"check ingine" lite comes right back on, but no code??? - JeepForum.com
post #1 of 5 Old 01-28-2006, 01:13 AM Thread Starter
Q-01
Cleared codes (99 2.5), cleared light,, several starts later...I get "check engine" light, but no codes...????????
Whats up....cant keep "check engine" light out....????? But no codes....??
Q-01 is offline
post #2 of 5 Old 02-01-2006, 05:57 AM
airduds
airduds's Avatar
What are you using to check your codes?
2000 Sport 4.0/both tops/5sp/4.88s/Dana 44 Truetrac rear/Dana 30 Aussie Locker front/Ramsey 9500 receiver mounted for front and rear/RE 5.5" LA/15"x10" M/T Classic II's/Dunlop Mud Rover 35's/TBT Alumi-Flex tie rod
airduds is offline
post #3 of 5 Old 02-01-2006, 07:53 AM
Muddeprived
Muddeprived's Avatar
Take it to autozone for a free code pull. The key trick does not work on 98+ models. Just so you know.
Make sure your gas cap is on a few clicks.
2001 XJ Sport 4.5" LA
1999 TJ 2.5L 5spd 2" lift
Muddeprived is offline
post #4 of 5 Old 02-01-2006, 08:11 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Thats correct.
The key trick does not work, but you can still pull codes (copied directly from the FAQ):
So on TJs with the newer diagnostic system, to see the codes you put the key into the ignition, push and hold down the odometer reset button, turn the key to RUN, then release the odometer reset button. When you do this you are rewarded with dancing number displays, the firmware version number, any error codes, then a diagnostic test of all the dash indicators and gauges. The gauges will, one by one, go through a calibration--the needles moving and stopping at major increments so you can check their alignment with the dial markings.
Wheelin98TJ is offline
post #5 of 5 Old 02-01-2006, 08:17 AM
sdog30
Ditto on Autozone. They have a code reader that they come out to your car and plug it in for FREE. They were able to tell me which O2 sensor I had to replace.
97 TJ 4.0Lw/5spd (the way god intended it)+33"+3.5 RE Superflex+RE Monotubes+GEN2 discos+BDS adjustable track bar
regretfully *FOR SALE*
sdog30 is offline
"Check Engine Light" and engine code P0442 MDC3 TJ Wrangler Technical Forum 3 08-05-2009 01:38 PM
O2 sensor 03" Rubi fixed passed e-check light came back on RDMcCoy TJ Wrangler Technical Forum 2 03-03-2009 07:21 AM
O2 Sensor Replaced... check engine light came back on with a 138 code kypd114 TJ Wrangler Technical Forum 8 12-01-2008 06:16 AM
Code "bus 68" "panel open" help??? 02tjsport TJ Wrangler Technical Forum 3 04-09-2006 01:21 AM
How do I turn "check engine" light off? Code.. Q-01 TJ Wrangler Technical Forum 7 01-28-2006 01:28 PM
