Chrysler is paying to install a new cam (2005/2006 owners should read this) - Page 104 - JeepForum.com
post #1546 of 1825 Old 01-22-2011, 10:46 AM
jkp
Ideal is 0 degrees.
'92 Islander
'06 Rubicon
jkp is offline
post #1547 of 1825 Old 01-22-2011, 10:57 AM
cmceleste
Thanks.
Does anyone know where I can get a replacement and about how much it'll cost? Obviosly the dealership has them but I have read they often go on backorder. Thinking about buying one just to have incase it slips again.
Sucks Chrysler does nothing about this...
cmceleste is offline
post #1548 of 1825 Old 01-22-2011, 11:00 AM
ChaseB
Originally Posted by cmceleste View Post
Thanks.
The dealer doesn't have any but you can try, best case scenario is February 14th, you may want to try some online stores, none of which will have any in stock now though.
I got mine at dodge-wholesale.com (well I paid for it, hoping to get it on the 14th!)
1984 CJ-7 Renegade
2005 TJ X (daily driver)
ChaseB is offline
post #1549 of 1825 Old 01-22-2011, 11:21 AM
cmceleste
Does anyone know what degree sets off the check engine light? 11.3 is when I finally scanned it, its at 1.3 now. Just curious to see what degree sets the check engine light.
post #1550 of 1825 Old 01-22-2011, 11:25 AM
jkp
15 degrees, IIRC.
'92 Islander
'06 Rubicon
jkp is offline
post #1551 of 1825 Old 01-23-2011, 12:56 PM
airframer
airframer's Avatar
Thanks.
I found it for bout $100 on mopper websites. Glad this thread is here. I noticed mine getting low while replacing my crank.
Everything in moderation
airframer is offline
post #1552 of 1825 Old 01-23-2011, 01:14 PM
steitsma
Can you just add STP Oil Treatment to your oil and get the same result as opposed to using the more expensive oil with the higher levels of zinc?
steitsma is offline
post #1553 of 1825 Old 01-23-2011, 01:21 PM
airframer
airframer's Avatar
Here found just the gear section here http://www.jeep4x4center.com/product...689200#details
post #1554 of 1825 Old 01-23-2011, 01:23 PM
ChaseB
That is for 02-04 (modifications would need to be made to have it work on 05-06)
1984 CJ-7 Renegade
ChaseB is offline
post #1555 of 1825 Old 01-23-2011, 01:23 PM
willydigger
That won't work for the 2005-06. They are completely different. That may be a way to get a good replacement gear. Also if anyone gets one for the gear or for comparison to the 2005-06 model post up some pics.
willydigger is offline
post #1556 of 1825 Old 01-23-2011, 01:27 PM
willydigger
I don't think anyone really knows the ZDDP level in that. Also what effect with it have on the oil? If the Mobil 1 is too pricey, you can be our STP guinea pig. Try it, document it, and post the results.
You could probably get 6-qts of dino oil and a filter for $25. Add the STP for $5. You'd save about $20 over using Mobil 1 5w40 TDT. FOG will know more. I don't really know anything about oil.
post #1557 of 1825 Old 01-23-2011, 01:28 PM
TheFog
The problem with the STP oil treatment is its not just ZDDP its a bunch of viscosity modifiers which make your oil much thicker IE heavier weight. The reason for this is STP markets this stuff for people that have older high mileage engines that have larger bearing clearances and burn oil which will benefit from the thicker oil.
Unless your 4.0 has a huge amount of miles on it (like over 150,000) all the STP additive is going to do is cause your engine to get less oil flow because of the thicker oil.
There are products like ZDDP plus that do add zinc and phos without any modifiers but they are around $10 a bottle IIRC.
The other issue is the quality of the oil you put the ZDDP in. There is a reason that the European car markers got away from the API certification because its standards allowed a wide variance from really good high quality synthetics all the way to really cheap crappy oil. Which basically has allowed the oils of today to not be as good as the ones 10 years ago.
So to deal with this car makers like BMW, Benz, ETC created the ACEA rating system. So if you want a quality oil to put the ZDDP in then buy a ACEA rated oil. But your back where you started because the 5W-40 TDT is a ACEA rated oil .
Honestly with whats at stake just spend the extra $15 when you change your oil and get the right oil.
On a side note I've ran Mobil one 10W-30 in my 01 4Runner for the first 100K then switched to 5W-40 TDT till where I am now at 300K. I pulled the valve cover yesterday to replace the seal and the engine looks brand new, no varnish or oil staining. And this is a engine that has been plagued with the sludge issue.
Mobile one and the 5W-40 TDT oils are very much worth the money.
In memory of Samantha Sue 1998 to Dec-16-10 at 2:15PM. She may have had 4 legs and a tail but she was the best friend I ever had and helped me through some really tough times. I hope to see her again one day.
TheFog is offline
post #1558 of 1825 Old 01-23-2011, 01:34 PM
willydigger
I'm going to add this to the failure thread.
post #1559 of 1825 Old 01-23-2011, 01:36 PM
steitsma
thanks for the clarification, i will just go with mobil 1 when i'm ready to do my next change, i know its been asked but what weight mobil 1 should i go with so i remember to pick it up next time! thank you!
steitsma is offline
post #1560 of 1825 Old 01-23-2011, 01:42 PM
05LongJeep
Well I tore into mine this morning. I had pulled it earlier to check for wear but didn't have time to do a full inspect. I was actually suprised at the lack of scoring. I went with the 45 degree grease zirk for my "Fog Mod". But I think my in stock viper lube may be a little thick. Really a waste of time though, My gear is approaching the Down Hill Run on the gear tooth. This has got me thinking. How many Wrangler drivers have an extra vehicle? I had just bought a 96 Accord when I stumbled upon this thread. I was thinking the LJ would forever have low miles. Thanks to JEEP its mandatory! I think I'll go test drive a Tacoma today!!!
Stock till its paid off 2008 Jeep Wrangler Unlimited 4dr. JK
Loved & Lost due to Faulty OPDA--2005 Jeep Wrangler Unlimited LJ. Rough Country 2.5" Lift w/Stearing Stab. R/C sway bar discos. 31x10.50, Hella Windshield Lights & A Never Ending List of Dreams
05LongJeep is offline
2006 , 4.0 , camshaft , replacement , tj , warranty , wrangler
All jeep owners please read for better mpg jeepfreak_5 TJ Wrangler Technical Forum 77 06-26-2012 05:20 PM
Have you really read your owners manual JohnRodriguez JK Wrangler Technical Forum 2 09-14-2008 08:25 PM
97 owners please read!!!!!! river rat TJ Wrangler Technical Forum 33 01-31-2007 06:38 PM
FL Jeep Owners, Please Read siennaspilt TJ Wrangler Technical Forum 11 01-24-2004 04:05 PM
soft top owners - must read DrEvil TJ Wrangler Technical Forum 12 10-20-2003 07:38 AM
