Chrysler is paying to install a new cam (2005/2006 owners should read this) - Page 10 - JeepForum.com
post #136 of 1825 Old 04-09-2010, 10:35 AM
Woodenya
Yes, yours is worn abnormally...
You need to take your Jeep to the dealer and call the Chrysler 800 number. Mention TSB E05.
It's hard to tell if the Cam gear is worn. The underside of the gear teeth drive the CPS gear. You need to use a small miror to inspect the underside of the teeth.
'06 TJ Rubi (Light Metalic Khaki) 6sp, Bought 3-10 w/6500 miles. 31 MTR's, UCF alum UHC T-case & engine skid w/ LoPro, Rokmen gas tank & steer gear skid, Ridler dif covers F/R, Warn 8274-50, Optima Yellow top, Pro Comp front 3/4" spacers, Currie 1" BL, Bomb Proof MML, Novak cable shifter, AGR Super Box 2, Warn rear bumper/tire carrier, Rubi locker mod/pumps moved to engine bay, OBA. Build to come...
Woodenya is offline
post #137 of 1825 Old 04-09-2010, 12:34 PM Thread Starter
ElJaynocibuR
Originally Posted by Country1 View Post
Yeah, I had to realign my oil pump with a screw driver too. It took a few tries, but I finally got her. No codes either...
Update on my drive failure... I took mine to Carmax because I still had a 30 day warranty. (I just purchased the TJ). At first Carmax seemed like they we're going to take care of the problem, but that soon changed. After going back and forth with them for most of the week, the end result is them wanting to replace the cam position sensor only. They aren't willing to replace the cam shaft even though there is abnormal wear on the gear. The service manager even told me that the new CPS will "just get tore up again". So it's really ridicules that they won't do the whole job... He also told me that there is a "nation wide back order" on the CPS and the est. ship date for one was 4/28/10.... Maybe Jeep has figured out that their part is still failing and are doing a redesign??... Anyway, I pulled the trailer to Carmax yesterday, loaded my Jeep up and took her home. She’s now washed again and safe in my garage. Bottom line with Carmax is, they’re still just a used car dealer no matter what they try to make you believe before the sale. Also, don’t put too much faith in their 30 day “we’ll make it right” warranty. Their service department has a few things to learn about customer service too!
When I gave up on Carmax I called the 800 Chrysler number. Explained my problem, told them about the E05 TSB and this thread. They gave me a case # and said I would receive a call from a case manager by close of business the next day. About 2:30 yesterday I got a call from a nice lady and she said that they were willing to help cover the costs of the repair (she wouldn't say how much though), but I had to take the vehicle into my dealer and get it "properly" diagnose. Told her I would call and set up an appointment and she said she would call me back the next day to follow up on my appointment date.
Hung up from her and called Rob (my service writer at Jeep/Dodge dealer) and filled him in on everything that I’d been through (He was the 1st person I talked to about this last week and he advised me to try Carmax 1st). He said " from my experience it sounds like Chrysler is going to take care of this for you". ( I hope so!) We set an appointment for Monday morning and he said that he would follow the instructions on the TSB. Also that he would most likely be on the phone back and forth with Chrysler most of the day Monday but, by the end of the day we would have a full answer on what needs to be done and what Chrysler would cover.
Give you all another update next week (week 3 of dealing with this and not being able to drive my new Jeep....)
I don't quite understand why u are trying to get carmax to pay for it. Its chryslers problem let them pay for it. (Of course that's just my .02)
2006 LJ Rubicon=4" lift, 305/70/16 Mickey T.'s MTZs, etc...
ElJaynocibuR is offline
post #138 of 1825 Old 04-09-2010, 01:13 PM
Woodenya
Because when I went to my Chrysler dealer, I was told my '06 wasn't covered under the TSB and since I still had a 30 day Carmax warranty that they should cover the repair. I was told that my local Carmax contracts out any major Chrysler work to the local Chrysler dealer. I went to the Chrysler dealer first because I would rather them do such major work on my 7,000 mile new to me Jeep. Also, I was told by my Carmax salesman before the purchase that they had a "great 30 day warranty" and I could buy with confidence because Carmax would take care of “any” problem I found in the first 30 days. The documentation on the warranty back this up.. Once It was evident that Carmax wasn't going to solve my problem correctly, I went back to Chrysler with it. Sounds like they're going to take care of it for me, but it was also Carmax's responsibility to fix it under their warranty. I could still try and fight it out with Carmax, but that would probably be harder than trying to get Chrysler to cover the work.
Woodenya is offline
post #139 of 1825 Old 04-09-2010, 01:41 PM
popeyesides
popeyesides's Avatar
Just picked up my 06 LJ Rubicon from the dealer , I took it there Monday late afternoon. They replaced the oil pump drive assembly and a sensor. I asked about the camshaft and the tech said it did not have any wear and then showed me pics he took with a micro video cam. He said he has done a couple of these in the last month or so. So it cost me $100 and I have a 12month- 12,000 mile warranty so I will check it again in 10 months since I only put about 3,000 miles a year on it. BTW the Jeep sure idles smooth now and did not have to break down the motor. Thank you Chrysler for doing the right thing.
popeyesides is offline
post #140 of 1825 Old 04-09-2010, 02:39 PM
jrhack11
Uh oh, '06 tj, engine build date 8-26-2005, mfg date 11-05, number on the synchro is 105222reve, feel like I might have a problem. Guess I might have to pull it and check this weekend. Would it be smarter for me to just take it to the dealer and have them check for the wear? Thanks for any advice.
Maybe not a mechanic
jrhack11 is offline
post #141 of 1825 Old 04-09-2010, 04:40 PM
Nick B
How many miles did you have on it ?
Nick B is offline
post #142 of 1825 Old 04-09-2010, 08:13 PM
popeyesides
13,600 miles.
post #143 of 1825 Old 04-09-2010, 10:49 PM
tshively
Talked the service writer at the dealer today he said that the cam gear wear/oil pump drive gear wear was with-in spec.?? I picked up the jeep after hours so I did not get a copy of service order. I definately want paper work from them stating that after their inspection that it is normal wear.
Originally Posted by roadkill View Post
I've been thinking about this problem. it seems as if the culprit is that new style oil pump drive assembly and Chrysler hasn't came up with a good viable fix and I doubt they will seeing as it only affects 2 model years that are no longer in production. the only real long term solution I see is an engine swap.
This is so true ^^^. Even those that have got the problem repaired with a new cam and OPD assembly will the problem be fixed? I have always wanted a hemi. No it is not because of the name it is because it is such a clean install in our late model TJ's. The good news is there seems to be more and more low mile hemi's showing up in the salvage yards everyday!
tshively is offline
post #144 of 1825 Old 04-09-2010, 11:35 PM
tjwoo
tjwoo's Avatar
Build date is 5/06, haven't experienced any problems so far. 57k miles on it, and the number on the synchro is well out of the range posted.
Should I still pull and see?
tjwoo is offline
post #145 of 1825 Old 04-09-2010, 11:51 PM
roadkill
I would. at the very least I would remove the cover and see how hard it is to rotate the OPD. from what I understand is the bushing starts to seize up and that is what drives the wear
roadkill is offline
post #146 of 1825 Old 04-10-2010, 01:32 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
That might explain the one I saw with the snapped off retaining bolt...
Knuckelhead is offline
post #147 of 1825 Old 04-13-2010, 09:14 AM
RockHound1
How do you unplug the plug ? Do you push the red clip in or push down on the bottom tab ?
RockHound1 is offline
post #148 of 1825 Old 04-13-2010, 09:23 AM
Woodenya
No need to unplug,
Unbolt the sensor.
Woodenya is offline
post #149 of 1825 Old 04-13-2010, 11:46 AM Thread Starter
ElJaynocibuR
D
I don't want to sound like a jerk, but if you have a hard time with the plug I would not attempt this procedure yourself. Take it to the dealership to have it checked.
post #150 of 1825 Old 04-15-2010, 01:16 PM
Woodenya
Update on my bad gear...
Went round and round with Chrysler this week. Bottom line is, no help... My Cam gear is said to be fine and only the CPS needs to be replaced. Parts and labor are around $325 so not the huge bill/repair I thought, so I'm just going to pay out of pocket to get it done. Part is backordered and the tech says my Jeep is ok to drive until they get the part in. I just hope the $325 will put an end to this saga...
Woodenya is offline
2006 , 4.0 , camshaft , replacement , tj , warranty , wrangler
All jeep owners please read for better mpg jeepfreak_5 TJ Wrangler Technical Forum 77 06-26-2012 04:20 PM
Have you really read your owners manual JohnRodriguez JK Wrangler Technical Forum 2 09-14-2008 07:25 PM
97 owners please read!!!!!! river rat TJ Wrangler Technical Forum 33 01-31-2007 05:38 PM
FL Jeep Owners, Please Read siennaspilt TJ Wrangler Technical Forum 11 01-24-2004 03:05 PM
soft top owners - must read DrEvil TJ Wrangler Technical Forum 12 10-20-2003 06:38 AM
