Chrysler is paying to install a new cam (2005/2006 owners should read this) - Page 113 - JeepForum.com
post #1681 of 1825 Old 02-06-2012, 08:05 PM
26679cj5
Originally Posted by chris142 View Post
I had to sand mine down with emery paper. Had to remove quite a bit.
How do you make sure to sand it evenly around the entire thing?
26679cj5 is offline
post #1682 of 1825 Old 02-06-2012, 08:08 PM
chris142
Well how much are you talking? IIRC I had to remove about .015 to get mine to go in the hole. I just held the emery paper in one hand and spun the OPDA with the other hand and kept trying it untill it fit.
It's been in there for about 10,000 miles now and is ok so far.
chris142 is offline
post #1683 of 1825 Old 02-06-2012, 10:17 PM
\\WK//
I pulled my OPDA tonight and it appears to be worn. Experts please chime in and let me know what you think my next steps should be. I'm the 3rd owner, so I don't really know the history with it, but it has about 64K on it.
image-1625222301.jpg   image-2971386900.jpg   image-901429440.jpg   image-625885389.jpg
\\WK// is offline
post #1684 of 1825 Old 02-07-2012, 08:24 AM
flying_bosun
Not claiming to be an "expert", but how did the shaft spin? Perfectly smooth or less than? Punch out the roll pin to inspect the upper bushing area. If it spins freely and the upper bushing area looks ok, you could reinstall it an run it till it or your cam dies, them rebuild the top end. If its binding at all, you should replace it (and I'd say use the old gear on the new OPDA 'cuz the new gear I believe will accelerate cam gear wear).
Originally Posted by Ron Paul
“Liberty is lost through complacency and a subservient mindset. When we accept or even welcome automobile checkpoints, random searches, mandatory identification cards, and paramilitary police in our streets, we have lost a vital part of our American heritage. America was born of protest, revolution, and mistrust of government. Subservient societies neither maintain nor deserve freedom for long.”
― Ron Paul
"Did you exchange your walk-on part in the war for a lead role in a cage?"
flying_bosun is offline
post #1685 of 1825 Old 02-07-2012, 12:38 PM
willydigger
Mine began to fail at 60K. I had binding. Like Bosun said, check to see how well it spins. This is the issue the FogMod will address. The wear is another issue that at this point has no hard and fast answer. I would suggest you FogMod this unit or buy a new one and FogMod it. Change your oil to a higher ZDDP variant and you should be in good shape for a while. At this point (in my OPDA adventures) I'm a little less concerned about gear wear and a little more concerned about preventing the shaft from binding.
willydigger is offline
post #1686 of 1825 Old 03-20-2012, 07:08 PM
mudmachine25
Junior Member
mudmachine25's Avatar
Looks like i will be having to get mine done. Took it out today and gears in bad shape. Forgot to take picture. My son is having open heart surgery Thursday so a lot on my mind. Will take it out again when I get back home and things settle down. Called Chrysler and told them what I found. Will bring to a dealer when I get a chance and let them look at it. Think mine has done quit a bit of damage. Jeep running stupid, sounds like monkeys under valve cover with ball pin hammers. Keep getting cylinder number 5 miss fire and multiple cylinder miss fire on the codes. Only 32,000 miles. Will see what Chrysler rep say when they call tomorrow. Has anyone had there oil pressure get stupid high than drop real low?
mudmachine25 is offline
post #1687 of 1825 Old 03-20-2012, 07:19 PM
jkp
If you're talking about the factory oil pressure gauge, all it tells you is that you have at least 6 psi. It's not a real pressure gauge, the computer looks for a switch to close and then moves the needle to the middle position.
'92 Islander
'06 Rubicon
jkp is offline
post #1688 of 1825 Old 03-20-2012, 07:25 PM
aRedRocker
Prayers for your Son Mudmachine.
aRedRocker is offline
post #1689 of 1825 Old 03-20-2012, 07:34 PM
mudmachine25
Junior Member
Thanks
post #1690 of 1825 Old 03-20-2012, 09:29 PM
Black05Rubi
Fact
10 chars
Originally Posted by bradthebard
I prefer puppies. Works equally well on irate drivers and motorcycle gangs. I tried kittens but they kept sticking to my hands when I tried to throw them...
Member of Black Jeep Society
Black05Rubi is offline
post #1691 of 1825 Old 03-20-2012, 09:52 PM
Heath
2014 JK Wrangler
God bless your son.
Where are you located?
2013 JKU Rubicon
Heath is offline
post #1692 of 1825 Old 03-21-2012, 04:32 AM
BioTex
1979 CJ7
Best wishes for your son!
Please report back what Chrysler says.
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is offline
post #1693 of 1825 Old 03-21-2012, 08:58 AM
Peterpsc
Please add my name to the list wishing your son the best.
Pete.
Peterpsc is offline
post #1694 of 1825 Old 03-21-2012, 10:14 AM
Rubi4MyMrs
Rubi4MyMrs's Avatar
Makes OPDA problems look small, doesn't it? Hope all goes well for your son tomorrow.
Rubi4MyMrs is offline
post #1695 of 1825 Old 03-21-2012, 12:52 PM
mudmachine25
Junior Member
Found some new opda's
Found a place with some new opda's. Had 8 down to 5. For 05-06.
http://www.ebay.com/itm/260964187439...84.m1497.l2649
price is 143
2006 , 4.0 , camshaft , replacement , tj , warranty , wrangler
All jeep owners please read for better mpg jeepfreak_5 TJ Wrangler Technical Forum 77 06-26-2012 04:20 PM
Have you really read your owners manual JohnRodriguez JK Wrangler Technical Forum 2 09-14-2008 07:25 PM
97 owners please read!!!!!! river rat TJ Wrangler Technical Forum 33 01-31-2007 05:38 PM
FL Jeep Owners, Please Read siennaspilt TJ Wrangler Technical Forum 11 01-24-2004 03:05 PM
soft top owners - must read DrEvil TJ Wrangler Technical Forum 12 10-20-2003 06:38 AM
