chromolly shafts for dana 35 - JeepForum.com
post #1 of 14 Old 04-22-2009, 05:25 PM Thread Starter
bigtjzj62
I have a stock 27 spline carrier and want to upgrade to chromolly axles on the rear because i keep breaking everytime i hit the trail. the only company i have found that makes them is yukon. does anyone know of anyone else and where can i find them for cheap.
thanks
bigtjzj62 is offline
post #2 of 14 Old 04-22-2009, 05:32 PM
sailsurf7713
Alloy USA, Crown, AtoZFabrication are a couple others.
I've found the crown ones for 300, the ones on the atoz site are 350. Alloy USA is in the process of restructuring, however if you give them a call I'm sure they can direct you to a vendor or allow you to purchase them direct.
Superior also has their c-clip eliminator kit which uses 27 spline shafts.
'99 SE: The "It could be worse..." jeep
Originally Posted by 97flexy View Post
...I say don't lift but CUT. :)
sailsurf7713 is offline
post #3 of 14 Old 04-22-2009, 06:05 PM
Muddybrit
I suggest you learn how to drive first
From stock to big rock just enjoy what you got
Muddybrit is offline
post #4 of 14 Old 04-22-2009, 06:09 PM
cmc1
from my looking and gathering i think the real only solution for keeping 27 splines is the superior c clip eliminator. with 33s should do well.
cmc1 is offline
post #5 of 14 Old 04-22-2009, 06:42 PM
tooofast
a buddy of mine just got a pair of new yukons for his d35 for about 200 shipped from ebay. you'll need to get new wheel studs and all you get are the shafts but that was a good deal i thought.
Dave
4" clayton long Arm, 5 inch rear stretch. CRAWLER tank. 35" KM2 muds, 1" MML from Brown Dog. Rear D44 Locked with a Detroit & trussed on Alloy Shafts, 4 point triangulation. Rear disc conversion. AtoZ Cage. Rubicon OR241 4:1. Front D30, Polly Performance Sleeve kit, locked with ARB, Alloy Shafts and HD steering linkages. Clayton belly up and oil pan skids, PSC Rocker Knockers, ORO air powerd Swayloc, Onbard Vita 450 and tank for fills and ARB compressor for the locker. Covered in dents.
tooofast is offline
post #6 of 14 Old 04-22-2009, 06:45 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
The only way I'd expect chromolly 27 spline axleshafts for the rear Dana 35c axle to be of any help at all would be if you also installed Superior Axle's c-clip eliminator kit. Without that, I wouldn't expect those shafts to live that much longer than the OE shafts do in reality.
Getting
Jerry Bransford is online now
post #7 of 14 Old 04-22-2009, 06:57 PM
Muddybrit
Depends what you are doing with them surely?
For most mere mortals a d35 will do just fine with reasonable sized tyres. I am constantly amazed at the abuse I give mine and have yet to even come close to disaster. If as you say you do genuinely keep breaking them then an upgraded shaft will not help as you will break that too. You need to change your driving style or buy an axle that can handle it!!!
post #8 of 14 Old 04-22-2009, 08:03 PM
sailsurf7713
If you're breaking axles "every" time you go wheeling, you may want to skip the chromos, the c-clip eliminator and start thinking about a super 35 like mentioned prior. Could also set up an 8.8 or Isuzu 44 for probably under 1000 if you choose components wisely. Isuzu 44 will require wheel adapters though. I've only found one company that makes them.
post #9 of 14 Old 04-22-2009, 08:16 PM
Jerry Bransford
Administrator
Exactly what do you know about the fairly new Superior Axle c-clip eliminator kit where you would dismiss it that easily?
Getting
post #10 of 14 Old 04-22-2009, 08:19 PM
percent20
I have to agree with upgrading axels especially if you plan to eventually go bigger and do more stuff. I have seen a lot of threads where people put a lot of time into their 35's only to replace them later.
percent20 is offline
post #11 of 14 Old 04-22-2009, 08:26 PM
AlTheKillerr
AlTheKillerr's Avatar
id up to the 30 spline chromos with the c-clip eliminator
Photographer
2000 XJ, 3.5" lift, 32s, Locked
AlTheKillerr is offline
post #12 of 14 Old 04-23-2009, 10:19 PM Thread Starter
bigtjzj62
i dont hammer the thing into the ground that is why it is so shocking tht i break. there is a guy in the club that i go with that he is either stopped or wide open on a d35 with the same tires i have and he has broke one axle in 8 years of wheeling. i have broke two axles in roughly 5 or 6 trips. alot of people have said that the chromos will help out and wont break.
post #13 of 14 Old 04-26-2009, 04:44 PM
sailsurf7713
Sorry Jerry. Wasn't putting the kit down at all. It seems to be excellently engineered and I've kept up with the info on it and I know there are plenty of guys running it with 33s and no breakage. I was actually looking into a lot and was gonna pull the trigger this summer, however for the money I feel there may be stronger (however ground clearance robbing). options out there. Plus with a crappy economy and shaky job market I'm staying on stocker tires for longer than anticipated.
I was under the impression that this guy was really hammering on his rig and none of us like trail fixes anymore than the next guy. Figured a tougher axle may suit his needs and wanted to throw some recommendations up from previous research I've done. However hearing now how he's wheeling the c-clip eliminator may be an excellent choice and he can install it himself.
post #14 of 14 Old 04-26-2009, 05:55 PM
Liftedsahara
Ok, I'm running 35's on my STOCK dana 35, yeah yeah, I know. So far in 6 years of owning my Jeep, I've never had a problem. It's all driving style and the lines you choose. Plus my diff. is open. I go easy on it but still in some situations where I thought, damn I need to go easy on it or I'll snap a shaft or destroy my spiders, still it pulled trough(knock on wood). My jeep is daily driven and sees trails once every couple of months. So, I'd say do the C-clip kit from Superior. That's the route I will be taking soon.
2000 TJ Sahara- 35" MTZ's, RE 3.5" SA, JKS 1.25" BL, 4.56's and a ton more stuff
Liftedsahara is offline
Dana 30 spare shafts, what other vehicle shafts will work on the TJ Broadway TJ Wrangler Technical Forum 5 05-03-2007 09:27 PM
How do I get Dana 44 Shafts out JeepRocks86 TJ Wrangler Technical Forum 2 03-29-2006 10:42 AM
dana 44 shafts in a dana 30 housing??? jdelow77 TJ Wrangler Technical Forum 9 09-22-2005 10:46 AM
Dana 35 shafts pwhit YJ Wrangler Technical Forum 4 09-14-2005 04:58 PM
Dana 44 shafts supertj4415 TJ Wrangler Technical Forum 6 12-07-2004 08:10 PM
