Chrysler is paying to install a new cam (2005/2006 owners should read this) - Page 110 - JeepForum.com
post #1636 of 1825 Old 04-14-2011, 03:08 PM
JeepScrap
Anyone have a link for the LDI website? Can't seem to find anything being that there are 4 billion companies named LDI.
"Science will win in a battle with religion because it works." -Stephen Hawking
JeepScrap is offline
post #1637 of 1825 Old 04-14-2011, 03:39 PM
chutta
LDI Incorporated
05x 4.0 6sp 30/35, aussie front, 3.73's, r/c 4"x lift, adv adptr sye, shifter bracket, tw cv ds, 33 t/c skid, 33x12.5 dunlop mud rovers on steelies, psc sport cage/rockers, warn fr bump/steer and 30 diff skid, sirius,cb, hand throttle 1"bl/mml 265/16's pepboys at's on orig moabs for street. Lowrance H20c for gps
chutta is offline
post #1638 of 1825 Old 04-14-2011, 04:03 PM
JeepScrap
Thx chutta...I thought that was them but I wasn't sure.
post #1639 of 1825 Old 04-17-2011, 06:45 PM
jeeper92
Here is my damage from cam
Trouble shooting thread
http://www.jeepforum.com/forum/f9/he...l-4-a-1122566/
Roads? Where we're going, we don't need roads.
jeeper92 is offline
post #1640 of 1825 Old 04-17-2011, 07:04 PM
TJJP77
TJJP77's Avatar
Looks like that could have been a lobe hardening issue - if it were oil related, all the lobes would have had similar wear.
Chris
'02 Sahara
'06 Rubicon Unlimited
Sienna Jeep Club: Member #15
TJJP77 is offline
post #1641 of 1825 Old 04-20-2011, 10:52 PM
coppertop71
coppertop71's Avatar
1990 XJ Cherokee
One thing we notice on this is the #4 intake cam lobe doesn't not sit centered when looking down into the lifter hole. Once the lifter wore the lobe down enough you can see marks where it rode on the shaft area becasue it was offset about 10% off the lobe. Ive seen this problem before when someone upgrades a cam and lobes dont sit properly for all the lifters holes.
This could possibly by part of the problem with OPDA gear issues if the gear set is unmatched for proper gear mess due to improper cam alignment. It could be assume if someone has a problem with OPDA then it wont be long before the lifter & lobe wears out.
Mods
2006 Jeep Wrangler X, 4.0 4:11 gears
'90 Cherokee XJ,W/'91 4.0L reman/ 3.5" RE lift, W/31" M/S tires, 4:11 Gears W/Speedo gear change/ Aluminum Coolant Tank
A/C Conversion/Home Built Roof Rack/K&N Box Filter
Derale 15" Rigid Radiator Fan PT# DER-17415, through Summit W/2"X5/8X5/8"" spacer
coppertop71 is offline
post #1642 of 1825 Old 05-31-2011, 06:55 PM
cmceleste
Does anyone know where I can get just the gear?
cmceleste is offline
post #1643 of 1825 Old 05-31-2011, 08:53 PM
coppertop71
1990 XJ Cherokee
I pulled every distributor from 5 XJ 4.0's ranging in early 90's to late from our junkyard the gear was the same and they all had the same wear so I took one that was worn the least.
Mods
post #1644 of 1825 Old 05-31-2011, 09:38 PM
Rubi4MyMrs
Rubi4MyMrs's Avatar
Crown makes one. They are available through 4 Wheel Parts. They are listed for ’04 & earlier. Should work. Need to finish drilling 2nd hole
http://www.4wd.com/productdetails.aspx?partID=11465
Dorman has a complete ’04 OPDA with a gear that is supposed to work by re drilling it.
Rock Auto has them I think the # is DORMAN 689-200. It is called Camshaft Synchronizer. It is $32.
Hesco has a bronze gear that may or may not be for street use. Its $89 I think.
CHECK YOUR CAM GEAR!
Rubi4MyMrs is offline
post #1645 of 1825 Old 07-09-2011, 08:48 AM
GMBNT42
OK, my 05' Unlimited has a build date of 10/04 and I called up a Jeep dealership and they punched in my VIN # and said the E05 recall does not apply to me at all. DOes this mean I have the old style OPDA with the "oil groove" in the shaft?
FWIW my 4.0L engine has 89k on the odometer, I pulled the head, the lifters and camshaft look brand new still, no signs of wear anywhere, but I have yet to pull the OPDA............
GMBNT42 is offline
post #1646 of 1825 Old 07-09-2011, 04:08 PM
Heath
2014 JK Wrangler
Post pics of the cam gear area on the camshaft.
2013 JKU Rubicon
Heath is offline
post #1647 of 1825 Old 07-09-2011, 04:31 PM
DocMojave
Has this turned into an official chrysler recall now?
Never Mistake Kindness for Weakness. What is desired in a man is kindness, And a poor man is better than a liar.
DocMojave is offline
post #1648 of 1825 Old 07-09-2011, 06:10 PM
grnberet2b
lol
grnberet2b is offline
post #1649 of 1825 Old 07-09-2011, 06:17 PM
Heath
2014 JK Wrangler
Errr, no.
2013 JKU Rubicon
Heath is offline
post #1650 of 1825 Old 07-09-2011, 06:48 PM
DocMojave
That's what I thought. The thread title really needs to be updated.
2006 , 4.0 , camshaft , replacement , tj , warranty , wrangler
All jeep owners please read for better mpg jeepfreak_5 TJ Wrangler Technical Forum 77 06-26-2012 04:20 PM
Have you really read your owners manual JohnRodriguez JK Wrangler Technical Forum 2 09-14-2008 07:25 PM
97 owners please read!!!!!! river rat TJ Wrangler Technical Forum 33 01-31-2007 05:38 PM
FL Jeep Owners, Please Read siennaspilt TJ Wrangler Technical Forum 11 01-24-2004 03:05 PM
soft top owners - must read DrEvil TJ Wrangler Technical Forum 12 10-20-2003 06:38 AM
