Chrysler is paying to install a new cam (2005/2006 owners should read this) - Page 101 - JeepForum.com
post #1501 of 1825 Old 01-19-2011, 02:18 PM
Xlr8n
1967 JK Wrangler
Good info in this thread. It's a shame to see a design flaw causing so many headaches.
Got a couple thoughts/questions to the guys involved in this research.
I have a Rev-B unit in my '05, but haven't checked for any wear at this point and have had no codes, squeals, or performance issues.
I have a bit over 61k on my rig. I've been a proponent of higher level of ZDDP oils (Pre-SM) for many years and I have used high level ZDDP oils for mearly all of those 61k miles.
I primarily used Mobil 1 HM 10w30 up until they further reduced the Phosphorus/Zinc levels in that oil last year to 900/1000 ppm respectively.
I recently decided to switch to Mobil 1 5w40 Turbo Diesal Truck that has higher phosphorus/zinc levels (1100/1200 ppm) similar to those that the SL oils used to have.
I haven't had the time to read 100 pages of post, but perhaps someone can chime in here. Seeing the '04 and earlier engines don't seem to have the gear-wear issues, am I correct in assuming that the ZDDP's, or lack there-of, is not be the root cause of the gear wear as much as it is the un-lubricated bearing putting resistance on the shaft which in turn puts more pressure on the meshing gears and causing premature wear?
Am I correct in assuming that the ZDDP's may inded help to reduce this wear to the drive gear on the '05-'06 motors, but without the resistance of the faulty shaft/seal design, it would likely not be a problem?
Xlr8n is offline
post #1502 of 1825 Old 01-19-2011, 05:13 PM
lope
lope's Avatar
The way I see it I believe you have it about right. The '04 and earlier models had the oil seal at the top of the bushing, the '05-'06's had it at the bottom of the top bushing keeping any oil from reaching it. I don't know how the thing was supposed to hold up without any lubrication to the top bushing. Hopefully the mods we've made will stand up to the test. We'll see.
lope is offline
post #1503 of 1825 Old 01-19-2011, 05:21 PM
ChaseB
Where do you guys buy your oil from (reason I ask is it's around $8 a quart locally)? The (Mobil 1 5w40 Turbo Diesal Truck) and what kind of filter do you guys recommend?
Next oil change I'm switching it up whether or not I have the new unit installed.
Thanks!
1984 CJ-7 Renegade
2005 TJ X (daily driver)
ChaseB is offline
post #1504 of 1825 Old 01-19-2011, 05:38 PM
nate2630
If anyone can help me that would be great. My 05 sport would not go over 2500rpm so I took it to a dealership in Denver on 12-29-10 and was told it needed recall e05 and or warranty work done and that it would be ready on 1-3-11. I received a call on 12-31-10 that the oil pump drive was on back order till 2-14-11! I have to rent a car and pay for it myself and might get it back before 2-20-11 and I can not afford to pay for a rental that long. I have spoken with about 8 supervisors with Chrysler and no one seems to have any accountability there. If anyone can help or knows where to get the oil pump drive for an 05 please let me know or if anyone knows anybody at Chrysler that can help me please let me know. I have been reading a lot of threads of people over the last 4 years that have had the same problem, why have they not made enough of these yet, it is rediculous!!! Please help!!!
I have called about 50 different salvage yards and no luck, it would be easier to find a lepricon with a pot of gold then to find this part! Please email me if you can help ridethebeav2@yahoo.com.
Thanks,
Nate
nate2630 is offline
post #1505 of 1825 Old 01-19-2011, 05:43 PM
ChaseB
Thanks,
Nate
Unfortunately you're out of luck with the OPDA until the 14th. Give Jonathon at Chrysler a call. (248) 944-7141
1984 CJ-7 Renegade
ChaseB is offline
post #1506 of 1825 Old 01-19-2011, 06:17 PM
Jeffro06
Jeffro06's Avatar
Thanks!
I switched today. I got the oil at Autozone, it was on sale for like 6 bucks a quart. I bought the Mobil 1 filter too.
Jeffro06 is offline
post #1507 of 1825 Old 01-19-2011, 06:19 PM
ChaseB
Thanks! I'll try to find some sales! Every little bit helps lol!
1984 CJ-7 Renegade
ChaseB is offline
post #1508 of 1825 Old 01-19-2011, 06:48 PM
willydigger
Have you tried Walmart? They sell a gallon for $25. I use the Mopar filter (also at Walmart).
willydigger is offline
post #1509 of 1825 Old 01-19-2011, 07:09 PM
ChaseB
I tried and they didn't stock it at the location I went to, but there are 3 others to try so I'll give that a shot too! Thanks for the replies guys!
1984 CJ-7 Renegade
ChaseB is offline
post #1510 of 1825 Old 01-19-2011, 07:12 PM
keithert
keithert's Avatar
I was also told Feb 14 by an online dealer. Think they will actually have the part available then?
Current: 2016 Ram 1500 Sport - Past: 05 Wrangler LJ, 90 and 92 Trackers and 98 Wrangler SE
keithert is offline
post #1511 of 1825 Old 01-19-2011, 07:15 PM
ChaseB
It's wishful thinking but if the dealership is saying Feb 14th as well it's obviously coming from the manufacturer and I hope they are running on schedule with production! Damn shame they're still producing defective OPDAs though!
1984 CJ-7 Renegade
ChaseB is offline
post #1512 of 1825 Old 01-19-2011, 07:16 PM
Jeffro06
Jeffro06's Avatar
Let's hope the backorder is because they were changing someting.....cross your fingers people.
Jeffro06 is offline
post #1513 of 1825 Old 01-19-2011, 07:26 PM
ChaseB
I can only assume the backorder would mean they had to produce more?? Unless they're importing them from somewhere? You think by now they would know that it's defective. Changes should have been made and it would be VERY nice if there were a new unit to replace the defective one.
1984 CJ-7 Renegade
ChaseB is offline
post #1514 of 1825 Old 01-20-2011, 07:45 AM
Jeffro06
Jeffro06's Avatar
This morning was the coldest morning we've had so far this winter, and the first morning after changing to the Mobile 1 Truck Turbo Diesel 5W-40 oil...........it didn't make a sound. It's only one morning, but it gives me hope that the oil is providing better lubrication than the dino oil that was in there.
Jeffro06 is offline
post #1515 of 1825 Old 01-20-2011, 08:38 AM
chutta
Mine's been chirping for a few weeks now when cold, lasting maybe a couple hundred yards.
Dealership says they "see no problems with this". Owner has a sideline biz selling Hemi's. NOT BITING.
Taking apart tomorrow or telling them to take it out tomorrow
05x 4.0 6sp 30/35, aussie front, 3.73's, r/c 4"x lift, adv adptr sye, shifter bracket, tw cv ds, 33 t/c skid, 33x12.5 dunlop mud rovers on steelies, psc sport cage/rockers, warn fr bump/steer and 30 diff skid, sirius,cb, hand throttle 1"bl/mml 265/16's pepboys at's on orig moabs for street. Lowrance H20c for gps
chutta is offline
2006 , 4.0 , camshaft , replacement , tj , warranty , wrangler
All jeep owners please read for better mpg jeepfreak_5 TJ Wrangler Technical Forum 77 06-26-2012 04:20 PM
Have you really read your owners manual JohnRodriguez JK Wrangler Technical Forum 2 09-14-2008 07:25 PM
97 owners please read!!!!!! river rat TJ Wrangler Technical Forum 33 01-31-2007 05:38 PM
FL Jeep Owners, Please Read siennaspilt TJ Wrangler Technical Forum 11 01-24-2004 03:05 PM
soft top owners - must read DrEvil TJ Wrangler Technical Forum 12 10-20-2003 06:38 AM
