Chrysler is paying to install a new cam (2005/2006 owners should read this) - Page 114 - JeepForum.com
post #1696 of 1825 Old 03-21-2012, 04:50 PM
CoRubicon
Originally Posted by mudmachine25 View Post
Found a place with some new opda's. Had 8 down to 5. For 05-06.
http://www.ebay.com/itm/260964187439...84.m1497.l2649
price is 143
You can get them cheaper from dodge-wholesale.com
http://dodge-wholesale.com/catalog/p...ucts_id=221662
And even cheaper than that price if you call and talk to Mike V. in parts, ask for the Jeep Club discount. Thanks to flying bosun for the hook up.
http://www.jeepforum.com/forum/f9/20...l#post13137394
Wishing your son the best.
Jim
CoRubicon is offline
post #1697 of 1825 Old 03-29-2012, 08:31 PM
mudmachine25
Junior Member
mudmachine25's Avatar
Here is picks of my gear.
mudmachine25 is offline
post #1698 of 1825 Old 03-29-2012, 08:43 PM
flying_bosun
Looks rather similar to my original unit. Any shots of the cam gear, perhaps?
Originally Posted by Ron Paul
“Liberty is lost through complacency and a subservient mindset. When we accept or even welcome automobile checkpoints, random searches, mandatory identification cards, and paramilitary police in our streets, we have lost a vital part of our American heritage. America was born of protest, revolution, and mistrust of government. Subservient societies neither maintain nor deserve freedom for long.”
― Ron Paul
"Did you exchange your walk-on part in the war for a lead role in a cage?"
flying_bosun is offline
post #1699 of 1825 Old 03-29-2012, 10:28 PM
mudmachine25
Junior Member
No. Couldnt get pics of cam. From studying what i seen, I think it may be possible the oil pump is some of the cause of the problem. The end of the shaft that turns the oil pump had a wear mark like the oil pump is dragging and causing strain on the end of the shaft and causing drag on shaft which is causing wear on the gear.
post #1700 of 1825 Old 03-30-2012, 04:17 AM
BioTex
1979 CJ7
That's a very interesting theory! I too noticed a bit of wear on the drive side of the shaft where it fits into the pump slot. Might be considered normal wear IDK, but it is evident.
My new OPDA arrived today, so will install it, and if I still get the ticking, will most likely drop the pan.
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is offline
post #1701 of 1825 Old 03-30-2012, 06:17 AM
doublins
The wear on the oil pump shaft is normal and every distributor or opda you pull out of any 4.0 I6 from YJs up through your year will show it- unless you're running an HV pump, the pump is not the cause of your issues.
98 TJ Street Sleeper- 408ci Stroked Magnum V8
My Magnum V8 Build Thread:
doublins is offline
post #1702 of 1825 Old 04-01-2012, 07:57 PM
czechsky
Is there a video of a new OPDA install showing the turning of the crank to tdc etc buried somewhere in this or any other thread that someone can direct me to? I am that kind of amatuer that prefers a visual when doing something the first time. Thanks.
czechsky is offline
post #1703 of 1825 Old 04-01-2012, 09:25 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
Described here mostly on post 5 & photos further down.
http://www.jeepforum.com/forum/f9/op...-help-1347545/
You don’t have to pull the #1 plug as described there. When you line the small hole in the wheel with the hole in the bottom of the housing you will be on TDC #1.
There is some video on the long first page of the main OPDA thread & it is worth reading that page. It doesn’t show the TDC method but relies on marking the wheel. Either way will work.
http://www.jeepforum.com/forum/f9/20...ilure-1144202/
Rubi4MyMrs is offline
post #1704 of 1825 Old 04-02-2012, 09:35 PM
czechsky
Exactly what i needed, even if it isn't a video. Thanks a million!
czechsky is offline
post #1705 of 1825 Old 04-03-2012, 12:38 AM
lucky06
This is great info.
lucky06 is offline
post #1706 of 1825 Old 06-07-2012, 09:07 AM
2006X
This thread has helped me alot with my 06 same problem as everyone else. It is at dealership now waiting to see what Chrysler
is going to do about it i only have 28k miles where on the motor can i find the build date
2006X is offline
post #1707 of 1825 Old 06-07-2012, 09:20 AM
Fusco
2016 JK Wrangler
1% of me says dump it for a newer Jeep.
99% of me loves my TJ too much to toss her away.
Driving it until warranty is up and i'll toss in a 4bt or V8.
I could never drive the Super Plastic JKs
2016 Jeep JK 2D Sport S
2006 Jeep TJ Rubicon Impact Orange - SOLD :-)
Fusco is offline
post #1708 of 1825 Old 06-07-2012, 02:35 PM
2006X
Just heard from jeep. Dealership told jeep OPDA was not the problem. So i guess no help coming from jeep
Great!
2006X is offline
post #1709 of 1825 Old 10-24-2012, 08:20 PM
nsummers82
So, I have been dealing with this terrible squealing for the past two days and found out where it is coming from. The same as everyone else. I can't seem to get the cover off to check the gears for wear, but I assume that's the issue. Should I park it until I can get it to the dealership? I'll have to check on the build date to see if its part of the TSB...
nsummers82 is offline
post #1710 of 1825 Old 10-25-2012, 04:04 AM
flying_bosun
Great!
The dealership told Jeep/Chrysler that your OPDA was not the problem or the Jeep dealership told you that it wasn't the problem? It's easy to self-diagnose and if it is bad, then you might try a different dealership. Y'all have read the first 10-12 as well as the more recent posts in the willydigger thread, right? http://www.jeepforum.com/forum/f9/20...ilure-1144202/
Yes, stop running it (it'll eat your cam) and the build date and tsb are irrelevant.
― Ron Paul
2006 , 4.0 , camshaft , replacement , tj , warranty , wrangler
All jeep owners please read for better mpg jeepfreak_5 TJ Wrangler Technical Forum 77 06-26-2012 04:20 PM
Have you really read your owners manual JohnRodriguez JK Wrangler Technical Forum 2 09-14-2008 07:25 PM
97 owners please read!!!!!! river rat TJ Wrangler Technical Forum 33 01-31-2007 05:38 PM
FL Jeep Owners, Please Read siennaspilt TJ Wrangler Technical Forum 11 01-24-2004 03:05 PM
soft top owners - must read DrEvil TJ Wrangler Technical Forum 12 10-20-2003 06:38 AM
