Quantcast Check Pinion Angle - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Check Pinion Angle
Poison Spyder Brawler Rockers!TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-
Old 08-02-2009, 03:53 PM   #1
criddy
Check Pinion Angle
I just installed a Teraflex 3 inch spring lift but actually got 4 inches. I did the transfer case drop because I don't have a SYE yet. This was my first experience with work on my jeep. I learned from the Jeep Forum how to install the lift and tried to educate myself on lifts and the affects they have on other components. Since I have never looked at a pinion angle I just want to be sure its correct. Thanks for all you knowledge that you post on the forum it is very helpful to newbies
Transfer case 231, Dana 44
[IMG][/IMG]
Angle is 10
Angle is 12
Angle is 12
criddy is offline   Reply With Quote
Old 08-02-2009, 03:57 PM   #2
-sean-
newb
-sean-'s Avatar
Your fine.
... keeping an eye on you guys.
-sean- is offline   Reply With Quote
Old 08-02-2009, 04:12 PM   #3
Knuckelhead
Knuckelhead's Avatar
Did you check the pinion angle? None of your pictures show that...
Originally Posted by Yucca-man View Post
My experience is that poly loves to groan
Knuckelhead is offline   Reply With Quote
Old 08-02-2009, 04:14 PM   #4
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
The pinion angle needs to be exactly the same as the transfer case's output shaft angle with that type of driveshaft. Definitely never any higher and as low as 1-2 degrees under that of the t-case output shaft. It may be the photo angle but it looks like someone raised the pinion angle up to match the driveshaft which is incorrect and can cause vibes.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is online now   Reply With Quote
Old 08-02-2009, 05:44 PM   #5
criddy
Jerry,
So, can I fix this with adjustable upper rear control arms?
Old 08-02-2009, 05:55 PM   #6
-sean-
newb
-sean-'s Avatar
Are you getting vibes?
Old 08-02-2009, 05:58 PM   #7
criddy
a little with decel at around 10-15 mph and less. I just don't want to damage anything by leaving it if its not correct.
Old 08-02-2009, 06:08 PM   #8
Knuckelhead
Adjustable uppers will allow you to correct it, you'll need them also when you do get an SYE and new driveshaft...
Old 08-02-2009, 06:14 PM   #9
-sean-
newb
-sean-'s Avatar
X2 Good to have no matter what.
Sounds like your good for now and running it that way isn't going to hurt anything in the mean time as long as your not getting a bad vibe. Are you sure the vibe you described is coming from the rear? I only ask because most folks get them constantly and under a load, not during deceleration.
Old 08-02-2009, 06:36 PM   #10
Knuckelhead
And how about that pinion angle measurement?...
Old 08-02-2009, 06:57 PM   #11
-sean-
newb
-sean-'s Avatar
I was wondering about that too, you took a measurement at the pinion but you put the angle finder on the shaft, not the pinion yoke.
Old 08-02-2009, 06:57 PM   #12
criddy
The angle on the transfer case is 8 deg.. The bottom of the diff is 18 deg.
Old 08-02-2009, 07:00 PM   #13
-sean-
newb
-sean-'s Avatar
Are both of these measurements taken on the yokes?
Old 08-02-2009, 07:07 PM   #14
criddy
I rechecked it. The yoke from the diff is 12 deg. the yoke from the transfer case is 10 deg
Old 08-02-2009, 07:28 PM   #15
bddisi
bddisi's Avatar
Like stated earlier, your rear pinion looks too high. Yes adj uppers would allow you to correct it. Did your lift come with cam bolts? I don't know if you could get enough adjustment from those to help or not, I do know they are a lot less $$$ than adjustable uppers.
bddisi is online now   Reply With Quote
Glock Forum
