Chrysler is paying to install a new cam (2005/2006 owners should read this) - Page 25 - JeepForum.com
post #361 of 1825 Old 08-05-2010, 06:49 PM
Volusiaguy
1995 XJ Cherokee
Thanks!
Originally Posted by bonza View Post
J3181288 is the Mopar part number for the seal where the CPS drive assembly fits into the motor. the part number is out of the official Mopar parts listing for 2005 Wranglers and is listed in "group 8 sensors 610 sensors engine" and is item 4. would imagine the same for all years
as far as needle bearings go, I havent pulled my CPS assembly apart yet to measure it up and work out what SKF part numbers will fit
Volusiaguy is offline
post #362 of 1825 Old 08-05-2010, 07:17 PM
2006_Sport
Originally Posted by Volusiaguy View Post
Ok...here's my experience and the information I was able to gather over the last few days....I had the chattering monkey syndrome, pulled the CPS, had some unusual wear that was just starting on the gear and some markings that needed to be smoothed and polish off of the shaft by a machine shop. The shaft and bearing were fine. Re-greased, re-installed, and we'll check up on it in a couple of months, but it is running great and seems to be better than new....all for a total cost of $72.
Here are my ideas and notes to add to what has been posted before. Thanks to all of you who have been posting to this for your ideas and help in getting this resolved...at least for now:
Check your gearing using the instructions in this thread. If you have a problem (even if it's making the chattering monkey sound), contact Chrysler to get a case number so you can add to their embarrassment and data base:
Contact Us by Telephone:
1-800-853-1403
M-F 8:00A.M. - 5:00P.M.
(U.S. Continental Time Zones
Since they probably won't/can't help you without a part, here are your options at this point:
Option #1: Part number: 53010624AC Distributor Oil Pump ($112-150 from a dealer or from:
Jeep OEM Parts
Jeep OEM Parts
Mopar Parts for Dodge, Chrysler and Jeep: MoparPartsAmerica
This part is back-ordered in the US/Canada/everywhere else. The number of back-orders was 237 as of 8/5/10. The companies listed above will let you order them, but you will receive an Indefinite Backorder Email within a day or two saying that they have no determined date for delivery. You may want to get on this list to have a backup in case they ever DO fix it.
Option #2: Repair package part number: 1-CDC0E51AB $32
Chrysler did send out a Replacement/Repair package in 05 to their dealers to deal with this issue. The part number above consists of a kit that contains the bottom gear, a new gasket, a brass mounting flange, a mounting pin to hold the gear to the shaft, and a one-time drill bit to drill out the mounting hole on the new gear. (My gear already had two holes opposite of each other to use and they thought the drilling option was idiotic at best..
Take this kit and your old part to a machine shop, have them polish the shaft and install the new gear and check/replace the upper sealed bearing, and you will be good as new.
My guy did mine for $40 total. The bearing was in great shape, so they cleaned up the shaft, greased up the bearings again, put it all together, and we're good to go.
Option #3: Order the gear itself from the following vendors.
4WD Hardware: BOTTOM GEAR - RETAIL:
Distributor Drive Gear by Crown Automotive and Other Jeep Parts and Jeep Accessories by 4 Wheel Drive Hardware-RH3
Crown Automotive (BOTTOM GEAR - WHOLESALE):
Distributor Gear (2.5L, 4.0L) | Crown Automotive Sales
Part #83504635
Option #4: Buy or find a 99-04 CPS unit from EBAY or a junkyard for like 20 bucks and pull the gear of it.
You will also need to order the gasket for any of the options above (minus the Chrysler repair kit as it already has one included). The part number from Chrysler is J3181288. (I'm pretty sure that the gaskets from a 2002-2003 distributor oil pump would work too since they seem to have the same base. It's a flat, fiber, round gasket that fits around the base of the assembly, so you could probably find a substitute by trial and error at your local auto parts dealer.)
I did talk to my machinist about installing a zerk fitting to lube the bearings, BUT my 2006 model had a sealed bearing assembly and the location of the zerk would have led to nothing but a dead end. It seems Chrysler may have made some adjustments to the manufacturing process after 05, but I'm not positive about this. My Jeep was build on 12/05 and I still had the chattering monkey syndrome and unusual wear on the gear and binding on the shaft.
That's all I have for now. Post or PM me if you have any questions, and I'll keep you posted as this moves along.
Dave
AWESOME post dave...awesome. Going with option 2 or 3
2006_Sport is offline
post #363 of 1825 Old 08-05-2010, 07:21 PM
TheFog
Don't take this the wrong way but your machinist didn't look hard enough.
My CPS of my 06,a CPS from a late 04 and the new CPS I got from Chrysler all have the passages behind the plug.
The problem is if you just pull the plug and scrap out the yellowish grease inside it will look like a dead end. What I did was put some heavy degreaser in the hole and rub a Q-tip around in the bottom. After about 2-3 times of that it because VERY aparent when looking in with a flash light that there is about 2-3MM of clearence between the bushing and the end of the hole.
This space feeds down into a cavity with runs around the the CPS shaft and allows grease to be feed in just below the bottom of the upper bushing.
The problem is the grease has gotten so hot its turned to sludge or carbon so if you just try blowing on the hole with compressed air all you will hear is just a VERY faint hiss inside the shaft tube.
What I did with mine was put it in boiling water till it was nice and hot then laid it on its side with the soon to be zerk fitting hole up and used a eye dropper to fill it with heavy degreaser again.
After that I washed it out and fitted the ZERK fitting and as I pumped the ZERK fitting I watched the grease flow out inside the shaft tube on all three CPS assemblies.
So there is a passage there its just easy to miss if your not looking really hard for it.
FOG
In memory of Samantha Sue 1998 to Dec-16-10 at 2:15PM. She may have had 4 legs and a tail but she was the best friend I ever had and helped me through some really tough times. I hope to see her again one day.
TheFog is offline
post #364 of 1825 Old 08-05-2010, 07:39 PM
Unlimitedlou
Originally Posted by roadkill View Post
I wonder if it's feasible to have a machine shop press out the old bushing(s) and install a new one with a seal at the top of the assembly so that engine oil will lube the shaft from bottom to top?
Refer to my post #195. My gear looked fine and the top bushing was wore out. I had a machine shop install a oil impregnated brass bushing in its place. 2K miles later and no problems.
2005 Unlimited Rubicon, too much junk to list!-sold
2012 JKU Orange Crush
Unlimitedlou is offline
post #365 of 1825 Old 08-05-2010, 07:58 PM
TJJP77
TJJP77's Avatar
Are you sure it wasn't a bronze bushing? That seems like it would be more typical for this type of application.
Chris
'02 Sahara
'06 Rubicon Unlimited
Sienna Jeep Club: Member #15
TJJP77 is offline
post #366 of 1825 Old 08-05-2010, 08:03 PM
piperpilot3tk
Today I pulled my CPS assembly again and removed the factory blanking plug to install a zerk fitting. I cleaned out the passage with brake cleaner and the passage dead ended at the upper bushing with no passage for the grease to get to the shaft, I verified this with a really bright light and 150 PSI of air pressure. I then grabbed my old '96 distributor that I robbed the gear from and pulled the shaft out and removed the blanking plug from the housing with the same results, NO passage for the grease. One interesting thing I did find was the '96 distributor has bushings that are set up exactly like the '06 CPS assembly. The only difference I could find is the shaft from the '96 distributor is MUCH harder, so obviously a properly hardened shaft will run mostly dry in the upper busing for quite some time, but I still think the design is pure crap!!! So my solution was to drill a hole through the upper bushing with a #40 drill bit and tap the housing and install a grease fitting with 8mm diameter threads. Pumped the CPS full of Mobil 1 SHL-100 synthetic grease. Reinstalled and all is good. Hopefully this will be a long term fix!
piperpilot3tk is offline
post #367 of 1825 Old 08-05-2010, 08:05 PM
Volusiaguy
1995 XJ Cherokee
FOG
Not at all...this is a group deal, right? I'm going to take a look at it again and I may go with a zerk anyway if what you say is right. It's possible that they missed it since they did not pull the bearing. Might not be a bad thing for me to check when I do the checkup on it. Thanks for the head's up.
post #368 of 1825 Old 08-05-2010, 08:08 PM
RubiOR
Can I get this online or is it a "go to the dealer" item? I tried both of the links with no luck but perhaps my search-foo is off tonight.
'06 Solar Yellow Rubicon Unlimited --
Their huge yellow spaceships hung in the air in exactly the same way that bricks don't. -- Douglas Adams, Hitch Hiker's Guide to the Galaxy
RubiOR is offline
post #369 of 1825 Old 08-05-2010, 08:09 PM
snobank
Cps
Thats right, recall E05 MAR 2005 Campaign - Engine Oil Pump Drive Gear/Cam Replacement .
it might fall under it, here is a vin breakdown letter etc
Revised June 2005
Dealer Service Instructions for:
Customer Satisfaction Notification E05
Oil Pump Drive Gear
A revised drive gear parts package has been released. The second roll pin hole must be drilled in the revised drive gear.
2005 (TJ) Jeep(R) Wrangler
NOTE : This notification applies only to the above vehicles equipped with a 4.0L eligible ("S" in the 8th VIN position) and an engine build code between 902944 (October 20, 2004) and 900325 (February 1, 2005).
IMPORTANT : Some of the involved vehicles may be in dealer vehicle inventory. Dealers should complete this repair on these vehicles before retail delivery. Dealers should also perform this repair on vehicles in for service. Involved vehicles can be determined by using the VIP inquiry process.
Subject
The oil pump drive gear on about 16,000 of the above vehicles may wear out prematurely and cause engine failure due to a loss of oil pressure.
Repair
The camshaft position sensor/oil pump drive assembly date code label must be inspected. Units within a specific date code range must have the drive gear replaced.
All unsold vehicles must have the oil pump drive gear replaced prior to retail delivery to eliminate the risk of engine failure due to premature oil pump drive gear wear. On sold vehicles, the cam/crank angle must also be checked with the DRB III scan tool. Engines found with excessive cam/crank angle must have the oil pump drive gear and the engine camshaft replaced.
Alternate Transportation
Dealers should attempt to minimize customer inconvenience by placing the owner in a loaner vehicle if inspection determines that an engine camshaft is required and the vehicle must be held overnight.
Parts Information
Special Tools
The Special Tools may be required to perform this service procedure.
Completion Reporting and Reimbursement
Claims for vehicles that have been serviced must be submitted on the DealerCONNECT Claim Entry Screen located on the Service tab. Claims submitted will be used by DaimlerChrysler to record Customer Satisfaction Notification service completions and provide dealer payments.
Use one of the labor operation numbers and time allowances shown.
Add the cost of the parts package plus applicable dealer allowance to your claim.
NOTE : See the Warranty Administration Manual, Recall Claim Processing Section, for complete claim processing instructions.
Dealer Notification
All dealers will receive a copy of this dealer notification letter by mail. Two additional copies will be sent through the DCMMS. This notification can be viewed on DealerCONNECT by selecting "Global Recall System" on the Service tab, then clicking on the description of this notification.
Owner Notification and Service Scheduling
All involved vehicle owners known to DaimlerChrysler are being notified of the service requirement by mail. They are requested to schedule appointments for this service with their dealers. A generic copy of the owner letter is included.
Enclosed with each owner letter is an Owner Notification postcard to allow owners to update our records if applicable.
Vehicle lists, Global Recall System, VIP and Dealer Follow UP
All involved vehicles have been entered into the DealerCONNECT Global Recall System (GRS) and Vehicle Information Plus (VIP) for dealer inquiry as needed.
GRS provides involved dealers with an updated VIN list of their incomplete vehicles. The owner's name, address and phone number are listed if known. Completed vehicles are removed from GRS within several days of repair claim submission.
To use this system, click on the "Service" tab and then click on "Global Recall System." Your dealer's VIN list for each recall displayed can be sorted by: those vehicles that were unsold at recall launch, those with a phone number, city, zip code, or VIN sequence.
Dealers should perform this repair on all unsold vehicles before retail delivery.
Dealers should also use the VIN list to follow up with all owners to schedule appointments for this repair.
VIN lists may contain confidential, restricted owner name and address information that was obtained from the Department of Motor Vehicles of various states. Use of this information is permitted for this notification only and is strictly prohibited from all other use.
Additional Information
If you have any questions or need assistance in completing this action, please contact your Service and Parts District Manager.
Customer Services Field Operations
DaimlerChrysler Corporation
Wed Apr 14, 2010 3:40 pm
Display posts from previous: All posts1 day7 days2 weeks1 month3 months6 months1 year Sort by AuthorPost timeSubject AscendingDescending
Page 1 of 2
[ 25 posts ] Go to page 1, 2 Next
Portal » Board index » Tech » Technical Jeep Talk
Who is online
snobank is offline
post #370 of 1825 Old 08-05-2010, 08:29 PM
Volusiaguy
1995 XJ Cherokee
Piper,
I talked about this possibility with my machinist, and he didn't feel comfortable drilling into the housing as he felt that it might lead to premature failure of the bearing. I'm somewhat beyond my learning curve on this and I don't have anything to look at....any chance of that happening?
post #371 of 1825 Old 08-05-2010, 08:30 PM
snobank
The local dealer here wont even look at it,says" there is no signs so dont worry about it,did not affect your vin.Theres nothing we can do or see if its not acting up""This is bull,im not the most mech.inclined and want a dealer to look at ,im willing to pay but this guy would not do anything,does anyone know any dealers in mass that is up to date on this sort of stuff other than this one in raynham ma
snobank is offline
post #372 of 1825 Old 08-05-2010, 08:30 PM
Volusiaguy
1995 XJ Cherokee
It's a go to the dealer item. They can do a search for them and have them sent out from other dealers that have them in stock.
post #373 of 1825 Old 08-05-2010, 08:37 PM
roadkill
did they move the oil seal to allow more lubrication?
roadkill is offline
post #374 of 1825 Old 08-05-2010, 08:37 PM
Unlimitedlou
There have been absolutely zero in stock for some time now. There are 7 at local dealers in "off road" status. That means the dealer has Jeeps sitting in their lot that customers can not drive. As of last week, there are over 250 drives on back order with none in production and no parts in production. About 6 weeks ago there was 1 in Hawaii and I tried to get it. All of a sudden it was gone and there have been no more on the dealer parts locator since then.
post #375 of 1825 Old 08-05-2010, 08:39 PM
TheFog
I don't know what to say honestly. Even after running degreaser though it and heating it I could just VERY faintly hear a little hiss in the cps shaft hole when I applied about 200LB of nitrogen. Even then it took several VERY hard pumps of the grease gun to break it loose.
Doctor D over on ROF has a post even showing where he fitted a temp zerk fitting. http://i23.photobucket.com/albums/b3...e/DSC06550.jpg
But instead of all that work I guess just drilling a hole in the side of the upper bushing and fitting it with a zerk would work just fine.
FOG
TheFog is offline
2006 , 4.0 , camshaft , replacement , tj , warranty , wrangler
All jeep owners please read for better mpg jeepfreak_5 TJ Wrangler Technical Forum 77 06-26-2012 05:20 PM
Have you really read your owners manual JohnRodriguez JK Wrangler Technical Forum 2 09-14-2008 08:25 PM
97 owners please read!!!!!! river rat TJ Wrangler Technical Forum 33 01-31-2007 06:38 PM
FL Jeep Owners, Please Read siennaspilt TJ Wrangler Technical Forum 11 01-24-2004 04:05 PM
soft top owners - must read DrEvil TJ Wrangler Technical Forum 12 10-20-2003 07:38 AM
