Quantcast Cherokee 4spd auto swap? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Cherokee 4spd auto swap?
Old 10-13-2007, 12:10 AM   #1
12secondtr
I posted a question about swapping a Cherokee 4spd auto into my Wrangler, replacing the 3spd auto, gaining OD. There was a reply posted stating that there will be an ECM issue. Does anyone know if I could replace my Wrangler ECM with one from a Cherokee, resolving the probelm with the tranny swap? Both came with the same motors, is there any other issues I am not thinking of? Thanks!
12secondtr is offline   Reply With Quote
Old 10-13-2007, 12:24 AM   #2
Greg_Volkman
http://www.stu-offroad.com/engine/aw-4/aw-4-1.htm
tell stu thanks by donating a few bucks...
-0|||||||0-
He who hunts in a pack is still a dog. The lion hunts alone, and so do I. - Napoleon
Conducting an argument by appealing to authority is not using your intelligence; it is just using your memory. - Leonardo Da Vinci
Greg_Volkman is offline   Reply With Quote
Old 10-13-2007, 01:07 AM   #3
Stu Olson
Stu Olson's Avatar
That is a good question. I would be skeptical that an XJ computer would be a drop in replacement for a TJ computer. That doesn't mean it can't work....I just would never get that lucky.
If you have one available, check the pin outs against the TJ's (you'll need good factory manual) and see if they match up one for one.
Stu Olson
ARB Locked & Loaded
www.stu-offroad.com
Stu Olson is offline   Reply With Quote
Glock Forum
