Check Engine Light reset - JeepForum.com
post #1 of 17 Old 06-16-2003, 08:45 AM Thread Starter
skatedork
I have a 99 wrangler sport, Anyone know where the check engine light reset is on this? Thanks
I bent my wookie
skatedork is offline
post #2 of 17 Old 06-16-2003, 08:47 AM
Owen
Owen's Avatar
Did you get any codes?
To reset you simply disco the battery for about 10 mins...
Smuggler Re-Born.....
Owen is offline
post #3 of 17 Old 06-16-2003, 08:47 AM
Owen
Owen's Avatar
Oh and what up Jersey
Owen is offline
post #4 of 17 Old 06-16-2003, 08:49 AM Thread Starter
skatedork
Ahh a fellow dirty jersian Ever ride your jeep at the Pine Barrens?
I bent my wookie
post #5 of 17 Old 06-16-2003, 08:51 AM
Owen
Owen's Avatar
Yes I do...Paragon more though. More into rocks than mud...
Where do you live?
Owen is offline
post #6 of 17 Old 06-16-2003, 09:03 AM Thread Starter
skatedork
I live in Morris County on Lake Hopatcong. I heard of that place before. I haven't been off roading with my jeep before, I am just starting to upgrade it from its stock form.
I bent my wookie
post #7 of 17 Old 06-16-2003, 09:14 AM
Dee Cue
Dee Cue's Avatar
Hey, I dated a Jersian before, she wasn't dirty at all... However her driving manners/road rage scared the hell out of me.
Blk, '05 LJ, 6-spd, 3" Zone SL, 33" BFG AT on Soft 8's
Dee Cue is offline
post #8 of 17 Old 06-16-2003, 09:27 AM
Owen
Owen's Avatar
I work in livingston real close to you...We are having a big run and party at paragon on the 18th-20th of July...There will be other Stock jeeps running too...PM me for details or check out the thread int eh wheelin neighborhood forum...
Owen is offline
post #9 of 17 Old 06-16-2003, 10:33 AM
JeepEnthusiast
To reset it, disconnect the negative battery terminal and turn on the headlights for 10 minutes. Then turn them off and reconnect it. Should be back to normal.
JeepEnthusiast is offline
post #10 of 17 Old 06-16-2003, 10:35 AM Thread Starter
skatedork
Where is Paragon exactly? Isn't it in PA?
I bent my wookie
post #11 of 17 Old 06-18-2003, 06:09 PM
quadna71
quadna71's Avatar
jeep enthusiast,
why the headlights? i've heard of the battery disconnect before...just never the headlights too.
chris
2013 JKU Sahara - ours
2001 TJ SE - hers, 2001 XJ Sport - ours
2003 TJ Sport - sold, 2000 TJ Sport - sold
1993 XJ Sport - totaled, 1987 XJ Laredo - sold
1987 XJ Chief - sold, 1953 CJ-3B - sold
quadna71 is offline
post #12 of 17 Old 06-18-2003, 06:32 PM
wingzero1285
wingzero1285's Avatar
I'm guessing turning on the headlights uses all the electricity still between the lights and the battery... Oh and I live in Jeresy too, monmouth county. No really good places around here except for a few spots on the beach in Asbury Park.
-John- Red 97 TJ Sport
-Red Jeep Club #45- -97 Jeep Club #10-
Pioneer 6800
Infinity Reference 311 Mono Sub Amp
MTX TA3404 4 Channel Amp
Infinity Reference 4x6 in the dash
Infinity Reference 6.5 in the soundbar
Infinity Kapa 10inch subwoofer
Magnaflow Cat
Flowemaster 40
Rear window duck tape special (extra 25 HP)
wingzero1285 is offline
post #13 of 17 Old 06-18-2003, 06:41 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Well, turning the headlights on would drain any remaining charge out of any capacitors inside the computer, but it's really unnecessary to go to that trouble, nor for that length of time. Disco'ing the battery's negative lead for 2 minutes is more than enough time to completely reset the computer.
You could also, if you're really anal about getting rid of all the potentially stored conditions inside the computer, momentarily touch the disconnected negative battery lead to the positive battery post lead. Though this will not produce sparks as some may think, it will totally reset any remaining logic conditions in the computer... but is still totally unnecessary. Disco'ing the negative battery lead for 2 minutes is plenty.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is offline
post #14 of 17 Old 06-18-2003, 07:04 PM
JeepEnthusiast
I usually just let it sit for 10 minutes just to be certain. It will drain the remaining charge. I guess it will work for 2 minutes as well but I dont really time it. 5-10 minutes would make me 100% sure its all gone. The check engine light might appear later if the jeep is having trouble. Go to autozone and have them run a check for you. It will show you the codes.
post #15 of 17 Old 06-18-2003, 08:57 PM
AirborneSilva
AirborneSilva's Avatar
Aloha Jerry, remember about a month ago I had the problem of my tj stahling out and idling too high, this after taking my battery out and cleaing things up with water. They finally ended up telling me that after I disconnect the battery I have to let the engine run at an idle for 30 minutes... this sounds like a load of crap to me and I suspect they were not telling me the truth, any thoughts?
Thanks and Aloha
04 Rubicon, Stone White w/all options, RE 4.5" superflex, 1" BL & 1" MML, Custom Front Bumper, Custom Rear Bumper w/swing out tire carrier, Custom Rock Rails w/steps, Mile Marker 12K winch/w Amsteel Blue synthetic line, 15X8 Black Rock crawler wheels w/35X12.5 Pro Comp Mudders, 800 watt power inverter. York OBA.
AirborneSilva is offline
Is there a way to reset "check engine" light? wildbadbill YJ Wrangler Technical Forum 8 05-01-2009 11:56 AM
engine light reset? jeepster4.0 TJ Wrangler Technical Forum 4 03-27-2007 06:23 PM
Check Engine Light Reset Procedure WORKS! YEA! Overdrive TJ Wrangler Technical Forum 11 12-16-2006 10:28 PM
Check engine Light 03' 2.4 reset Gunkel TJ Wrangler Technical Forum 11 05-07-2006 07:45 AM
How to Reset the computer (Check engine light)? BNovak TJ Wrangler Technical Forum 3 06-27-2004 03:54 PM
