Chrysler is paying to install a new cam (2005/2006 owners should read this) - Page 115 - JeepForum.com
post #1711 of 1825 Old 10-25-2012, 08:59 AM
nsummers82
Thanks for the input. Just got a quote from the dealership. $950 just for the labor. Seems ridiculously high. Can I just replace the pump drive, or do I need to replace the entire assembly?
nsummers82 is offline
post #1712 of 1825 Old 10-25-2012, 09:08 AM
flying_bosun
$950?! That is insane! I can remove, inspect, modify and replace an OPDA in about 45 minutes. You really need to check out the linked thread, get a new OPDA and StripperGuy retrofit kit and DIY or have someone reasonable mod and swap it for you. I can do the retrofit for you, and anyone with a 1/2" box wrench and the ability to read can do the install.
Originally Posted by Ron Paul
“Liberty is lost through complacency and a subservient mindset. When we accept or even welcome automobile checkpoints, random searches, mandatory identification cards, and paramilitary police in our streets, we have lost a vital part of our American heritage. America was born of protest, revolution, and mistrust of government. Subservient societies neither maintain nor deserve freedom for long.”
― Ron Paul
"Did you exchange your walk-on part in the war for a lead role in a cage?"
flying_bosun is offline
post #1713 of 1825 Old 10-25-2012, 09:44 AM
Bigbob
Bigbob's Avatar
Ditto on the rape. Call the police. Take names and get a lawyer.
How is your mechanical skills?
Replacing the unit is pretty simple and straight forward.
You can get someone on this forum to modify your unit for you if you ask nice. Get on the other thread with this issue. Look for "2005-06 Jeep OPDA_CPS_Distributor Failure" look at the first page real close. If you pull yours make darn sure you line those holes up before you loosen a bolt. The bottom of the first page has videos and pictures which explain all. If you have the ability to change a tire and have some simple tools replacing the OPDA is simple. You can PM many of us and we can walk you through it.
I would wager the $950.00 price tag included replacing the camshaft as well. If it didn't I'd stay away from that shop.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
post #1714 of 1825 Old 10-25-2012, 01:09 PM
nsummers82
I'll opt to do it myself. I have tools and a garage and as long as I have instructions I shouldn't have any issues. Guess when I get home I'll mark everything, pull it out and see just how bad it is. Any an all help is greatly appreciated!!
post #1715 of 1825 Old 10-25-2012, 02:01 PM
Bigbob
Bigbob's Avatar
I would not mark it. Look at the clocking video on page 1.
Watch this:
http://www.youtube.com/watch?feature...&v=McrtZ6ptSWY
6 Speed, Hardtop
Bigbob is offline
post #1716 of 1825 Old 10-25-2012, 02:47 PM
flying_bosun
Watch this:
I pull the cap and do short clicks with the ignition to get the TDC/pin holes lined up. Or you can turn the crank by hand to get there, too.
― Ron Paul
post #1717 of 1825 Old 10-27-2012, 02:03 PM
SolidusJ
I'm assuming this is what's going on with my buddy's jeep.
Trying to help out my buddy that hurt his jeep a few days ago. He went up the cliff that only he can make up 3x, in the video below when he made it to the top and was at 3,500 RPM with his 5 speed. Turned off the jeep and then went to turn it back on and it had a clicking sound in the block check gauges light was on and check engine. 3 camshaft codes came up and also the oil pressure wasn't moving at all. I know the piston is slapping the valves, we went down 5 miles and the jeep shut off and the clicking was getting louder. We pulled the oil cap and smoke was coming out more then it should. Before I rip into his jeep I'm hoping you guys would know what's happening so I can get it up and running sooner. We are shipping out to afghanistan soon and any info would be great. 05 jeep unlimited with a 5 speed.
http://www.youtube.com/user/TheSolidusJ?feature=plcp
SolidusJ is offline
post #1718 of 1825 Old 10-27-2012, 02:31 PM
jkp
The oil pressure gauge showed 0?
'92 Islander
'06 Rubicon
jkp is offline
post #1719 of 1825 Old 10-27-2012, 02:45 PM
SolidusJ
Damn near.
SolidusJ is offline
post #1720 of 1825 Old 10-27-2012, 04:29 PM
jkp
Probably broke the OPDA gear which drives the oil pump. Not good.
On the '05 and '06s, the oil pressure gauge is just a glorified idiot light. There is a pressure switch that closes at around 6 psi, at which point the computer moves the pressure gauge to mid-scale.
At less than 6 psi, the computer moves the gauge to the low end and turns on the check gauges light.
'92 Islander
'06 Rubicon
jkp is offline
post #1721 of 1825 Old 10-27-2012, 04:33 PM
flying_bosun
Which codes were tripped?
― Ron Paul
post #1722 of 1825 Old 10-27-2012, 04:42 PM
SolidusJ
There was 3 codes and they all. One of them was Crankshaft Position Camshaft Position Correlation code, the others was cam position and cam sensor.
SolidusJ is offline
post #1723 of 1825 Old 10-27-2012, 04:43 PM
SolidusJ
Is there a factory latter for the E05 recall? The jeep's manufacture date 11/2004.
SolidusJ is offline
post #1724 of 1825 Old 10-27-2012, 05:16 PM
flying_bosun
There wasn't a recall. It was a technical service bulletin
― Ron Paul
post #1725 of 1825 Old 10-27-2012, 05:26 PM
SolidusJ
OK so jeep is going to give us a big F you when we try to get them to fix it? He just bump the engine and it tried to to kick over so it not locked up.
SolidusJ is offline
2006 , 4.0 , camshaft , replacement , tj , warranty , wrangler
All jeep owners please read for better mpg jeepfreak_5 TJ Wrangler Technical Forum 77 06-26-2012 05:20 PM
Have you really read your owners manual JohnRodriguez JK Wrangler Technical Forum 2 09-14-2008 08:25 PM
97 owners please read!!!!!! river rat TJ Wrangler Technical Forum 33 01-31-2007 06:38 PM
FL Jeep Owners, Please Read siennaspilt TJ Wrangler Technical Forum 11 01-24-2004 04:05 PM
soft top owners - must read DrEvil TJ Wrangler Technical Forum 12 10-20-2003 07:38 AM
