Chrysler is paying to install a new cam (2005/2006 owners should read this) - Page 12 - JeepForum.com
post #166 of 1825 Old 05-13-2010, 04:27 AM
TJJP77
TJJP77's Avatar
Originally Posted by X-Treme View Post
Anyone know what years of these things are the same? Like.... is an OPD out of a 2000 the same as one out of an 06? Or are they not interchangeable at all?
I need one, because mine is squealing really bad, BUT they are on national back-order with no guarantee of delivery until MAYBE late August.
My Jeep is not driveable in this condition, and this is unacceptable at this time of year.
I'm thinkin of goin with a used one for now, but need to know what years will fit in what other years.
They only used this type of Cam Sensor drive housing/gear on 2005 and 2006 TJs - it was intended to coordinate with the newer style engine computer that they switched to in 2005, so earlier units will not work.
Chris
'02 Sahara
'06 Rubicon Unlimited
Sienna Jeep Club: Member #15
TJJP77 is offline
post #167 of 1825 Old 05-13-2010, 04:33 AM
TJJP77
TJJP77's Avatar
Oh, by the way - if your dealer is willing to do it, there are a number of dealers here in the US that have one of these in stock. Your dealer can just use the "parts locate" feature in their parts system to see the parts, assuming it will show them US dealers as well as Canadian dealers. Even if it won't show them US dealers, I would have to think that a few dealers in Canada have one on the shelf...
Chris
'02 Sahara
TJJP77 is offline
post #168 of 1825 Old 05-13-2010, 04:51 AM
TheFog
My local dealer had to do this to find me a new cam sensor drive unit. There was only one dealer near Houston that had one. I asked the dealer why they were so scarce and he said the cannot keep them on the shelf.
FOG
TheFog is offline
post #169 of 1825 Old 05-13-2010, 06:11 AM Thread Starter
ElJaynocibuR
EDIT Just saw that you are in Canada. Shipping may be more that I originally thought. pm me.
I think the 05s and 06's were unique and are not interchangable. I have one that has 65k miles on it and only needs a new gear. It's not squealing. Send me $40 and I'll ship it to you.
2006 LJ Rubicon=4" lift, 305/70/16 Mickey T.'s MTZs, etc...
ElJaynocibuR is offline
post #170 of 1825 Old 05-13-2010, 06:34 AM
TheFog
My old one was just fine except it needs a new gear. Do you have a part number for just the new gear? I would like to put a new gear on my old one for a spare.
FOG
TheFog is offline
post #171 of 1825 Old 05-13-2010, 08:03 PM
remery829
subscribing.... mine just started doing a weird idle jumping from about 900 rpm to 1600 after coming to a stop
Ryan
vvvthis is what they don't tell you about LCGvvv
...I went with the lcg method but its never ending be because once you fix one thing something else breaks or needs upgrading...
SUPPORT OUR TROOPS
remery829 is offline
post #172 of 1825 Old 05-13-2010, 08:09 PM Thread Starter
ElJaynocibuR
Good luck...Try the easy fixes first. I would start by taking the throttle body off and cleaning the hell out of it. Make sure you clean the IAC really good.
post #173 of 1825 Old 06-10-2010, 10:25 AM
okie1
First thanks to all the folks who contribute thier knowledge here. I have an '05 with 35k body build date 4/05 haven't checked the engine build date or # on the assembly. Having no issues now except for the extreme paranoid feeling every time I drive it now. I am assuming that mine is bad (hopefully not too bad). As the second owner I assume I have no recourse as to warranty, my thought is to locate a new assy. from the dealer and replace the old one myself, but it sounds as though I will not be able to "time" it correctly. Seems I will have to take it to the stealer to have that done. If all this seems right then would I be able to line it up close enough to get it started and limp it to the dealer to have it timed or just take it there to begin with.
okie1 is offline
post #174 of 1825 Old 06-10-2010, 11:04 AM Thread Starter
ElJaynocibuR
I would just take it to the stealership and let them check it. That way they can put it back correctly the 1st time. You'll have to have them diagnose it if it's bad anyway, if you want Chrysler to pay for it.
post #175 of 1825 Old 06-10-2010, 11:43 AM
TheFog
If his Jeep is a 05 Chrysler isn't going to pay for it because this isn't a recall its TSB only.
Unless you bough the extended warranty from Chrysler they are not going to cover it. I've heard of a small few that have gotten theirs covered only because the dealership decided to step up and do the right thing (very rare).
Since yours is out of warranty I would ask around and find a really good honest dealership even if you have to drive a good bit to get it there.
That being said, I just had to check mine and it ended up being bad so I had to replace it also. I did the work myself and grand total was $130.00
The timing isn't an issue if you use a timing pin. The way to do this is take the two torx screws off the cover of your current CPS. In the bottom left part of the bowl there is hole in the bottle and there is a hole in the wheel that turns. All you have to do is slowly turn the engine (either via the crank pulley or if its a standard slowly push it like I did) until the hole in the wheel lines up with the hole in the bottom up the cup.
Once they are lined up stick allen wrench through them lock them in place. You can now unbolt the CPS assembly and pull it loose. You can inspect the CPS gear and reinsert it back into the block and the timing will stay the same.
Also if you decide you need a new CPS assembly the new ones come with a timing pin installed. So all you need to do is just stick it in (along with a new gasket) and tighten down the holder screw and then just pull the timing pin out your ready to run.
IF you use the timing pin hole the only way to screw up the timing is by moving the engine while you have the CPS housing removed.
FOG
TheFog is offline
post #176 of 1825 Old 06-10-2010, 12:56 PM
okie1
thanks for the quick replies folks, Fog did you get that part from the dealer and if so did you have any problem with availability? Really appreciate the info on the timing pin, I believe I can do this job myself now. Thanks again
okie1 is offline
post #177 of 1825 Old 06-10-2010, 01:25 PM Thread Starter
ElJaynocibuR
FOG,
Have you read any of this thread? My 06 had 65k miles when Chrysler paid around $1000 to replace the camshaft synchronizer and the canshaft. I was waaay out of warranty. A couple of calls to chrysler and 2 visits to the dealership is all took to get them to PAY for the TSB.
just remember there are 2 gears there. If the one on the camshaft synchronizer is going bad, get a flashlight and look at the gear on the cam itself.
post #178 of 1825 Old 06-11-2010, 10:02 PM
meatlord
Maximum Disaster
meatlord's Avatar
Let me know how your diagnosis goes, right now I have the same Idle issue. 52xxx miles, Mfr date 12/04, Camshaft Position Sensor Date Code Label is 4326, "if your numbers are between 4297 and 4364 the TSB EO5R will pertain to you."
Looks like Im calling the dealer on monday. Anyone have advice on how to deal with dealer/chrysler? Also what kind of internal damage are we actually dealing with?
05 Rubicon "Big Stupid" / 99 XJ on 31s "Nurple" SOLD. / 07 WK Limited CRD GDE Hot Tuned DPF delete. / 00 TJ "One Shot Wonder"/ 12 Altima 3.5 SR CVT / 00 Suzuki DR650.
meatlord is offline
post #179 of 1825 Old 06-11-2010, 10:15 PM
TJJP77
TJJP77's Avatar
Depends on a lot of factors...if you are lucky, the only damage will be on the cam sensor drive gear. If it has progressed further, the camshaft will have some damage to the helical gear that drives the cam sensor. Much further than that, and the cam sensor drive gear can become so worn/stripped that cam sensor/oil pump drive stops turning (engine will keep running as long as it crank position signal) and therefore the oil pump stops turning...you can guess what happens from there.
The other concern I have is even if the wear is localized to cam sensor gear and/or the camshaft, the wear process that has been occuring up to the point it is discovered/repaired is putting small metal particles into the oil and possibly into the engine bearings if they are small enough to get through the filter.
Chris
'02 Sahara
TJJP77 is offline
post #180 of 1825 Old 06-14-2010, 04:33 PM
Unlimitedlou
Originally Posted by Sccafire View Post
I circled the Camshaft Position Sensor Date Code Label. On the second row of numbers the first 4 numbers are the date code. if your numbers are between 4297 and 4364 the TSB EO5R will pertain to you. If your numbers are lower than 4297 or higher than 4364 you will not need replacement. This is according to Alldata that I have for my 2005 TJ. You may not have to remove it to see the label. Try using a small mirror to read it.
I got the P0016 and P0344 codes today with limp mode. I checked my date code and it is 4308. How do I get to the Alldata that you have? I am waiting for Chrysler to call me back now. I need all the ammo I can get!
2005 Unlimited Rubicon, too much junk to list!-sold
2012 JKU Orange Crush
Unlimitedlou is offline
2006 , 4.0 , camshaft , replacement , tj , warranty , wrangler
All jeep owners please read for better mpg jeepfreak_5 TJ Wrangler Technical Forum 77 06-26-2012 04:20 PM
Have you really read your owners manual JohnRodriguez JK Wrangler Technical Forum 2 09-14-2008 07:25 PM
97 owners please read!!!!!! river rat TJ Wrangler Technical Forum 33 01-31-2007 05:38 PM
FL Jeep Owners, Please Read siennaspilt TJ Wrangler Technical Forum 11 01-24-2004 03:05 PM
soft top owners - must read DrEvil TJ Wrangler Technical Forum 12 10-20-2003 06:38 AM
