Chevy 305 in my 2000 jeep tj? - Page 2 - JeepForum.com
post #16 of 113 Old 11-22-2013, 10:04 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Originally Posted by DeGusipe View Post
The not reason I'm voting for carb is because of the wiring that has to be done with a fuel injected motor. Does anyone have any info or a guide for wiring in the computer? If I can get a good guide and understanding of how to go about it I may change my mind. Has anyone done it that could give me information or tips?
You need factory service manuals for both vehicles.
Then you need time to read and become familiar with the wiring diagrams. Know what the abbreviations mean, what the symbols mean, how to quickly find the info you need, etc.
Or you can buy a pre-made wiring harness for most of the popular motor swaps.
If you want a Chevy powerplant, you should consider the 5.3.
Wheelin98TJ is offline
post #17 of 113 Old 11-22-2013, 10:10 AM
willis36
willis36's Avatar
If swaping in a modern fuel injected engine is to complicated, why not just toss in your carb motor and add a stand alone system, such as a holley projection. A system like that is fairly easy to install.
willis36 is offline
post #18 of 113 Old 11-22-2013, 11:27 AM
rda616
The magnum v8 swap is the cheapest and easiest swap you can do. You get to keep the efi and the factory gages will work with out piggybacking the pcm.
rda616 is offline
post #19 of 113 Old 11-22-2013, 12:13 PM
AntiPrius
I also agree that going from FI to a carb is a HUGE down grade, and the Chevy 305 is one of Chevy's worst V8's. I'd much rather have the Jeep 4.0 than a 305/carb setup. I'd only consider a 5.3 or 5.7 FI setup-, if I was considering a Chevy swap.
AntiPrius is offline
post #20 of 113 Old 11-22-2013, 12:29 PM
Duck Doctor
Okay thank you very much. I don't rip on my jeep or abuse it. I do light off-roading and
Trail riding and a good bit of highway. The way I drive the tranny and tcase will most certainly work.
Anyone got suggestions on a 350 motor year? Emissions are not a problem where I live. If I knew how to wire the computer and harness into my jeep I'd go with a fuel injected motor but unfortunately I don't and will more than likely be going with a carb.
Look at the 290 HP Goodwrench crate engine offered by jegs or summit. They are cheap and well reviewed by the daily driver muscle car community.
Duck Doctor is offline
post #21 of 113 Old 11-22-2013, 12:40 PM Thread Starter
DeGusipe
Do I still need the computer and wiring harness out of that donor vehicle with the engine?
DeGusipe is offline
post #22 of 113 Old 11-22-2013, 01:07 PM Thread Starter
DeGusipe
Im gonna stick with a carb, might be a bad idea to many of you, but all of that wiring is nonsense to me lol. A guy I know has a 1991 YJ with a ford 302 in it and it runs well. Probably going to go with a 350.
DeGusipe is offline
post #23 of 113 Old 11-22-2013, 01:11 PM
rda616
Yes, but the dodge pcm will work with the jeep gages. The wiring is no harder than wiring in new gages or piggybacking to any other engine. You also don't need to alter the fuel delivery system with the magnum v8. The only non factory part you will need to use are the radiator and engine mounts. You will need a bellhousing from a Dakota with a 5 speed . And the advance adapters brackets are the better choice in my opinion.
rda616 is offline
post #24 of 113 Old 11-22-2013, 01:16 PM
rda616
A local guy though the same thing about a carbureted 350. He started his swap before me and my rig has been running for 2 years. I still haven't seen his out on the road yet.
These guys will build you a harness for $750. It's plug and play. http://backwoodsoffroad.com/cgi-bin/...play.cgi?cat=4
rda616 is offline
post #25 of 113 Old 11-22-2013, 01:21 PM Thread Starter
DeGusipe
After I saw this picture of a guy swapping a magnum v8 into his tj, it frightened me just a little bit lol
DeGusipe is offline
post #26 of 113 Old 11-22-2013, 01:25 PM
rda616
Why, because he took the loom iff the wiring.what do you think you will need to do to get that 350 running and gages working!
rda616 is offline
post #27 of 113 Old 11-22-2013, 01:28 PM
biffgnar
biffgnar's Avatar
The guy looks a little scary, but what's scary about the harness? Yes, there are a lot of wires under the hood in a car. Harness in the picture actually looks pretty complete and together with plugs and everything. If you get the right one you follow the diagrams and plug it in. If you had a photo of somebody building their own or doing some splicing that might look a little more intimidating.
Dakar Style Rally Raid in North America: www.sonorarally.com
biffgnar is offline
post #28 of 113 Old 11-22-2013, 01:29 PM
Andy5150
Do it.....If your experience with a carb is that bad, go to injection.My 82 CJ-7 had an AMC 360 with a Holley 670 Truck Avenger on it and ran great. Would it have gotten better than 12 mpg with injection? Maybe.....But I bolted it on, made 1 jet change , and never touched it again for remaining 2 1/2 yrs/ 26,000 miles I owned it. I think some of the bad experiences with carbs go back to the 70,s to mid 80,s when they were awful. They were jetted to lean, and had a lot of crap on them to pass emissions. Anyway, good luck, and keep us posted.
Andy5150 is offline
post #29 of 113 Old 11-22-2013, 01:31 PM Thread Starter
DeGusipe
Progress so far... About 3 days into it so far.
DeGusipe is offline
post #30 of 113 Old 11-22-2013, 01:35 PM Thread Starter
DeGusipe
I don't mean to start an argument here and dont want to do that at all, but you said that company will build a harness for me, but it's also $750. I'm not completely sure what i'm doing yet. Im just asking for opinions and advice here. Thanks everyone for the opinions!!!
DeGusipe is offline
help needed , jeep build , v8 , wrangler , wrangler tj v8
