 08-18-2010, 02:39 PM
DstroyrOfWrldz
Is that DG402 a replacement for the 05-06 gear or the previous gear?
If it's for the 05-06 does that mean it would save us from redrilling a hole and it would be a simple matter of replacing the roll pin?
Oh btw, for those that have ordered the Crown or the 4WD gear, did it come with a new roll pin?
Joe
post #593 of 1825 Old 08-18-2010, 03:06 PM
Savage1969
The Crown part has no new roll pin, only the gear.
Other toys: 2007 Shelby GT, 2004 2500HD 4X4, 2005 Raptor 660 LE, 2004 KFX400, 2004 Kubota Grand L3130
Savage1969 is offline
post #594 of 1825 Old 08-18-2010, 05:57 PM
DstroyrOfWrldz
oh great, so who knows where to get a new roll pin? Or have y'all just been reusing the old one?
Joe
post #595 of 1825 Old 08-18-2010, 06:39 PM
TheFog
The NAPA DG 402 does come with new a roll pin, and no its not a "catalog" replacement for a 05-06. The DG402 is specified in the catalog as a replacement for the mid 90s all the way to 2004 4.0 engine.
As far as the holes being the same I have several OPDA assemblies. One of them is from a 05, one is my "REV-B" that came with my 06 LJ and the other one is a "REV-E" that I bought back in May. I've had the gears off all three and NONE of them will line up with the holes on the others.
So the issue of having to re-drill the hole is something I don't think can be avoided. Plus I think it would be advantageous to be able to reduce the excessive end play that the factory seems to leave when putting the gears on.
FOG
TheFog is offline
post #596 of 1825 Old 08-18-2010, 07:24 PM
DstroyrOfWrldz
ok...well I'll have to see where the 4WD gear was made when it shows up. If it's made anywhere other than the USA I'll be heading straight for NAPA.
Joe
post #597 of 1825 Old 08-18-2010, 07:33 PM
Sweeney
Roll pins can be purchased at any decently stocked hardware store or online... not a make or break deal...
Sweeney is offline
post #598 of 1825 Old 08-18-2010, 08:54 PM
bonza
just received mine. there was nothing to indicate it was made in USA, so it could be from anywhere. noticed that the image for the NAPA DG402 has only one hole drilled as well. guess that is so when you align the hole in the gear to the shaft you can drill and ream to get a precise fit.
I am going to accurately measure up the spare gear for size and concentricity and then do a hardness check
some mechanical parts made in China can be dodgy. had some expensive components made there that failed on commissioning due to poor heat treatment. found supporting documents had been falsified. never again
bonza is offline
post #599 of 1825 Old 08-19-2010, 08:12 AM
Savage1969
FYI, according to NAPA, these are the specs on the DG402:
# Distributor Drive Gear Teeth : 13 Teeth
Distributor Gear & Pin I.D. : 0.5324"- 0.5332"
Distributor Gear & Pin O.D. : 1.03"
Distributor Gear Height : 1.031"
Distributor Gear Pitch Direction : Right Hand
It appears to have about the same hole placement as the Crown gear, correct me if I'm wrong here.
post #600 of 1825 Old 08-19-2010, 08:50 AM
speed_phreak
Very interesting! I just received my Crown gear too, but I think you have sold me on the NAPA part. Since I have to take this damn thing to a machine shop, I would rather have it done right the first time. Especially since I dont have any spare parts! I don't mind spending a couple more dollars on a known good part... HEAR THAT CRYSLUR???
I appreciate everyone sharing their knowledge and experience... Just think if we were all fighting this on our own, yikes... I'm just a computer geek with a knowledge of systems and a fascination with automobiles, not so much a mechanic.
speed_phreak is offline
2006 , 4.0 , camshaft , replacement , tj , warranty , wrangler
All jeep owners please read for better mpg jeepfreak_5 TJ Wrangler Technical Forum 77 06-26-2012 04:20 PM
Have you really read your owners manual JohnRodriguez JK Wrangler Technical Forum 2 09-14-2008 07:25 PM
97 owners please read!!!!!! river rat TJ Wrangler Technical Forum 33 01-31-2007 05:38 PM
FL Jeep Owners, Please Read siennaspilt TJ Wrangler Technical Forum 11 01-24-2004 03:05 PM
soft top owners - must read DrEvil TJ Wrangler Technical Forum 12 10-20-2003 06:38 AM
