Checking for codes - JeepForum.com
post #1 of 5 Old 07-15-2010, 04:47 PM Thread Starter
classicinjectio
Checking for codes
I tried to do the code check turned key on/off 3 times on third time left it in run my speedo displayed dont does anyone know what this means? I checked the codes at a Autozone none where shown.
2006 Rubicon unlimited
classicinjectio is offline
post #2 of 5 Old 07-15-2010, 04:49 PM
Benderff
Benderff's Avatar
Your post is hard to read the way you worded it. It sounds like you don't have any codes. That's a good thing.
Benderff is offline
post #3 of 5 Old 07-15-2010, 04:51 PM
chadsmeltzer
chadsmeltzer's Avatar
If no codes appeared then there are no codes.
Why do you think there are codes? Is the CEL on?
04 TJ - 2 KC Daylighters, 35x12.5x15 MT/R Kevlar, 3" coils, Rear 4 link, 1.25" JKS BL, 1" JKS BMML, 33 Eng. Hi-Clearance Skid, 8.8 with LS, D30 EZ locker, OBA
chadsmeltzer is offline
post #4 of 5 Old 07-15-2010, 05:06 PM Thread Starter
classicinjectio
Benderff, the letters dont showed up on speedo display
Chad, just doing some maintenance decided to check for codes
post #5 of 5 Old 07-15-2010, 05:22 PM
Benderff
Benderff's Avatar
dont showed up? That's because there are no codes to showed up.
Benderff is offline
CEL , key trick , check engine light
Need Assistance Checking Obd1 Codes On A Jeep BC Jeep YJ Wrangler Technical Forum 10 11-22-2010 04:17 PM
" No Bus" when checking codes dgill53 TJ Wrangler Technical Forum 4 10-07-2008 08:18 AM
checking codes -2006 tj oc92 TJ Wrangler Technical Forum 1 03-17-2007 05:58 PM
Checking codes on a 94 4 banger pezley69 YJ Wrangler Technical Forum 2 03-14-2006 12:01 PM
Checking engine codes only in a jeep cj YJ Wrangler Technical Forum 1 02-12-2006 11:15 AM
