Chrysler is paying to install a new cam (2005/2006 owners should read this) - Page 103 - JeepForum.com
post #1531 of 1825 Old 01-21-2011, 02:16 AM
2006_Sport
Originally Posted by Jeffro06 View Post
Yep.
I just talked to Chrysler, they're calling my dealer reference a diagnosis appointment, then we go from there.
Better hope you still have the full warranty. Chrysler told me to screw myself.
2006_Sport is offline
post #1532 of 1825 Old 01-21-2011, 02:29 AM
Zetto
Zetto's Avatar
Originally Posted by 2006_Sport View Post
Yall are making this cam alignment way too hard on yourselves. If you marked all the right areas and you take your time you will line it up fine. I did this at 3 in the morning in my driveway with just a flashlight....I think yall can do it in the day time just fine with no problems.
To be fair I also did this at night with a flashlight.
Zetto is offline
post #1533 of 1825 Old 01-21-2011, 03:14 AM
2006_Sport
That's the spirit
post #1534 of 1825 Old 01-21-2011, 06:24 AM
Jeffro06
Jeffro06's Avatar
That's actually the vibe I got from the guy I talked to, but we'll see.
Jeffro06 is offline
post #1535 of 1825 Old 01-21-2011, 07:56 AM
Jeffro06
Jeffro06's Avatar
-8 degrees, easy start up, no chirpping.....it has to be the Mobil 1.
Jeffro06 is offline
post #1536 of 1825 Old 01-21-2011, 05:12 PM
Jeffro06
Jeffro06's Avatar
I had my OPDA checked at the dealer today, and it was determined it needed to be replaced, but was caught in the early stages. I was told I'll have to pay no more than 50% of the cost. If Chrysler doesn't ask for the original one back the dealer said they'd give it to me.
Still no more chirpping. If you have an '05 or and '06 I'd strongly suggest doing the switch to synthetic Mobil 1 TDT 5W-40 asap, especially if you live where it gets eskimo cold.
Jeffro06 is offline
post #1537 of 1825 Old 01-21-2011, 05:14 PM
Elwood
Elwood's Avatar
2016 JK Wrangler
I just did mine and mine looked just like the pictures Zetto posted. I did the Fog Mod and today I started my Jeep at -4 degrees. No chirping at all. When I pulled mine, it turned hard, but not rough. I have a new one ordered, but did the mod on my existing one. After greasing it, and spinning it a few times, smooth as silk!
Installed it, changed the oil to Mobil 1 and all has been great since.
BTW, I changed mine in a 65 degree heated 60x60 shop with plenty of light, snap-on tools and Sirius Satellite Radio on Classic Rewind!
A quote from my wife: "I don't even want to know how much it cost, I'm not in the mood to be that pissed off today."
Elwood is offline
post #1538 of 1825 Old 01-21-2011, 05:16 PM
ChaseB
I hate you
Good news to hear about the oil and modded OPDAs! Anxiously awaiting mine to show up!
1984 CJ-7 Renegade
2005 TJ X (daily driver)
ChaseB is offline
post #1539 of 1825 Old 01-21-2011, 06:50 PM
lope
lope's Avatar
Zetto, do you know if your gear was replaced by the Chrysler E05 TSB? If not, I think they will do that at no cost to you. Some of you guys with more experience with that please tell me if I'm wrong on that.
The gear on mine had been replaced and the replacement gear had 3 holes in it (for the rollpin). Two of the holes lined up (which is where the rollpin was on mine) and the other was at 90° to the other two and at a slightly different depth from the top of the gear. I'm not sure but my guess is if the two holes lined up ok they'd just install with the rollpin there and if not, drill a hole opposite the 90° one and install rollpin there. You guys feel free to chime in that know more about it.
lope is offline
post #1540 of 1825 Old 01-21-2011, 07:27 PM
Zetto
Zetto's Avatar
lope,
I have a 2006 so I assumed that the recall did not apply but I will call my dealer tomorrow. I am pulling the OPDA in the morning and installing a zerk fitting until I can purchase a new OPDA or at the least a gear.
Zetto is offline
post #1541 of 1825 Old 01-21-2011, 07:37 PM
ChaseB
lope,
Correct, the E05 was based on that TSB with certain build dates. I forget the build dates but I don't think '06 was covered
1984 CJ-7 Renegade
ChaseB is offline
post #1542 of 1825 Old 01-21-2011, 07:55 PM
lope
lope's Avatar
Yeah, forgot it was limited to '05's, and only late '04 to early '05 builds if I remember right. Thanks guys
lope is offline
post #1543 of 1825 Old 01-21-2011, 09:15 PM
Jeffro06
Jeffro06's Avatar
Mine's an '06, built in '05. I believe an "S" as the 8th digit in the vin is a sure sign that said jeep has the problem as well.
Remember this is NOT a recall. If you call Chrysler they make that perfectly clear.
Jeffro06 is offline
post #1544 of 1825 Old 01-22-2011, 06:59 AM
willydigger
Youtube of OPDA removal uploaded.
http://www.jeepforum.com/forum/f9/20...l#post10831968
willydigger is offline
post #1545 of 1825 Old 01-22-2011, 10:37 AM
cmceleste
So Im joining the club. Bought my 06 TJ used 2.5 years back with 25000 miles. as I reach my warantee at 60000, check engine, cam shaft code, and so Im here. Build date is 3/06 - no recall.
I took out the OPD and had the wear on the gears and there was a great amout of play from the shaft to the housing. I found the same housing/shaft combination from an older jeep distributer: Swaped out the bushings and gear and it fit perfectly with no play.
No for the complex question. When I first scanned it said I had an 11.3 degree differntial between crank and cam shaft. When I replaced the fabricated OPD it now says I have a differential of 8.3.
What I am wondering is if anyone knows what the correct differential degree should be. I am using a Snap-On Modis.
Thanks
cmceleste is offline
2006 , 4.0 , camshaft , replacement , tj , warranty , wrangler
All jeep owners please read for better mpg jeepfreak_5 TJ Wrangler Technical Forum 77 06-26-2012 05:20 PM
Have you really read your owners manual JohnRodriguez JK Wrangler Technical Forum 2 09-14-2008 08:25 PM
97 owners please read!!!!!! river rat TJ Wrangler Technical Forum 33 01-31-2007 06:38 PM
FL Jeep Owners, Please Read siennaspilt TJ Wrangler Technical Forum 11 01-24-2004 04:05 PM
soft top owners - must read DrEvil TJ Wrangler Technical Forum 12 10-20-2003 07:38 AM
