Chev V8 Swap? - JeepForum.com
post #1 of 9 Old 03-11-2007, 05:06 AM Thread Starter
Wallace
Chev V8 Swap?
Hi All,
My old man just bought himself a CJ8 with a Chev 350 in it! Now... let me start off by saying, the beat of the V8 has gotten to me quicker than i thought it would.
I am considering doing a 350 swap into my TJ. I currently have the 4.0L I6 in my TJ. My TJ is a 2000 model, D30 front and D44 rear. I have a Heavy Duty SYE in the rear and 2.5" OME lift with 1" BL.
Since it is a 2000 model, i believe it has the AX-15 gearbox and the NP231 transfer case.
My question is this - is a V8 swap into my TJ worth the cash and the effort? Or should i just look at perhaps modifying the I6 a little more (it has a 2.5" straight the exhaust system)?
Any input will be appreciated.
Thanks,
Will
2000 TJ Wrangler Sport
Half Door - Soft Top
WARN Rock Sliders, 4.5" RE Springs
TnT Customs Dual Triangulated Long Arm Lift, NV4500
35" M/T Baja Claws, TBT Rear Bar with Tyre Carrier
ARB Front Bar - Dual Hella 4000 Spotlights.
Wallace is offline
post #2 of 9 Old 03-11-2007, 05:48 AM
Shane64
Shane64's Avatar
I hate to ask another question to your but how do you like the exhaust system, and dose it give allot of power?
Shane64 is offline
post #3 of 9 Old 03-11-2007, 09:15 PM Thread Starter
Wallace
My exhaust system does sound nice - gives the jeep a nice beat. I would say it gives more power - but i could be giving a biased opinion. I havent had it on a dyno or anythign like that.
Thanks,
Will
Wallace is offline
post #4 of 9 Old 03-11-2007, 10:55 PM
ChiliPalmer
This is Ames Mister...
ChiliPalmer's Avatar
It's cheaper and easier to just stroke your 4.0L into a 4.6L.
If you want to help the sport of offroading visit the
Forum!
Oh man Chili. I feel like a recovering addict that just had a bag of blow, a bottle of Jameson, and a sack dropped in his lap. You screwed me man!
ChiliPalmer is offline
post #5 of 9 Old 03-11-2007, 11:46 PM
TXjeepTJ
TXjeepTJ's Avatar
modify the 4.0L will be ALOT more cheaper, but i mean - youd basicly just be average still. im swapping an ls1 into my wrangler and i dont care how much money i put into it (closing up on about 5,000 now) i am going to have a huge smile on my face everytime i drive it/think about it/see it
that is how obsessd i am with a v8- if you dont feel this way, id just stick to modifying the 4.0
LS1 powered TJ
C6 Z06 Corvette
TXjeepTJ is offline
post #6 of 9 Old 03-11-2007, 11:57 PM
jeepcrzyspd
i have an ltz v-8 in my tj i bought it this way the trans wont hold up but you can buy the tranfer case mods and trans mods kits from ( http://www.novak-adapt.com/knowledge/th700r4.htm ) try giving them a call other wise use all chevy drive train i have to get another trans and case then have drive shafts made was told $2,000 to do it with the mods and ax-15 case might be cheaper using the chevy case and trans just fab mounting of the trans and t-case and skid plate then get drive shafts made
jeepcrzyspd is offline
post #7 of 9 Old 03-12-2007, 12:01 AM
TXjeepTJ
TXjeepTJ's Avatar
lt1? couldnt really understand what you were sayin about the ''was told $2,000 to do it with the mods and ax-15 case might be cheaper using the chevy case'' ??
what set up did you have before everything broke? what trans
LS1 powered TJ
C6 Z06 Corvette
TXjeepTJ is offline
post #8 of 9 Old 03-12-2007, 12:13 AM
ChiliPalmer
I'd have to agree with you on this one...
Forum!
post #9 of 9 Old 03-12-2007, 02:18 AM
mikey_vegas
im actually in the prosses of doing a Chevy 350 swap
im custom fabing a long arm lift for it
triangulated 3 link in the rear 4 link in the front, using 3/4 heim joints and 4130 chrome-moly tubing for the arms, should be stout.
using a built 400hp small block, turbo 350 trans and transfer case out of a k-5 blazer and custom drive shafts
total the swap its self will cost somewhere around 2 grand
then another 2 grand for 35's and all the things i need for the suspension and putting the Aussie locked 8.8 in the rear
ill start a thread when i start dropping things in, for now its all disassembly
400hp and 430 foot lbs in a TJ
and you want to talk about a flat tq curve ahahah
would would never be able to squeeze that kind of power out of a stroked 4.0 with out forced induction or running on race gas both of witch would be less reliable and more expensive then a solidly built Chevy motor
the sound is amazing and its alway nice to smoke that 350z sitting next to you haha
mikey_vegas is offline
Another chev v8 swap Giviner TJ Wrangler Technical Forum 100 01-26-2010 12:48 AM
Chev Gen3 engine swap - info compilation Giviner TJ Wrangler Technical Forum 27 05-12-2009 09:04 AM
Chev 350 engine swap could use wire info strd27 YJ Wrangler Technical Forum 5 08-10-2008 05:37 PM
4.3L Chev?? 93YJNewf YJ Wrangler Technical Forum 4 04-21-2007 06:08 PM
Chev 4.3L swap dartboy YJ Wrangler Technical Forum 2 04-15-2002 03:09 PM
