Chrysler is paying to install a new cam (2005/2006 owners should read this) - Page 107 - JeepForum.com
post #1591 of 1825 Old 02-05-2011, 11:56 PM
motorsports3
1997 XJ Cherokee
Im sorry but this is a really long thread. I am about to buy an 06. Will Chrysler still fix this issue? Is it a legit recall?
motorsports3 is offline
post #1592 of 1825 Old 02-06-2011, 12:09 AM
ff33
No it is not a recall. If it is under warranty they will "fix" it. However the fix currently is they install a new gear or opda that is identical to the faulty ones, so it will most likely fail again. Some have gotten the fix even while not under warranty, some have been reimbursed after paying out of pocket and others have been told to f off. Just depends who you talk to it seems.
2006 Rubicon LJ, auto, 2" lift, 1.25 bl, mml, tt, armor, winch, 33's, that's it for now.
ff33 is offline
post #1593 of 1825 Old 02-06-2011, 12:12 AM
motorsports3
1997 XJ Cherokee
Thats pretty dumb. Is this a big enough deal for me to shy away from an 05-06? I have to check the production date on the prospect.
post #1594 of 1825 Old 02-06-2011, 12:57 AM
ff33
Production doesn't seem to matter, all 05-06 use the same opda so the general consensus is they will all fail prematurely. If you read the thread some members have been experimenting with some possible fixes but nothing has been run long enough to determine long term results, however short term results have been promising. Also the replacement opda's are on a major back order right now so if you do need one it is going to be a long wait. There is a condensed thread available that is an easier read as well. As far as not buying one is up to you. Obvisouly the people having the issue are posting up more than the ones with out issues. From reading the threads I can only recall one member checking their opda that did not have premature gear wear and that was a pretty recent post.
ff33 is offline
post #1595 of 1825 Old 02-06-2011, 07:51 AM
kgginslc
And that was on a replacement gear, if I'm thinking of the same one as you. So they were on their second gear with an unknown number of miles.
kgginslc is offline
post #1596 of 1825 Old 02-07-2011, 08:12 AM
uf20wop
i bought my 06 tj a couple weeks ago
my build date is mid-late '06 (don't remember exactly)
i plan on pulling the OPDG this week some time
i'll report one way or the other
uf20wop is offline
post #1597 of 1825 Old 02-23-2011, 01:11 PM
Gold79Fever
I've got a 2005 TJ with approximately 14,000 miles.
The 8th VIN position has an "S".
Build date says 05/05.
Part in question is:
LDI Inc.
Part # 53010624AC
105103-REV-B
So does this mean this part will fail also?
How will I know when it is getting close? Do I head to the dealer ASAP?
Thanks for your heads-up to all Jeepers on this.
Gold79Fever is offline
post #1598 of 1825 Old 02-23-2011, 01:54 PM
uf20wop
VIN doesn't matter... just some BS by Jeep is seems.
if you're mechanically inclined at all you can do it yourself... takes probably 30 minutes.
uf20wop is offline
post #1599 of 1825 Old 02-23-2011, 02:26 PM
Xlr8n
1967 JK Wrangler
LDI Inc.
Part # 53010624AC
105103-REV-B
Keep in mind the OPDA is a two part problem with the unit itself. One being insufficient shaft bushing lubrication, the second being premature gear wear. The shaft issue may well increase the gear wear, but both can occur independent of each other.
Of the two, the greatest risk of abrupt failure is with the shaft seizing up due to lack of lubrication and busting up the gear which will then likely contaminate the motor with metal fragments. But, even though the lubrication with the unit is flawed by design, not all OPDA units are having shaft bushing issues. Some seem to operate just fine as is. Obviously if all were having problems, there'd be thousands of broken down '05-'06 Jeeps by now.
All of the units seem to have a gear wear issue in which the gear will continue to wear until there is enough slop to throw a code at which point the OPDA needs replaced. In some circumstances the wear can involve and include the cam gear itself which is a much more labor and cost intensive ordeal than the OPDA gear.
My rig has over 60k on it and the OPDA gear is at the point where it will need replaced soon before it wears to the point that it throws a code. It had no tell-tale signs of anything being wrong until I checked it. Shaft still spins fine.
The whole issue is not the end of the world, but it is indeed a problem that needs to be monitored at the least, and more likely replaced when needed and/or modified at most.
A re-design by the manufacturer would be the ideal solution.
Xlr8n is offline
post #1600 of 1825 Old 02-23-2011, 02:29 PM
willydigger
LDI Inc.
Part # 53010624AC
105103-REV-B
You need to pull the unit. Go to the OPDA Failure thread (link below) for instructions and a video. You're mileage is low so it may only have minor wear. If your gear is still serviceable you can do the FogMOD (also described fully in the below link) and likely be okay. We are still looking into potential problems with the lower bushing, however in my experience the top bushing is the one to address ASAP.
The VIN and PN of the OPDA has no real value. While a faulty gear may have been a factor in the beginning, time has shown us that the OPDA design is poor. All 2005-06 Jeeps have this OPDA, so there is a high likelihood that yours will fail if you do nothing.
http://www.jeepforum.com/forum/f9/20...ilure-1144202/
willydigger is offline
post #1601 of 1825 Old 02-23-2011, 02:51 PM
Gold79Fever
Thanks for all of your quick replies. I just "accidentally" found this thread (waiting to win a trailer!!) today so now have a new project to work on.....just what we all need.
Hope a fix to this problem comes along really soon.
post #1602 of 1825 Old 02-23-2011, 03:15 PM
ChaseB
It's not that there are OPDAs out there that are fine, it's just that the vast majority of 05-06 owners are oblivious to the problem. Some OPDAs may last longer than others for various reasons, but the issue here is that all of them will eventually fail.
1984 CJ-7 Renegade
2005 TJ X (daily driver)
ChaseB is offline
post #1603 of 1825 Old 02-23-2011, 03:23 PM
Xlr8n
1967 JK Wrangler
I' have to disagree with that blanket statement.
I know of several '05-'06 TJ's with over 100k on them that have not had any issues at all with the OPDA as far as codes or failure. Are the gears worn? Likely, but they are still functioning just fine.
Just because the gears examined here look and are worn excessively does not mean they will all ultimately fail completely.
Xlr8n is offline
post #1604 of 1825 Old 02-23-2011, 04:15 PM
ChaseB
I wasn't willing to chance it. Who knows when the gear teeth will wear thin enough to chip off? Different driving habits, oils, too many variables to say when or if it will fail. I guess some may sell or trade in before a failure occurs.
1984 CJ-7 Renegade
ChaseB is offline
post #1605 of 1825 Old 02-25-2011, 11:24 PM
amcjeepman
amcjeepman's Avatar
I have an '05 LJ Rubicon w/ 56k miles I have owned since new and always used Mobile 1 in it. I will be checking OPDG this weekend or this comming week. So far no chirping. Will take pictures as well and most likely do fogmod.
James Belcher, Jr
Carolina Trailblazers PR
86 CJ7 401 TF999
81 CJ7 360 T177
05 Rubicon Unlimited
and others ;)
amcjeepman is offline
2006 , 4.0 , camshaft , replacement , tj , warranty , wrangler
All jeep owners please read for better mpg jeepfreak_5 TJ Wrangler Technical Forum 77 06-26-2012 04:20 PM
Have you really read your owners manual JohnRodriguez JK Wrangler Technical Forum 2 09-14-2008 07:25 PM
97 owners please read!!!!!! river rat TJ Wrangler Technical Forum 33 01-31-2007 05:38 PM
FL Jeep Owners, Please Read siennaspilt TJ Wrangler Technical Forum 11 01-24-2004 03:05 PM
soft top owners - must read DrEvil TJ Wrangler Technical Forum 12 10-20-2003 06:38 AM
