Chrysler is paying to install a new cam (2005/2006 owners should read this) - Page 2 - JeepForum.com
post #16 of 1825 Old 02-12-2010, 12:42 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Originally Posted by Knuckelhead View Post
And the TSB number for this is???
IIRC this issue is from mid 2005 to the end of production for the 4.0L...
NHTSA Item Number : 10013784
http://www.allworldauto.com/tsbs/NHT...etin_9419.html
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #17 of 1825 Old 03-11-2010, 10:18 PM
percle
Just towed mine to Jeep Dealer with same problem
Dec 05 Build date - LJ Rubicon: I was having same symptoms (P0340, P0344, ...) with engine noise, loss of power, etc. It would barely turn over when trying to start, finally start but would die suddenly.
Took the cam synchronizer shaft out and it looked like the one in the picture (with damage inside the engine as well). I guess I start my fight with Chrysler tomorrow to see if they will pay for the damage. Mileage is only 16K so let's see what excuses they come up with!!
percle is offline
post #18 of 1825 Old 03-12-2010, 07:45 AM Thread Starter
ElJaynocibuR
Chrysler will want you to get it diagnosed by a local dealership first. It shouldn't be that much of a fight. It was actually pretty easy for me.
This problem is very common for 2005-2006's. I wish everyone would take the time to check their gears before it causes serious engine damage.
2006 LJ Rubicon=4" lift, 305/70/16 Mickey T.'s MTZs, etc...
ElJaynocibuR is offline
post #19 of 1825 Old 03-12-2010, 07:55 AM
pbjb25
pbjb25's Avatar
Does this apply if you have exceeded your 30k warranty?
pbjb25 is offline
post #20 of 1825 Old 03-12-2010, 08:08 AM
percle
Just heard from the dealer: According to their records (from another Jeep dealership now out of business), it was replaced in 05. His shop foreman is out today so won't hear anything until Monday. Could they be dumb enough to replace it with the same defective part
percle is offline
post #21 of 1825 Old 03-12-2010, 08:11 AM Thread Starter
ElJaynocibuR
I had 65k miles when they fixed mine
post #22 of 1825 Old 03-12-2010, 09:54 AM
element54
element54's Avatar
Hmmm, I'll check mine this weekend.
Why is there so much space down here?
element54 is offline
post #23 of 1825 Old 03-12-2010, 10:50 AM
aRedRocker
I haven't pulled a distributor since I had a 258, do these new ones rotate from side to side and move the timing? Is there a cap you can pull and mark the rotor like the old days? Pardon my ignorance, just want to see ahead of time what I'm getting in to.
aRedRocker is offline
post #24 of 1825 Old 03-12-2010, 11:01 AM
popeyesides
Me too, I have 10k miles on mine and want to check this weekend as well, Is it as easy check as it sounds.
popeyesides is offline
post #25 of 1825 Old 03-12-2010, 11:04 AM
FREEDOM1
Crawled until I find my build date. No issues to date.
Jeeps are like women, they're always better topless and dirty
¡¡¡¡ɹƎΛO ˥˥Oɹ SIH┴ p∀Ǝɹ ┴,N∀Ɔ ∩O⅄ ℲI
If you're going the speed of light and your turn your headlights on, what happens?
FREEDOM1 is offline
post #26 of 1825 Old 03-12-2010, 03:05 PM
popeyesides
Just pulled mine out and looked at it and it has wear marks on it but that should be normal I think. It does not look as bad as the picture though. I did just call dealer and he looked up my vin # and said mine is not one of them under the tsb. The service guy said he will talk to District guy and let me know Monday if they want me to bring it in and inspect it. He said a TJ came in today for this. My build date is 11/05 with 10k miles. My Jeep is running just fine but I checked it because of this thread.
post #27 of 1825 Old 03-12-2010, 03:13 PM
popeyesides
I have been getting random misses and crank position snesor codes. I have tried 2 new sensors and still getting the code. I think the slack in the gears is causing the crank/cam sensors to be out of sync. That's just a guess as of now, but that is what led me searching for things and I found this. I then called chrysler and was told to get it diagnosed at a dealer, so id id. They then decided to cover it under the recall. I have 64k miles. Sorry for the crappy grammar, I'm posting from my phone and its not easy to do.
Can you tell me who or what dept. or phone number you called at Chrysler because I would like to follow up on this and see if they will at least have it inspected to make sure mine is not going south. Thanks
post #28 of 1825 Old 03-12-2010, 03:21 PM
pbjb25
pbjb25's Avatar
Just called, my VIN does not fall within this TSB
pbjb25 is offline
post #29 of 1825 Old 03-12-2010, 05:30 PM
Nick B
Something doesn't add up .It was made in Dec of 05 and it was replaced in 05 ?
Nick B is offline
post #30 of 1825 Old 03-12-2010, 05:33 PM
Nick B
Who did you call, the dealer or DC ?
Nick B is offline
2006 , 4.0 , camshaft , replacement , tj , warranty , wrangler
All jeep owners please read for better mpg jeepfreak_5 TJ Wrangler Technical Forum 77 06-26-2012 04:20 PM
Have you really read your owners manual JohnRodriguez JK Wrangler Technical Forum 2 09-14-2008 07:25 PM
97 owners please read!!!!!! river rat TJ Wrangler Technical Forum 33 01-31-2007 05:38 PM
FL Jeep Owners, Please Read siennaspilt TJ Wrangler Technical Forum 11 01-24-2004 03:05 PM
soft top owners - must read DrEvil TJ Wrangler Technical Forum 12 10-20-2003 06:38 AM
